Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-21-2007, 07:42 AM
  #3331
muahdib4's Avatar
Originally Posted by Bikerbob
using your same arguement then.. you would not be able to run a ball diff in a Mini chassis..
Tamiya has NO ball diff listed as a hopup for the Mini chassis.. Manta Ray.. yep.. TA04 (I think this is the other one people use?) yes.. but not Mini.
As for Canada... Our group has confirmed with Tamiya Canada that the 1 way is legal.
Now.. weather that is the same in the US.. or Worlds etc.. I have no idea.
James
The rule reads the same in Canada "4. Any Tamiya Hop-Op Option and/ or spare part is allowed as long as it is used in the way it was designed, and on the vehicle it was designed for." I can't find a list of available "Canadian" hop-up parts on the Tamiya Canada website but on the U.S. website (http://www.tamiyausa.com/) you can look at a particular chassis and view a list of available hop-ups FOR that particular chassis. The Manta Ray AND TA04 ball diffs are listed there as hop-ups and are therefore legal but there is no 1-way listed. Maybe Canadian rules are different but if you won the trip to Japan....get ready to change it because it won't be legal there. Not really sure why Tamiya Canada would approve something that isn't legal anywhere else but who knows.
muahdib4 is offline
  #3332
slotcarrod's Avatar
James
What is the part # for that one way?
slotcarrod is offline
Old 02-21-2007, 07:50 AM
  #3333
tamiyarcracer's Avatar
the one way is for the TA02. I think it was 53200, but it is not legal in the US or Canada
tamiyarcracer is offline
Old 02-21-2007, 07:55 AM
  #3334
Jam-ehz's Avatar
Originally Posted by minimanintaiwan
Anyone know if you can replace just the Pressure plate B on the TA03 ball diff. I've stripped the thread on two of these already!!!
This is a good rebuild/upgrade kit for your TA03 diff, if you can find it: 53219 TC Aluminum Pressure Plate set.
It's machined aluminum, not cast, and is 30% lighter. Comes with a full set of cone washers and a one-piece bearing for a full rebuild, pretty well everything to make a diff except the gear, balls and outdrives.
On the other hand, as a result I have a spare set of TA03 diff A and B plates.. PM me if you're interested.
Jam-ehz is offline
Old 02-21-2007, 07:57 AM
  #3335
Turbonium's Avatar
Trader Rating: 27 (100%+)
http://www.tamiyausa.com/product/rcp...tion=&offset=1
this is the page on Tamiya's website listing the hopups for the M03.... the TA03 diff is actually listed,as well as the Manta one there....
i think a lot of that is actually left up to the club running the regional events, but held to TCS rules, they would be out.
Turbonium is offline
Old 02-21-2007, 08:00 AM
  #3336
muahdib4's Avatar
this is the page on Tamiya's website listing the hopups for the M03.... the TA03 diff is actually listed, but i didnt see the Manta one there....
It's there..part #53070...about 1/2 way down the page. I'd still like to know where the confusion is on the 1-way. Everyone says it's not legal but Bikerbod did say they verified that it was legal. Sounds like it needs RE-verified.
muahdib4 is offline
Old 02-21-2007, 08:03 AM
  #3337
muahdib4's Avatar
Tamiya rules do allow both of those diffs in TCS legal competition since they are listed as hop-ups for the M-chassis and all regionals and worlds allow them.
muahdib4 is offline
Old 02-21-2007, 08:23 AM
  #3338
mach51's Avatar
Trader Rating: 31 (100%+)
probably been asked 100 times, whats the bearing sizes for the M03 Mini?
want to rebuild mine but would rather get bearings from Avid. thanks.
mach51 is offline
Old 02-21-2007, 08:34 AM
  #3339
SteveM's Avatar
Trader Rating: 165 (100%+)
There are twelve 11x5 and two 8x5 metric ball bearings in the SWB M-03. The new M-03M uses eight 10x5, two 8x5 and two 11x5 metric bearings. Kits are available on the Bay dirt cheap.
SteveM is offline
Old 02-21-2007, 08:35 AM
  #3340
minimanintaiwan's Avatar
2 x 850 Ball Bearings
12 x 1150 Ball Bearings
minimanintaiwan is offline
Old 02-21-2007, 08:57 AM
  #3341
I read that the chassis length is set by a spacer in the chassis, is there a spacer in the shortest chassis? Id like to get the M03M for its newer stronger parts but want to run the short version to run the old style mini cooper body.
The8BitHero is offline
Old 02-21-2007, 08:59 AM
  #3342
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
To use the old style mini body just remove the spacer.
CCristo is offline
Old 02-21-2007, 09:00 AM
  #3343
Sweet thats what I was hoping for, thanks!
Old 02-21-2007, 09:12 AM
  #3344
slotcarrod's Avatar
Thanks for the # but if it's not legal, I don't want it.
Old 02-21-2007, 09:44 AM
  #3345
#53200 Tamiya 4WD Front One-Way Differential Unit. Is this it? What do you use it with. gear diff, ball diff or stand alone? It does say, used with TA03 chassis so maybe if you're running a TA03 ball diff in your mini you can use this as well. Maybe a loophole the judges in Canda allowed.
