Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-06-2007, 05:28 PM
  #3196
defMondo's Avatar
Originally Posted by minimanintaiwan
Just got my Team Orion Carbon Lipo 3200 pack! Will run it in my mini very soon. Thanks tony/rc-mini for the setup info. Looking forward to that extra jump/speed/runtime! just wondering if you could show a picture of how you wired it up. Looks like all your wiring is in the chassis and the pics on rc-mini don't really show much detail. Do you also run a balancer between your charger and pack? How many amps are you charging with? Thanks!!
Checkout taipei's 1st indoor rc track. It's short and winding; just perfect for the mini!
The wiring is all hidden in the chassis, when I can be bothered doing it I like it better that way, I dont like seeing lots of wire hanging out everywhere.
I'll try to draw a wiring diagram tonight, if I have time (packing for a trip). But basically it's wired as normal, the only difference is that I'm using the Novak Smart Stop (NSS) 2 cell version, which prevents discharging the lipo to far so it wont burst into flames .
I have wired the NSS to the battery inputs on the ESC and then using double sided tape stuck it on top of the ESC. The cable from the ESC that normaly plugs to the receiver is plugged into the NSS and the wired from the NSS plugs in to the throttle output on the receiver. Prety straight forward.
I dont run a balancer for the lipo, Orion dont seem to recomend one, and I charge at 3.2amps, Lipos have to charge at the capacity of the battery or less to prevent damage, so for a 4800mah pack you would charge at up to 4.8amps and for a 1800mah pack charge at up to 1.8amps.
btw nice track, wish we had a good indoor track here.
tp
defMondo is offline
Old 02-07-2007, 07:54 AM
  #3197
minimanintaiwan's Avatar
tp
Ok. thanks guys. Do you protect the pack at all with any reinforced tape or something to keep that cool carbon look shiny?
minimanintaiwan is offline
Old 02-07-2007, 11:20 AM
  #3198
defMondo's Avatar
I haven't done anything to protect the battery the only place it's gotten marked so far is where the battery rests on the chassis, so there are some scrape marks from the battery rubbing on the chassis, but I dont think you can do anything about it because it's a snug fit in the mini, any tape would make it difficult to put the battery in.
I do use a rubber band on each side of the battery to hold it to the battery supports,we all do this here to stop the battery sliding out during "racing incidents".
tp
defMondo is offline
Old 02-07-2007, 06:28 PM
  #3199
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default trf shocks
I am new to mini and I was going to install some trf shocks.
What is the general starting setup.
Overall length?
Amount of internal limiters?
Shock oil front front and rear?
Springs front and rear?
I tried to search it but I couldnt find what I was looking for.
Jamie
J.Gonzalez is offline
Old 02-07-2007, 06:47 PM
  #3200
muahdib4's Avatar
Overall length?
Jamie
Height, I have mine so there is just barely room to get the spring retainer on and I'm going to get the 1mm down spring retainer so I can get a little lower.
Shock oil, I currently use the same that I do in my TA05 and that's 60 front and 40 rear.
Springs, I'm using white front and I'm torn between yellow and red in the rear. All of them are the short tuned tamiya type.
muahdib4 is offline
Old 02-07-2007, 10:39 PM
  #3201
flying G.E.O.'s Avatar
Nice track. The other pics are small. Mr. Black mentioned that its possible to charge 3200 lipo at 4amps. Its just too slow at 3.2amps so the waiting period is really long. You need 2 packs atleast.
flying G.E.O. is offline
Old 02-08-2007, 12:55 AM
  #3202
try their site for better pics: scroll down half way.
http://www.shop2000.com.tw/23T/
I read that over time charging at higher amps reduces battery life.
Old 02-08-2007, 07:45 AM
  #3203
xrayroooahhhh's Avatar
Default Bodies??????
defMondo or tony gray have links to rc-mini.net.......on that site it has a list of several different bodies that will work on the M03 chasis. Could someone tell me if there is anyone carrying these bodies in Canada/USA or a link to where I can order these??? Also on that web-site it says HPI rims and X tread tires work well........is any body/tire allowed at Tamiya races or is there a aproved list??? Thanks guys!
Roy
xrayroooahhhh is offline
Old 02-08-2007, 07:52 AM
  #3204
muahdib4's Avatar
Roy
At Tamiya Races, only Tamiya bodies and Tamiya wheels and tires are allowed. Check out Tamiyas website for what they offer...I prefer the standard, old school Mini Cooper body and S-Grip 60D tires in front with M-Grip 60D tires on the rear.
muahdib4 is offline
Old 02-08-2007, 10:44 AM
  #3205
djgoku's Avatar
Default 2 much tire spin
Hello all Mini Racers!!!!
Iím new to this forum and spended lot of time learning from your tips,
I race M03 in a club here in Mexico that only allows Tires(tamiya, hpi, ride rp), mostly there were 2 racers qualifying on a certain lap, about 8 of us one lap behind and 12 to 15 more racers a couple of laps behind then the rest of the field about 15 more racers, the races where very competitive and no boarder line illegal issues until now.
Since a couple of months one of the top guys has been qualifying (5min hits) 3 more laps than the rest of the field and wining the A main (20 min) by more than 5 laps.
Iíve noticed he lowered the ride height, but he sling shots out of the curves in a way no one of us has been able to emulate,
M03`s have a tendency to spin the tires on acceleration HOW DO I CURE THIS?? (tire incerts, diff, dogbones, ride height)
djgoku is offline
Old 02-08-2007, 10:50 AM
  #3206
axle182's Avatar
Trader Rating: 18 (100%+)
He has locked or semi locked the diff. Means that both wheels are powering out of a corner on acceleration. easy to do, easy to tech. Ive got a TA03 ball diff in mine and its tight, so i get great acceleration out of corners with my M03L. HTH
axle182 is offline
Old 02-08-2007, 10:56 AM
  #3207
muahdib4's Avatar
You do want to keep the ride height as low as possible and use good stiff Tamiya white or blue springs up front. Are you currently running any stabilizers up front? Use a lighter spring in the rear and I don't run any stabilizers out back either. As for inserts, we've been using HPI 26mm soft inserts which stiffen up the sidewall of the tire and keep it from flexing which in turn helps with traction roll. It also could be that the guy winning is just a really good driver. I get beat by guys running the exact same setup I am by a couple laps. They just outdrive me...they actually turn in lap times almost as good as our Stock Sedan guys.
muahdib4 is offline
Old 02-08-2007, 11:25 AM
  #3208
Customworksking's Avatar
Trader Rating: 74 (100%+)
I run the stock gear diff and shim it tight with 5 shims 3 on 1 side and 2 on the other and it's allmost like a spool very little diff action the car ripps off the conner!!!
Customworksking is offline
Old 02-08-2007, 08:07 PM
  #3209
Registered User
Bodywerx's Avatar
What kind of shims are you using?
Bodywerx is offline
Old 02-08-2007, 10:27 PM
  #3210
Red face ????????<<<<<>>>>>>>>
the kit comes with a few u will need to for some more zi'm sure someone here knows how to get more....
