Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-03-2015, 01:21 PM
  #25996
sakadachi's Avatar
I suppose if those were Tamiya fanboys, I would've expected them to use the CC01 diff lock piece instead of bunching up bevels on one side generating unbalanced vibrations..
And Tamiya... come on now, do a double-deck CF TRF m-chassis! Enough with these plasticatry
(okay making up words now)
sakadachi is offline
Old 11-03-2015, 01:48 PM
  #25997
+1
cheapskate.brok is offline
Old 11-03-2015, 08:46 PM
  #25998
sakadachi's Avatar
So I worked on the TOP SabreFD gear diff tonight (also fits M05/M06) and found that the revised clear o-rings (PP-GDRS02) for the TOP's S4 actually fits in the outdrive sides of the gear diff housing. TOP mentioned they don't fit and was working on a fix.
ANYWAY, since they do fit, I added one shim on the leaking side, new clear revised o-rings, and GreenSlime on both sides. I only had time to do one run, but no leaks.
Old 11-04-2015, 03:35 AM
  #25999
(0000000000)'s Avatar
Dont you already have a ta05m four? LoL
(0000000000) is offline
Old 11-04-2015, 05:29 AM
  #26000
sakadachi's Avatar
I do and it's a great little car. but I was hoping a 540 size motor standard.
Old 11-04-2015, 08:42 AM
  #26001
R/C Tech Elite Member
monkeyracing's Avatar
There are enough companies doing mini TCs already, and quite cheaply, too. No need for Tamiya to jump in.
monkeyracing is offline
Old 11-04-2015, 09:46 AM
  #26002
sakadachi's Avatar
Shaft driven ones I don't really care for unless the motor is placed horizontally to the chassis like the belt-drives. I'm not sure if such chassis is available for cheap.
Tamiya should jump in to finish the M-Four this time with a 540 motor and add a few more pieces to provide turnbuckle adjustments such as front camber, and droop, etc to make it a TRF trim. It's cool the way it is, but can do more with a few more adjustments.
And not think selling a RWD Miata body on a FF platform is okay. I expect more from a Japanese company.
Old 11-04-2015, 09:54 AM
  #26003
sakadachi's Avatar
BTW, for those that don't know, the front camber on the M-Four is a solid plastic rod, comes with 2 lengths in the kit.
Old 11-04-2015, 02:35 PM
  #26004
eR1c's Avatar
oh, should mention make sure that you completely remove and dry the diff' fluid before using the green slime/extra shim method. The green slime needs to be on dry surface housing to prevent diff fluid to penetrate ...but maybe that was already obvious? ...I say this out of experience ...had to do it 2x the first time I tried this as I didn't dry and clean everything properly.
eR1c is offline
Old 11-04-2015, 04:24 PM
  #26005
sakadachi's Avatar
No worries, eR1c. It's not the first time I'm doing gear diffs. Been using Greenslime for a while. Thanks though.
Old 11-04-2015, 05:58 PM
  #26006
Trader Rating: 118 (100%+)
+1
Chris Furman is offline
Old 11-05-2015, 07:39 AM
  #26007
eR1c's Avatar
Ah, right Sakadachi!
Well maybe it will help someone else reading this post ?
eR1c is offline
Old 11-05-2015, 08:43 AM
  #26008
axle182's Avatar
Trader Rating: 18 (100%+)
Wait, what? Someone else reads this thread? I had no idea! .
Good advice on making sure the diff halves are dry first.
That MX5 looks so good, although I doubt it will be the hot ticket body, at least on carpet. The bodies that seem to do the best are the hot hatches. Civic / Blitz Jazz / GTI etc all have a windscreen further forward, to put more weight higher over the nose to get the FWD tires to work harder. I tried to get the old HPI Miata body to work on a FWD, but I was consistently quicker with a Civic body, no matter the suspension changes.
If I decide to make life harder and run a M06 again, the new MX5 will be what Ill run
axle182 is offline
Old 11-05-2015, 11:28 AM
  #26009
sakadachi's Avatar
eR1c -
axle- I'm sure you already do, but have you tried putting weights inside your front bumper? I do this often on the FWD's... Even stack more on top of the bumper as needed to get the extra grip.
Old 11-05-2015, 11:59 AM
  #26010
axle182's Avatar
eR1c -
Yep started doing that many years ago, but i have gone away from it. I could notice a different feel in reaction of the car when its changing direction, when the weight is outside the wheelbase. I still have that bumper, and use it on some occasions but its a last resort when I have a bad set of front tires.
axle182 is offline
