Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-19-2017, 05:11 PM
  #29266
Laguna Bozo's Avatar
Well, if they continue to run a 24T pinion against 20T M03/5/6, of course the M07 will look good.
OVA and gigaplex like this.
Laguna Bozo is offline
Old 06-19-2017, 06:11 PM
  #29267
Core Creations's Avatar
Trader Rating: 110 (100%+)
Exactly, I would hope it would annihilate a M05 with a 20T! It certainly looks like it handles great. Maybe it was a somewhat weak motor?!
Core Creations is offline
Old 06-19-2017, 08:13 PM
  #29268
Where do you guys suggest to get Hop-Up parts for a MO-5V2? I am looking for a ball diff. TRF? shocks, and a few Alum. suspension bits. None of my local Hobby shops carry much in the way of Tamiya parts.
TheOtherBill is offline
Old 06-19-2017, 09:37 PM
  #29269
AngryRog's Avatar
Trader Rating: 20 (100%+)
TQ Racing carries most everything for the M05.
TheOtherBill likes this.
AngryRog is offline
Old 06-20-2017, 06:02 AM
  #29270
Thanks AngryRog...
Old 06-20-2017, 06:26 AM
  #29271
speedemall's Avatar
Trader Rating: 60 (100%+)
Would anyone here have use for this body?? Tamiya Alpine A110 fits the M05RA chassis. Maybe others? 210mm short wheelbase
speedemall is offline
Old 06-20-2017, 11:03 AM
  #29272
k_bojar's Avatar
Trader Rating: 30 (100%+)
Originally Posted by gigaplex
Yes, but also be aware that the v1 alloy motor plate will interfere with the steering rack without modification. I hear the plastic one works fine.
hmmmmmmmm
thanks, guess i'll be trying the plastic plate and finding a v2 aluminum one ASAP
k_bojar is offline
Old 06-21-2017, 02:37 PM
  #29273
AngryRog's Avatar
Pinion question... Mod 06P different than some of the newer release pinions with just an 06 reference?
AngryRog is offline
Old 06-21-2017, 04:14 PM
  #29274
I don' t think they are different, but stick to tamiya pinions to be on the safe side of tcs....
bertrandsv87 is offline
Old 06-22-2017, 11:36 AM
  #29275
k_bojar's Avatar
no, not true - any pinion can be used, the spur and idler gear HAS to be Tamiya
Any manufacturer’s radio equipment, servo saver, antenna pipe, antenna mount, pinion and spur gear, ball bearing, tire insert are allowed in all classes, unless exceptions are noted within class specific rules.
6. Tamiya internal gears only. Aftermarket idler and spur gears are not legal.
k_bojar is offline
Old 06-22-2017, 11:44 AM
  #29276
AngryRog's Avatar
I am referencing Tamiya only pinions here...
AngryRog is offline
Old 06-22-2017, 05:10 PM
  #29277
Any suggestion's for a ball diff. for a Mo-5 V2? Tamiya has two I believe, which would work better on Asphalt? I have been looking thru a lot of posts and haven't really gotten a answer. Thanks for any info.
Old 06-22-2017, 06:37 PM
  #29278
tony gray's Avatar
Just over 24 hours away. rc-mini's LIVE BUILD of an M07.
Facebook Live - 7.00 PM Sat 24th (AEST)
https://www.facebook.com/rcmini.net/
tony gray is offline
Old 06-22-2017, 07:04 PM
  #29279
R/C Tech Elite Member
monkeyracing's Avatar
Mine should be here by Monday! Just finished building a buggy. I'll need this weekend to clean up my bench.
monkeyracing is offline
Old 06-22-2017, 07:49 PM
  #29280
dmcguire's Avatar
Trader Rating: 38 (100%+)
I used to always be a huge fan of a ball diff on asphalt. Recently I tried a stock gear diff with 3 washers per side, a bunch of AW grease and set pretty darn tight. It was just as good as a ball diff in the fast corners, but would track way straighter and more predictable.
You'll get a bunch of opinions, but this setup made me a believer
dmcguire is offline
