Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-10-2015, 01:21 PM
  #26041
sakadachi's Avatar
Originally Posted by monkeyracing
If you're in an actual race and you're a contender, probably. I'm a crap racer and I can tell a good servo from a really[ good servo.
Yeah, I suppose. I should give it a try and see if I notice anything... why not, right?
Originally Posted by howardcano
That could be, if they are talking about the acceptable frame rate, which is normally much higher for a digital servo than an analog servo.
Or they could be talking about servo latency-- after all, the servo's microprocessor needs to measure the incoming pulse from the receiver, do some math, then drive the motor appropriately. That all takes time!
Hi Howard, I actually thought about asking you for your input when I questioned earlier. Thanks for the insight. So the signal coming out of the R614FS and R614FFE is analog? TX/RX is digital, then D/A out the RX and then back A/D going into the servo? I suppose in this case, latency can be a concern. For the most part, I am using a fast TX/RX combo so if there is latency, then it would be at the servo.. at the fast 60degree swing I am not sure if the speed of the servo's motor is the culprit or the conversion itself..
sakadachi is offline
Old 11-10-2015, 01:26 PM
  #26042
sakadachi's Avatar
Actually the RX and servo are probably digitally connected but the D/A to the servo motor is where the latency can differ..
I would need to hook up the servo's next to each other and compare response times.
Old 11-10-2015, 01:37 PM
  #26043
axle182's Avatar
Trader Rating: 18 (100%+)
Originally Posted by CSeils
I think this has been asked before, but I can not locate the suggested fix.
While racing on carpet, I have an issue with the rear end of my M05 braking loose at the end of the straightaway going into a right hand turn sweeper. Would reducing the droop improve handling? Or would spring, oil, camber etc... correct this issue?
Rear -
S grip tires
Blue springs
50wt oil
Yellow roll bar
-3 camber
1.5 toe in
Front
S grips
Yellow spring
40wt oil
-2.5 camber
.5 toe out
Any help would be appreciated.
I got confused reading the setup as you listed the rear first lol. I need more info, what diff, how is it setup? What droop do you currently have? I would guess that a lot of roll could be why your loosing the back end. On carpet, you shouldn't have a problem with S grips on the back, unless the car is lifting off the tires. This below helps cement the back end, while making the car turn hard in the corners.
Give this a try -
Diff - 3 racing gear diff, 500k oil
Front -
S grips - Full sauce
Red spring
35wt oil 3 hole piston
-1 camber
.5 toe out
.5mm droop
Rear -
S grip tires - Full Sauce
Yellow or white springs
Hard roll bar
-2 to -2.5 camber You can go to -3 but start lower and find the sweet spot for the track
1.5 toe in
1mm droop
I run very similar setup to this, until the car starts to lift when I really throw it into a corner. I then ad a very small bead of CA, right at the outside edge of the tread on the front tires only. You may find the car will push now, but it should come back (try more camber if its still pushing) HTH
axle182 is offline
Old 11-10-2015, 03:44 PM
  #26044
KA2AEV's Avatar
Cseils
What exactly do you mean by your rear is breaking loose?
Is the car spinning out, is it turning over etc...???
KA2AEV is offline
Old 11-10-2015, 04:14 PM
  #26045
sakadachi's Avatar
I think in real-car lingo, he means the rear is stepping out when he lets off the throttle before the turn.
Old 11-10-2015, 04:54 PM
  #26046
CSeils's Avatar
Trader Rating: 54 (100%+)
Originally Posted by KA2AEV
Cseils
I am at full throttle on the straight which leads to a medium right hand high speed turn which leads into the sweeper. The rear end loses traction half way through the turn. I am usually able to correct it before going all of the way around.
Attached Thumbnails Tamiya mini cooper-screen-shot-2015-11-10-6.50.46-pm.png
CSeils is offline
Old 11-10-2015, 05:02 PM
  #26047
CSeils's Avatar
Usually steps out on throttle through the turn..
CSeils is offline
Old 11-10-2015, 05:12 PM
  #26048
sakadachi's Avatar
True, but you get the point... since especially difficult to do on a FWD car.
Old 11-10-2015, 05:38 PM
  #26049
sakadachi's Avatar
Tamiya still hasn't released a Fall promo-code. Last year I probably bought 3-4 kits from them by now.
Old 11-10-2015, 06:44 PM
  #26050
(0000000000)'s Avatar
Sounds like you need to take away some front traction. I recommend super glue on the outside edge of the front tires.
(0000000000) is offline
Old 11-10-2015, 07:18 PM
  #26051
Try one step harder front springs.
mariob62 is offline
Old 11-10-2015, 07:35 PM
  #26052
CSeils's Avatar
Did it
CSeils is offline
Old 11-10-2015, 07:39 PM
  #26053
CSeils's Avatar
I'm thinking the droop in the rear might be the issue. I checked the rear and I had a lot more there then I thought. I have 3mm droop in the rear, what do you run?
CSeils is offline
Old 11-11-2015, 08:00 AM
  #26054
My droop was: 1 o-ring in the front shocks, no o-rings in the back shocks.
I just got back from a 3 day race, and my setup was similar to axle's. Soft in the front, hard in the back.
I ran 2 different sets of front tires. One set has CA just on the edge of the outter tread. The other had CA on the entire outter tread. By the time the mains were up, there was so much traction that it was necessary for me to run the tires with CA on the entire outter tread.
Old 11-11-2015, 08:39 AM
  #26055
KA2AEV's Avatar
I'm guessing this is a carpet surface?
Do you sauce your tires, since you already did the ca on your front treads...
If you do, to what extent?
KA2AEV is offline
