Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-26-2017, 04:05 PM
  #29296
Toyota Tom's Avatar
Default Build notes M-07
A few notes from my build. The motor plate hole is too small for a
24 pinion. A round file fixes that issue. The left front chassis brace
won't allow a brushless motor, no room to solder the ESC wires. Left
that brace off. The stock plastic shocks use a 28 mm shock shaft. If you
are trying to use the short option shocks, they are not long enough.
You can use the long shafts from the kit, or use the front M-07 shock tower
on the rear, and for the front, I modified the M-05R rear graphite shock
tower for use on the front of the MO-7. In both cases, the shock tower's ball stud holes are about 2mm lower than the stock M-07's. Also the after market non-Tamiya 35 and 33 spur gears are a perfect fit. Although you don't have to split the chassis to work on the gears, You still have to disassemble the front of the car. The kit diff oil is not labeled but in the directions it indicates 100,000K. In any case, I used 30,000K. We will see how it runs next week.
Toyota Tom is offline
Old 06-26-2017, 05:09 PM
  #29297
Laguna Bozo's Avatar
Could you please explain what "after market non-Tamiya 35 and 33 spur gears" are?
Laguna Bozo is offline
Old 06-26-2017, 05:18 PM
  #29298
gigaplex's Avatar
Third party spur gears with different tooth counts - stock is 37. Commonly referred to as speed tuned gears.
gigaplex is online now
Old 06-26-2017, 06:18 PM
  #29299
R/C Tech Elite Member
monkeyracing's Avatar
The word you're looking for is "cheater" gears. I've got some nice delrin ones.
Build is going well. Bearings are filled with rendered hog fat out of the box. Sticky.
monkeyracing is offline
Old 06-26-2017, 06:22 PM
  #29300
Originally Posted by howardcano
380 brushless motors tend to have less torque but more RPM than 540 brushless, which is exactly what a mini needs.
So this why the TA-05 M-four is the most awesome mini ever...
torg is offline
Old 06-26-2017, 07:07 PM
  #29301
Someone pass me the ban-hammer.
Old 06-26-2017, 07:30 PM
  #29302
Thanks guys for the "cheater" info. i didn't know the M07 gears were the same as 3/5/6.
Old 06-26-2017, 07:48 PM
  #29303
gigaplex's Avatar
The spur is the same but the rest are different.
Laguna Bozo likes this.
Old 06-26-2017, 08:17 PM
  #29304
nova2015's Avatar
So if I've seen correctly elsewhere, a 20T pinion in the M07 gives same FDR as previous M-Chassis cars? I'm thinking of compatibility within the class with older cars.
nova2015 is offline
Old 06-26-2017, 08:38 PM
  #29305
Yep. Difference of 0.01% That's less than tire wear.
Old 06-27-2017, 11:10 AM
  #29306
eR1c's Avatar
so w/ a 24t pinion the M07 should be much faster than the best M05's ...shoot, ..my M07 is on order and will not have it built for my next race. ...I know a few guys are already running the M07's at my track for our next race .... double rats
eR1c is offline
Old 06-27-2017, 11:21 AM
  #29307
dmcguire's Avatar
Trader Rating: 38 (100%+)
I'm not sure if I missed it, but for TCS races, is there a pinion limit for the M07 to keep the playing field level with the M03 and M05?
eR1c and KA2AEV like this.
dmcguire is offline
Old 06-27-2017, 01:16 PM
  #29308
KA2AEV's Avatar
Here you can have mine, I have two of them and don't need both of them!
k_bojar likes this.
KA2AEV is offline
Old 06-27-2017, 03:22 PM
  #29309
I think it's safe to assume TCS will limit the pinion to 20t max. It's very easy to check on the M07. The little hatch covering the pinion just pops right off.
Weird thing from my build - tried using the heavy duty rear axles, like you'd use on any other mini. They caused a very slight binding for some reason. I tried removing shims, different bearings, different set of he axles, etc, but the only way to get smooth axles was to run the kit ones. The funny part is I can't see any diffrence between the old and new. Weird.
MORE: Motor fitment is a bit of a pig. Ended up filing a little bit to make room for wires for Hobbywing 13t style motor. I'm guessing at some point, someone will come up with a replacement stiffener bar for that spot that's bent differently. Fitting the rear suspension mounts requires minor juggling abilities. Oh, the thing with accessing the gearbox by undoing 8 screws also requires popping off upper links, steering links, swaybar link and dampers. I think you could do some work with just the screws out, but it's tricky.
Still, I like this car so far. Nice plastics, stiff chassis. Still pondering shorty battery attachment.
dmcguire and miha like this.
Old 06-28-2017, 06:38 AM
  #29310
What body are you guys going to use for your MO-7s?
TheOtherBill is offline
