Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-19-2007, 01:20 PM
  #3031
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default lock
Originally Posted by Wicked-Wayz
Just able to rotate I think carl. I think per the rules it can't actually be locked. Maybe someone else knows exactly.
Peace Aaron(W-W)
true lock as tight as u can but still has action and its legal
Customworksking is offline
Old 01-19-2007, 03:46 PM
  #3032
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Yea that is exactly what I said. The diff still needs to have some kind of action to be legal.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 01-19-2007, 04:49 PM
  #3033
wallyburger's Avatar
muahdib4, MrLesac,
Thanks for the reply.
muahdib4,
Does any lipo charger work for the TO 3200 Lipos?
wallyburger is offline
Old 01-19-2007, 05:03 PM
  #3034
muahdib4's Avatar
Originally Posted by wallyburger
muahdib4, MrLesac,
muahdib4,
As far as I know they do. The best buy on a Lipo charger is the Team Orion Avionics which you can usually buy for around $80 and it'll charge NiCd and NiMh too.
muahdib4 is offline
Old 01-19-2007, 06:52 PM
  #3035
Thanks again.
The reason I ask is I already have a triton and hyperion I use. Didn't want to have to shell out more $$ for another charger.
Old 01-19-2007, 08:25 PM
  #3036
padailey's Avatar
No special lipo charger needed for any lipo. If you have a 3200 you would just want one that charges at 3 amps at least. Not 100% needed to charge that high but if not it will take quite a while to charge. A guy I race with uses a Triton Jr for his 3200 and it works just fine.
padailey is offline
Old 01-19-2007, 08:41 PM
  #3037
Question about stuffing tires with more than one insert for carpet. On what tires? any specific pattern? or just lay one atop another I am ordering extra sets of soft and hard 60d inserts. I am still trying to find the perfect carpet setup (tires & inserts) for m03m.
Cheers,
Carthik
SeaKayCarthik is offline
Old 01-19-2007, 09:01 PM
  #3038
For tire stuffing I lay the sedan insert in first and then the tamiya foam second. The diameter of the 24mm insert will lay spot on against the outer diameter of the inside of the tire if all that makes sense.
Difuser is offline
Old 01-19-2007, 09:07 PM
  #3039
took me a while to understand but I get it. when you say sedan tire you mean touring car (regular sized wheels)? what do you mean when you say tamiya foam?
random question:
I am not too good with precision things so if its possible I dont need to cut the foams I would prefer to go that way. will regular 24mm touring car sized foams fit perfectly over the diameter of the M chassis foams? and the inner diameter of the tires? why not use 26mm? wont the extra 2mm help stiffen the sidewall.
another random question, what is tamiya re-enforced aluminum tape (#53361 used for (battery?), and is the glass tape (#53170) the kind I want for taping in batteries
one more random question, when rebuilding my bearings to make them smoother, will tamiya bearing oil do the job? item number 53508
Cheers,
Carthik
Old 01-19-2007, 09:17 PM
  #3040
Part Number 49355... the Blue TRF Dampers... Do they use the short springs, or the long ones?
BadCarmaNY is offline
Old 01-19-2007, 09:21 PM
  #3041
You want to use the 24mm sedan insert inside a 60d Mini tire then use the Tamiya strip foam that came with your Mini. All on a Mini rim.
Difuser is offline
Old 01-19-2007, 09:24 PM
  #3042
oh, ok, that makes more sense now, I though you were starting by mounting it on the rim, not tire. soft or hard touring car insert? see my above post again, I edited it with more questions. why not use 26mm sedan inserts instead of 24? wont the extra 2mm re-enforce the sidwall?
Thanks,
Carthik
Old 01-19-2007, 10:28 PM
  #3043
the 26 is just too wide along with being too thick. You can use a cut down 26mm with no other insert for a good airgap tire though
The tapes were for re-inforcing and heat shielding if I remember correct.
For bearings I usually use 1 drop of Tribo after the bearing has been cleaned of all other greases
Difuser is offline
Old 01-19-2007, 10:38 PM
  #3044
Ok, I will use 24 then. What type touring car insert (soft or hard)? What is tribo btw?
I was thinking this for my indoor carpet setup, any comments/suggestions?
front
-type A 60D tire
-hard 60D insert
-hard 24mm touring insert
rear
-type A 60D tire
-hard 60D inesert
-soft 24mm touring insert
would that work? I dont want to lost too much on the handling but would prefer if my A's dont wear out so fast.
Carthik
Old 01-20-2007, 06:39 AM
  #3045
hi guys, i found someone talking about the speed tuned gear set for tamiya minis, what is the part number? i cant find it anywhere ... ??
DrKucho is offline
