Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-22-2007, 03:29 PM
  #3091
SteveM's Avatar
Trader Rating: 165 (100%+)
Originally Posted by Tim K
Keith - I've got the RP30 mini tires. The RP tire numbers run in reverse, ie 24 is a harder compound, 30 is mid range and 36 is soft.
I was told that the documentation that comes with the RP mini tires is wrong and that the higher numbers mean firmer tires. Meaning the RP24 would offer more grip......RP36 less.
SteveM is offline
Old 01-22-2007, 03:30 PM
  #3092
Core Creations's Avatar
Trader Rating: 110 (100%+)
Core Creations is offline
Old 01-22-2007, 04:09 PM
  #3093
Originally Posted by Jam-ehz
Yeah, we've used fans with the 19T GT1 and Black-can GT2 class, no problems.. Not sure if I've ever seen one on a Mini, though..
Yeah, thats what I was referring to, but when you use them they are used as a motor heatsink (since that was open). The M chassis fan is not a motor heatsink.
SeaKayCarthik is offline
Old 01-22-2007, 08:38 PM
  #3094
akuhon's Avatar
Do you guys have the M03 (not the M03M) tech racing conversion manual ?
I'm curious about the steering system..... I see from the pics (Jap RC World Nov and Dec 2006) , they are different....
I already got the M03M manual from Tony G (rc-mini.net, thanks mate ).....
Now I need the M03
Could you post it ?
TIA.
akuhon is offline
Old 01-22-2007, 10:08 PM
  #3095
I'm sure those inserts are for mini as Spice also do a new series of rims for the mini as well, I found some photos:
Might have to buy a set of the black ABC rims, my white ones shattered on the first run, I couldn't believe it!
I just bought some of the black ones today! If you want, I'll let you know how they hold up before you order yours. Just gotta wait for them to come from Japan ;P
BadCarmaNY is offline
Old 01-23-2007, 12:03 AM
  #3096
f2000racer's Avatar
Default new to mini
Hi guys,
I'm a novice in terms of running a mini. I've pretty much read everything there is to a mini, except I'm a bit lost with regards to inserts.
I like my ride to be TCS legal and would like to know what Tamiya inserts works with the mini.
f2000racer is offline
Old 01-23-2007, 01:04 AM
  #3097
gcooper's Avatar
I read through the entire post and I am a little confused about the swift conversion. I know it was covered maybe clear to ya but not to me.
What would I need to convert my M04M roadster to swift suspension?
I am guessing my M04 comes with 0 deg toe in and would need the 2 deg?
The swift is better suspension?
Keep up the great work and comments. . .
Oh and Customworksking, I think I must have missed your setup & testing info from the Novak race?
Coop
gcooper is offline
Old 01-23-2007, 04:39 AM
  #3098
i know it is a M04, but that body should be easy to cover a M03L i gues... aint it the most beautifull shell you have seen lately?
look at those wheels too ... YUM YUM!!
coming soon by tamiya http://www.tamiyausa.com/product/ite...oduct-id=58383
DrKucho is offline
Old 01-23-2007, 05:05 AM
  #3099
SteveM's Avatar
Default Tamiya Manuals
Go to http://www.tamiya.com/english/rc/manuals.htm to download a copy of the M03 manual.
Now I need the M03
Could you post it ?
TIA.
SteveM is offline
Old 01-23-2007, 12:48 PM
  #3100
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
TG10 servo posts are #53308
Thanks Tim K. Anyone have some they want to sell? It seems they are not available anywhere.
CCristo is offline
Old 01-23-2007, 12:53 PM
  #3101
muahdib4's Avatar
Anyone have an idea when this is going to be out officially? I want one of these almost as much as I wanted the worm body...which will ROCK once it gets here.
muahdib4 is offline
Old 01-23-2007, 06:39 PM
  #3102
akuhon's Avatar
Sorry,
I mean M03 conversion kit from Tech Racing .... not from Tamiya ...
akuhon is offline
Old 01-24-2007, 02:39 PM
  #3103
Hey, dont know if any of you guys knew this already, but I bought a gram scale, and for hahas weighed the M03 kit-stock 20T Pinion, and a Robinson Racing 20T Metric Pinion...
Kit - 1.7g
RR - 3.8g
The Robinson is twice the weight.. Not that either weigh MUCH.. just an interesting thing I thought I'd share with those who might like that info..
Old 01-24-2007, 05:51 PM
  #3104
fatboy's Avatar
Default pinion size
Hi, just completed building MO3M and wonder what pinion size you guys using for 23turn stock motor with the spur supplied by the kit.
hope to hear from you guys soon.
tq
fatboy is offline
Old 01-24-2007, 06:05 PM
  #3105
tamiyarcracer's Avatar
tq
what 23t?
I had atamiya 23turn and the 20t pinion was fine, but with that said if you had a 18t pinion you would be set!
tamiyarcracer is offline
