Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-14-2005, 10:18 PM
  #376
snopro31's Avatar
Trader Rating: 57 (100%+)
Originally Posted by RED-LINE M03
Very nice web site I like that mo3-l!!!
Have you ever ordered from this web site?
How do you convert Yen to Dollars?
Thanks for the site info.
Go to http://www.xe.com/ucc/ they have one of the best sites to convert money over.
snopro31 is offline
Old 06-14-2005, 11:08 PM
  #377
Default help me figure this out
OK I finally got my m-03 running and all upgraded. It is set up pretty much with every tamiya upgrade and bearings, ball diff, universals. I also have a m-01. both of these I have only had the m-01 for 2 weeks and the m-03 for less than one. I put the same gear in my m-03 to compare to the m-01. same motor, battery, esc, reciever etc. the m-01 is alot faster than the m-03. And I cant figure out why. is the gearing different? I can't pinpoint a huge friction difference. the m-01 has the stock gear diff. the only thing I can figure is the m-01 is used so the grears are very well worn in. The m-03 is new with the ball diff. could this cause enough friction to cause it to be a slower vehicle? Sort of dissapointed the m-01 was so fast and handled pretty well. the m-03 handles even better but the speed lacks. I ran a 20T pinion in both. I also wore through the stock tires in one battery. I guess it needs an alignment.
gpwpat is offline
Old 06-15-2005, 06:13 AM
  #378
Core Creations's Avatar
Trader Rating: 108 (100%+)
I'm pretty sure the M-01 has a little taller gearing, not much, but enough to see a difference. Did you try it with the same motor. Sometimes really well worn in 540s are awesome. They usually get better with age.
Core Creations is offline
Old 06-15-2005, 07:46 AM
  #379
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Anyone have a setup for the M04-M or a website for them. That M03 site was awesome. That is some wild looking Mini that guy has.
wyd is offline
Old 06-15-2005, 07:48 AM
  #380
wyd
Tech Legend
wyd's Avatar
The 540's are almost always alot better after they have been a bunch as the brushes start breaking in some. When new the brush is contoured the wrong way and takes a really long time for it to fully break in.
wyd is offline
Old 06-15-2005, 08:36 AM
  #381
Jam-ehz's Avatar
Arrow Mini building guide
Not sure if it's been posted before, but our local Mini-master here in the GTA has a great little guide posted on how to set up his. His car races like a touring car, and is impossible to roll over, it's amazing watching it go. He's trying the M-03L for this year's TCS, and it's another one to watch.
I followed this link to a tee for my M-04M, and it's a great racer now.
http://rcontario.com/rcorevms2004.html
Jam-ehz is offline
Old 06-15-2005, 09:20 AM
  #382
wyd
Tech Legend
wyd's Avatar
Thanks!!!!!!!
wyd is offline
Old 06-15-2005, 09:51 AM
  #383
I did use the same motor on both mini's not the 540 can but an after market stock motor form one of my offroad trucks. I will look into it a bit more.
gpwpat is offline
Old 06-15-2005, 02:28 PM
  #384
About the only thing I would add to Mike instructions there, which are brilliant BTW, is to pay particular attention the the rear uprights and arms. After a few runs they develop slop and nee a little shimming and the Super Glue trick on them to keep them true.
I put a SS hinge pin and add a drop of SG to the pin. The Nylon in the upright will not allow a real hard set to the SG but it does wick in and take up the slop. It ia also handy to have a 3mm bit(Tamiya has a pre packaged one with handle) to ream the arm hole a touch if you have a bit too much SG.
Difuser is offline
Old 06-16-2005, 08:41 AM
  #385
That setup guide is pretty good. I am really addicted to these little cars. not playing with my others for 5 years or so these mini's have really gotten me back in the hobby. I can't believe how buch I have dumped into them in 2 weeks. Found out with a little online research why the m-01 is so much faster than the m-03
M-01 gear ratio 2.4375
M-03 gear ratio 3.134
this would shurly make the difference.
Has anybody upgraded their gears to non tamiya? I found some at Integy that have upgraded gear ratio. I know not tcs legal but I have a tcs legal car and I want it for fun. I just want my m-03 to match my m-01 speed and out handle it with the same motor.
any word when and if body sets will be available for the 2 XB mini's just released? I got to have some scale bodies and the monte carlo kit. been thinking about getting the xb monte carlo to just have as a base line to what it is set up like now. and to be a shelf queen.
gpwpat is offline
Old 06-16-2005, 01:10 PM
  #386
Nova F1 Racer's Avatar
I thought I read some where that the front steering block and front castor block for the tl01 was the same as the m03????????
Is that correct?
THX
Nova F1 Racer is offline
Old 06-16-2005, 03:09 PM
  #387
GPW yes I have run the gears in a non TCS event and we were able to run the car at the same speed as sedans.
Nova I believe you are correct for the castor block
Difuser is offline
Old 06-16-2005, 08:59 PM
  #388
Jam-ehz's Avatar
Any tips on getting the gears to be a little quieter? Mine sound like they're grinding a stone out, but they're all clean and lightly lubed with super-speed gear lube, and have smooth bearings on them.
I bought a new set with a new steel pinion to no avail, but I haven't replaced the diff gear yet.. could that be it? It's the TA03 ball diff... do they have replacements for just that gear?
Does the M04 Aluminum heatsink-mount actually do anything? It's only touching the motor with 2 screws...
On a side note, what colour should the Tamiya black-can Sport Tuned brushes be? I think I've overgeared it for a race and baked them with the TB-02 , and they're a dark purpley-grey. I forget what they were before, but i'm being outrun in every race (hey, could be the batts too, I guess). Is there any way to fix them, or is that it? How hot should it be after 5 mins?
Thanks!
Jam-ehz is offline
Old 06-16-2005, 09:23 PM
  #389
Default mo-3 cvd's
Hi guys, I once purchased a set of cvd's for my mo3L.I have since snapped the end of 1 axle.I cannot remember the part #.all i can find is 53205 wich is a universal set.any help appreciated
jim beam is offline
Old 06-16-2005, 09:32 PM
  #390
tamiyarcracer's Avatar
Not sure why it broke. There is a newer version, more like a 415 type.
53597 M03 ASSEMBLY UNIVERSAL SHAFT
tamiyarcracer is offline
