Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-22-2007, 05:42 PM
  #3376
tony gray's Avatar
Nope....wont fit, no matter what you do. Simple as that.
tony gray is offline
Old 02-22-2007, 10:36 PM
  #3377
Three's Avatar
Default Mini questions
Got a few questions about preparing a Mini Cooper that is TCS legal.
1. Which shocks would be better the #50746 C.V.A. shocks, #53155 shocks or #49198 dampners ?
2. What other replacement parts are a "MUST" have for TCS racing ?
3. Any online stores that stores (other than Tower) that stock these parts ?
4. What tires should be used ?
5. Is the #53267 TA03 ball diff better than the #53341 Manta Ray ball diff ?
6. What spare parts should I keep on hand ?
7. What set-up tools for tuning do I need ?
Mini thanks ..................
Three is offline
Old 02-22-2007, 11:02 PM
  #3378
tamiyarcracer's Avatar
1. the TRF dampers are the best
53280 Super Low Friction Damper - TA03
53571 TRF Fluorine Coated Damper
49355 TRF Damper Special Set
but the the 50746 CVA Super Mini Shock Unit will work great
2. the mini is tough, if you are using the stock uprights I would recommend the 53523 Alum Fnt Upright Set - M03, M04 and the 53345 Toe-in Rear Upright. Maybe a gear set or 2 50794 M03 G Parts. I would get some if the spring sets 53163 On-Road Tuned Spring Set - (4WD/FWD Touring & Rally Car), 53333 Touring Car Tuned Spring - Set (Short), 53440 On-Road Spring Set (Hard). MAybe a 53343 M03 Front/Rear Stabilizer. You will have to get a bearing set.
3. Online Stores?? The best is RC champ, all you have to do is email what you want to them then you get an email with the price. They are cheap. http://www.rc-champ.co.jp/ on the left it says Oversea Mail Order.it explains it well.
4. Tires depends on surface.
5. the TA03 is an updated and lighter version of the Manta, so I recomend the TA03 version.
6. spares, upright tree.
7. No real set up tools needed. only thing to adjust would be front toe.
What car are you getting?? I recommend getting the swift kit.
tamiyarcracer is offline
Old 02-22-2007, 11:09 PM
  #3379
TENCHO's Avatar
heres a pic of my "non TCS legal" mini....i live in hawaii, we have our own rules. Aluminum arms are made by Racy, and Active hobby VW body was my first airbrush job.
TENCHO is offline
Old 02-22-2007, 11:17 PM
  #3380
Three's Avatar
Thanks tamiyarcracer !!!
Purchased the Rover mini.
Should I use the Tamiya bearings or opt for some ceramic bearings from Acer?
I normally race pan car oval so this mini world (as far as upgrades/modifications) seems to easy. Hope I can learn to turn right.
Will be racing on a prepared parking lot (Memphis, TN TCS race). Any suggestions on shock oil and springs for initial start point ?
Is there any trick to the foam inserts and tires ? Making tires is a new thing to me.
Three is offline
Old 02-22-2007, 11:27 PM
  #3381
I don't know your surface,
I'm gonna stand on a limb you will want the 53340 60D Reinforced Tires A. I run a sedan insert with a mini foam insert under it in the front, and a nard insert in the rear, on my asphalt track
front:maybe a red or yellow spring from the 53440, 60 w oil, 6 mm of spacer under the piston to limit droop
Rear, yellow or blue spring from 53333 40w oil about 6mm of spacer under the piston to limit droop
Any bearing is fine in a mini. I have spent money on the ceramics, but I don't think it is an advantage in a mini.
Old 02-23-2007, 12:22 AM
  #3382
tony gray's Avatar
Latest update to rc-mini. The super-cool and cute Chevron Subaru 360 shell. We've finally got one...
Old 02-23-2007, 12:53 AM
  #3383
Customworksking's Avatar
Trader Rating: 74 (100%+)
Arrow TCS
WHAT'S THE WORD Who is going to be @ the tcs race @trackside ????
Customworksking is offline
Old 02-23-2007, 01:24 AM
  #3384
Three's Avatar
Now a question about motors....
Johnson or Mabuchi, which is better for legal TCS racing ?
How do I get them to peak performance ?
Three is offline
Old 02-23-2007, 04:43 AM
  #3385
Matt Howard's Avatar
from the few motors of those types that I've played with the Mabuchi's have a bit more torque but the Johnson's have a bit more top end. I think the track layout would determine which one is faster, at least for me.
Matt Howard is offline
Old 02-23-2007, 08:38 AM
  #3386
OSherman's Avatar
Cool
Originally Posted by rccardr
.. Just figure out a way to equalize the cells before use......
And exactly what kind of doo-hik-eey do i need to do this??.. I'm guessing this would be some sort of mad-scientist-basement-built-gizmo type deal..
OSherman is offline
Old 02-23-2007, 08:44 AM
  #3387
OSherman's Avatar
Originally Posted by Difuser
O- I think SMC has some prebuilt 4200 Sticks. Locally alot of the guys are still running the Tamiya GP3300 sticks as they are low cost $$$. The SMC sxs prebuilt I think we sell for $43 up here not sure what a Stick is.
We also have a few who build the 4200 matched into a factory look stick pack.
Is there any special braid/bars i should know about for building stick packs..
I've done/tried it in the past, but the braid then was just waayyy to thick and my soldering skills werent the best.. Resulting in 'stretched' packs that were just a tad too long
OSherman is offline
Old 02-23-2007, 08:50 AM
  #3388
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Stick pack how to: http://www.logoheli.com/end2end.htm
CCristo is offline
Old 02-23-2007, 09:17 AM
  #3389
OSherman's Avatar
Thumbs up
Good read there..
One question.. What is that C/10 charge they mention to 'equalize' the cells??.. Is that just a very low charge rate?.. Would .5 -1 amp suffice? Or would that still generate too much heat in some cells while the others are 'cathcing up'??
OSherman is offline
Old 02-23-2007, 11:05 AM
  #3390
CCristo's Avatar
C/10 is the capacity of the pack divided by 10. So, a 4200mah pack you would charge at .42 amp.
CCristo is offline
