Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-06-2021, 11:25 PM
  #29971
R/C Tech Elite Member
monkeyracing's Avatar
I use M3 screws with generic hardware store washers under the heads. Works. Those mounting holes do look a little large.
monkeyracing is offline
Old 03-05-2022, 11:32 AM
  #29972
Have not been able to find the old S-Grips (TAM53254) for some time now. Have they been officially replaced by "TAM54995 (60D Super Radial Tires M-Chassis/Soft) and how do they compare?
OFFroadrunner is offline
Old 03-05-2022, 11:59 AM
  #29973
Raman's Avatar
Trader Rating: 84 (100%+)
The old S grips should still be available.. probably hard to come by due to supply chain issues.
This is what I got from Tamiya a while backIt’s a step softer. They have a narrower temperature range and will wear out faster in warmer track conditions, but will have a lot of grip on medium to low track temp conditions. The standard S grips have a wider temp range. Longer wear cycle too.
OFFroadrunner likes this.
Raman is offline
Old 03-09-2022, 02:06 PM
  #29974
On asphalt, would it be better to run S-grips all around, or consider the H-grips in the front for a FWD car?
My thinking with the harder front is to mostly to take out some twitch, and have them last longer since the tires are doing double duty. Not sure if the TCS H-grips have enough traction though.
Xtracrispy is offline
Old 03-15-2022, 05:40 PM
  #29975
Hi All,
Are the Tamiya Mini Copper and VW Golf Mk 1 body shells still available?
I can only find the part number for the full kit, not the body shell alone, Tamiya 58438 Mini Cooper M-05 Chassis Kit - Body shell only
Also is the Tamiya Volkswagon Golf Mark 1 body shell still available? Tamiya 47308 Volkswagen Golf Mk.1 M-05 Chassis Kit - Body shell only
For both the Mini Copper and the Golf I can only find aftermarket body shells.
Thank you ! Very much appreciated.
museguy is offline
Old 03-15-2022, 06:13 PM
  #29976
gigaplex's Avatar
Mini Cooper, definitely not available. Tamiya weren't able to renew their license.
VW Golf Mk 1, I'm not 100% sure but I think they're discontinued too.
gigaplex is offline
Old 03-16-2022, 10:17 AM
  #29977
Team Blue Groove repops them. They're not full tamiya sets, but you can find them on ebay.
oreo likes this.
Nerobro is offline
Old 05-06-2022, 07:33 AM
  #29978
EDWARD2003's Avatar
Thank you in advance.
Can someone do me a favor and measure the distance (center to center) of the two mounting holes.
EDWARD2003 is offline
Old 06-16-2022, 09:51 AM
  #29979
I just bought a used M05 Pro V2 with the clear plastic dampers. Can you all tell me what spring set I should buy for tuning options? Also what tire combo would be good for black carpet?
CTRJ is offline
Old 06-16-2022, 01:02 PM
  #29980
sosidge's Avatar
Look for the older style short springs. #42168 is what I used. Tyres will depend on the track, best to ask locally.
gigaplex likes this.
sosidge is offline
Old 06-16-2022, 06:01 PM
  #29981
Shock tower looks reversible for low cg shocks...Nice...
bertrandsv87 is online now
Old 06-16-2022, 08:15 PM
  #29982
gigaplex's Avatar
The mini shocks are already pretty short. You'd need something half the size to fit with the tower upside down.
gigaplex is offline
Old 06-16-2022, 08:32 PM
  #29983
Maybe the ULP shocks built with short ballcups will fit on the first inside hole, in case the original shocks are not available ...
Old 07-24-2022, 06:00 AM
  #29984
Three's Avatar
Talking M07R
Anyone know where I might find a M07R kit for sell?
Three is offline
Old 09-17-2022, 11:32 PM
  #29985
I just love the M01 so much. I wish Tamiya would remake the original M01
Autostrada048 is offline
