Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-02-2007, 01:28 PM
  #5101
Steven Key's Avatar
Which Lipo packs fit a M03m Mini chassis with out modifications?
Steven Key is offline
Old 10-02-2007, 02:37 PM
  #5102
tony gray's Avatar
Orion Carbon Edition - goes straight in
tony gray is offline
Old 10-02-2007, 05:46 PM
  #5103
You need to slightly modify the end pieces that hold the battery in place. The inside reinforcing ribs of the "L" pieces need to be shaved.
Sydewynder is offline
Old 10-02-2007, 06:08 PM
  #5104
Regional Moderator
Darkseid's Avatar
Or just tape it in.
Darkseid is offline
Old 10-02-2007, 07:24 PM
  #5105
Actually, elongating the holes in the battery holders is a lot easier and certainly less messy than Dremel dust all over you. Also that retains the rigidity of the end pieces
Granpa is offline
Old 10-04-2007, 09:49 PM
  #5106
billjacobs's Avatar
Trader Rating: 65 (100%+)
Default which way to put in the ta03 ball diff
when you put the ball diff into the transmission, which way do you put it in? Do you put it in so the diff screw is on the left or right side, looking on top of the mini with the front pointing north?
billjacobs is offline
Old 10-04-2007, 11:32 PM
  #5107
tony gray's Avatar
Use Tamiya AW grease on the balls, diff plates & thrust bearing, then (optional) put loctite threadlock on the step screw and tighten it until it stops (until you cannot tighten it anymore).
Install the diff so that the nylon gear part of the diff is in the right hand side of the chassis. (Screw is therefore on the left)
Old 10-04-2007, 11:33 PM
  #5108
Tiptoe's Avatar
I always put my diff in the car so that the rotation of the diff will tighten it. This seems to help keep the diff from spinning loose which is a commen issue with these cars.
Tiptoe is offline
Old 10-05-2007, 01:40 AM
  #5109
akura2's Avatar
anybody seen this yet?
4WD, 1/12 scale
www.active-hobby.com
Chassis Features:
Ultra-low center of gravity
# Fully adjustable suspension with extended suspension arms.
Ability to change the roll center
Dual belt AWD system including eccentric adjustable tensioning
Aluminium motor mount and F & R bulkheads
F & R CVD universal drive shafts
# Eccentric bulkhead the suitable belt pressure adjustment.
# F&R CVD universal drive shafts.
F & R adjustable ball diffs
Adjustable Ackerman steering system
Choice of 2 front shock towers
Adjusters come complete with turnbuckles and ball cups
Shocks include high quality low friction oil
Chassis accommodates both ladder and stick packs
Includes Sports Body
Includes Scale Rims and Rubber Tires 54mm size
Includes 540 motor
Includes Tamiya M03 bodies post sets
Includes full ball bearings
Haven't seen it mentioned yet... if it HAS been brought up...My bad
akura2 is offline
Old 10-05-2007, 01:56 AM
  #5110
tony gray's Avatar
Yep, you're bad. There's a whole separate thread devoted to it....
Old 10-05-2007, 02:55 AM
  #5111
DRAG_ON's Avatar
tony have you try running one way with your mini car ????
DRAG_ON is offline
Old 10-05-2007, 02:56 AM
  #5112
TryHard's Avatar
quick Q...
Has anyone used Ride's RP mini tires? or got any recomendations for mini tires on carpet?
Ta
Ed
TryHard is offline
Old 10-05-2007, 03:14 AM
  #5113
tony gray's Avatar
One ways don't work in a mini. For one you have no brakes, two you cant sit the car still on a slight incline (it just rolls)
There's no benefit to doing it really.
Old 10-05-2007, 09:27 AM
  #5114
Rock'sTC3's Avatar
I dont have a scale, but seems like my mini weighs a ton. it is a lot heavier than my TC. Thats just by picking them both up.
Rock'sTC3 is offline
Old 10-05-2007, 09:42 AM
  #5115
akura2's Avatar
My guess is that running a spool in the front would serve a similar purpose but still keeps the brakes
and thanks for straightening that out for me (the Active-hobby car)
I just saw it in the new Japanese October issue of RC Magazine
akura2 is offline
