Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-02-2017, 11:09 PM
  #29086
Trader Rating: 62 (100%+)
Originally Posted by monkeyracing
Cool. I've managed to order the sway bars, the aluminum suspension mounts, motor plate and titanium screw set. The copy so far says it comes with DCJs, right? Hopefully I won't need the heat sink.
Where did you order it?
sipaboy is offline
Old 05-03-2017, 09:17 AM
  #29087
R/C Tech Elite Member
monkeyracing's Avatar
1999.co.jp but they're not taking orders at the moment.
monkeyracing is offline
Old 05-05-2017, 05:15 AM
  #29088
gigaplex's Avatar
I received my Yeah Racing shock package the other day, and while trying to match spring rates from the Yeah pack to my Tamiya springs, I noticed my Tamiya ones are a lot softer. The super-soft Yeah springs felt harder than my black/blue Tamiya hard springs. I've got the short black springs from the 42168 short touring spring pack, which appear to match the springs that come with the 42291 big bore shocks and the ones that come with the 84424 M05 v2 R kit (I purchased all 3 of those).
I tried measuring the spring rates using a scale and calipers and here are the numbers I came up with:
Tamiya Short springs:
Black/Red: 6.51lb
Black/Yellow: 7.66lb
Black/Blue: 8.60lb
Box stock long Tamiya silver spring: 6.93lb
Yeah Racing springs:
Red super-soft: 14.68lb
Yellow medium: 17.83lb
Blue soft: 21.26lb (I think their labelling switched the blue and yellow around by mistake)
White hard: 23.71lb
No colour super-hard: 31.64lb
AE TC3 springs (for comparison to check if my method was valid):
Blue 17.0: 17.68lb
Gold 19.5: 19.54lb
Red 22.0: 23.76lb
I didn't realise how soft these mini springs were. Has anyone else done similar measurements to compare?
gigaplex is offline
Old 05-05-2017, 10:23 PM
  #29089
Pulled this body out of storage
sipaboy is offline
Old 05-06-2017, 11:33 PM
  #29090
HLJ also has it. Search for M-07.
jjjheimer is offline
Old 05-07-2017, 10:07 AM
  #29091
shmit 1's Avatar
Have your ordered through them before. I saw this website about a week ago. Website has alot of bad reviews.
shmit 1 is offline
Old 05-07-2017, 10:43 AM
  #29092
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
I just picked up the Sky RC corner weight system in hopes of maximizing the performance of my M05 chassis.
Check out the RCTech thread here:
Corner Weight System
I am currently running a Tamiya M05. I already knew that the weight would be biased to the front left being a fwd car and the motor being mounted on the left. I would like to shift a little of that weight to the right rear and ultimately better balance the left & right weight distribution.
Any input would be appreciated.
Rich Panganiban is offline
Old 05-07-2017, 02:24 PM
  #29093
Yeah, I've been ordering from them since the late 90s.. probably have spent about $10k CDN with them over the years, buying mostly Gundam kits and plastic models. I usually pick EMS shipping.
Old 05-08-2017, 01:18 AM
  #29094
marcos graveyar's Avatar
Here is a chassis I overhauled for one of the more senior members of my club.
We still run NiMh cells so cars usually run 1400-1500g, we dont have a minimum weight limit
marcos graveyar is offline
Old 05-08-2017, 07:21 AM
  #29095
Wow...that looks great! Any tips or suggestions on how to balance a Mini?
Old 05-08-2017, 07:39 AM
  #29096
Why are you running the bullet connectors? Tamiya plugs? I'd expect someone ~that~ deep down the tuning path would have addressed resistance. I also see you've chosen to go without the roll cage.
Tamiya sells a balance plate to add weight to the non motor side. You can also potentially mount both the reciever and ESC on the same side to help ballance.
Nerobro is offline
Old 05-08-2017, 08:16 AM
  #29097
Looks like about 10 grams difference on each side. Maybe led weights?
sipaboy is offline
Old 05-08-2017, 09:07 AM
  #29098
howardcano's Avatar
Trader Rating: 37 (100%+)
I don't know if it's the case for MarCos, but many classes using handout motors require the stock connectors to remain in place.
howardcano is offline
Old 05-08-2017, 01:49 PM
  #29099
32819toon's Avatar
Hi
I'm having problems with the steering servo moving on my son's M03. I think the parts must have worn over time. There used to be alloy servo mounts available, but I can't see any for sale anywhere, even on auction sites. Can anyone suggest a source for them ?
32819toon is offline
Old 05-08-2017, 04:41 PM
  #29100
Originally Posted by 32819toon
Hi
These work well and they're CHEAP! Alloy servo mount for tamiya M03 WR02 TL01 WT01 wild willy 2 twin detonator GF01 | eBay
