Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 09-17-2015, 08:53 AM
  #25681
sakadachi's Avatar
Originally Posted by OSherman
My passport has been waiting/sitting in my sock-drawer for this occasion literally for the last 2 years..
Does the final take place at their Shizuoka facility? I've seen their building from the outside a few times during my many visits to Japan. I should check out their show room next time I'm down there.
http://www.tamiya.com/english/news/e...isit/visit.htm
Also want to visit TOPRacing's HQ in Tokyo.
sakadachi is offline
Old 09-17-2015, 09:26 AM
  #25682
eR1c's Avatar
-Oh, Man, I would love to go there!
Maybe I can convince the wife that our next vacation should be to Japan?!
eR1c is offline
Old 09-17-2015, 09:28 AM
  #25683
eR1c's Avatar
I got the sensor cable replaced on the Vulcan motor. Replaced the GTB3 to Hobbywing JustStock as the GTB3 was kind of huge for the chassis and heavy.
I'm not sure how much cleaner I can make the wiring on this chassis unless I start cutting the servo cables.
http://www.rctech.net/forum/members/...-v2-latest.jpg
-is that an HPI Cup Racer rear body mount/brace I see on your Tamiya M car?
eR1c is offline
Old 09-17-2015, 09:29 AM
  #25684
eR1c's Avatar
-guess you can't copy links inside of quotes? ...anyway, here is your link
eR1c is offline
Old 09-17-2015, 09:53 AM
  #25685
sakadachi's Avatar
That is, eR1c good eyes! I tend to use different brand parts on different chassis often.
And yeah, Japan is an awesome place to visit for sure.
Old 09-17-2015, 10:14 AM
  #25686
OSherman's Avatar
i vaguely recall some mention or documentation about "Twin Messe in Shizouka"... is where the event will be held.
i could be mistaken
its all still a blurry cloudy haze... ive been focusing on readying prep my car.
OSherman is offline
Old 09-17-2015, 11:20 AM
  #25687
eR1c's Avatar
Sweet, -what's my prize?!
eR1c is offline
Old 09-17-2015, 11:34 AM
  #25688
IndyRC_Racer's Avatar
I've never had much success building the plastic body mini shocks. No matter what weight oil I use, the shocks feel like they have very light weight oil in. Another racer suggested that when you remove the pistons from the parts tree that it is easy to remove too much material and effectively have a piston with a larger "hole" than needed. Basically instead of having a circle around the edge of the piston you now have a flat spot that will act as an additional piston hole.
Anyone else ever run into this issue and if so what were your solutions for this problem?
IndyRC_Racer is offline
Old 09-17-2015, 11:49 AM
  #25689
OSherman's Avatar
yes
but i wouldn't necessarily call it a 'problem'..
i used the BigBore shocks on my Nats winning car... previous to that i used the 'plastic shock' pistons in the regular TRF dampers to dial in my setup.. When switching over to the BigBore i chose an oil combination that felt very similar... yes, a SOFT setup...
OSherman is offline
Old 09-17-2015, 02:02 PM
  #25690
sakadachi's Avatar
I use the single hole and white Tamiya oil. This damper actually works pretty good with a soft setup. On my trucks that use the CVA dampers, I have some pistons I got from another brand (I mix brands often) which has the small holes like the ones in the TRF dampers. I use #400 oil in those. I like to use soft-ish springs and higher damp rate in my trucks as the tires are like balloons already, I want them to stick.
yes
Wow, you know, this am I was thinking about doing EXACTLY THAT tonight because my V2 is seriously running like crap since the 54000 damper swap. It's running the softest Tamiya damper oil but it is still a frikken plow basically just goes straight with moderate amounts of throttle coming out of a turn. It didn't do this before while I had the clear CVA factory dampers. Thanks for confirming! I will definitely report back.
Old 09-17-2015, 05:25 PM
  #25691
F N CUDA's Avatar
Trader Rating: 34 (100%+)
That's awesome!
I never thought of doing that when I came in second a couple times before finally gitt'n her done.
F N CUDA is offline
Old 09-17-2015, 08:53 PM
  #25692
sakadachi's Avatar
I swapped my 54000 dampers to the junky black pistons 3 holes for front, 2 holes for rear, Tamiya white (clear) damper oil. Definitely improved damping vs the white pistons on my V2. Thanks Osherman.
Old 09-19-2015, 10:31 AM
  #25693
sakadachi's Avatar
Decided to run the Vulcan 21.5 on my M03. Much better match for the motor.
I should be getting my Thunderpower 21.5 early next week, so will run that on my V2.
I'm going to take the chassis apart today and tighten the diff. Felt kind of loose which is also probably contributing the plowing.
http://www.rctech.net/forum/members/...-brushless.jpg
Old 09-19-2015, 10:42 AM
  #25694
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
yes
ygpm..Thanks
OVA is offline
Old 09-19-2015, 10:24 PM
  #25695
R/C Tech Elite Member
monkeyracing's Avatar
I've decided it's time to out-do myself and try to find a part so rare, it makes my M04 sway bar set appear annoyingly normal.
I'm looking for a Xevo Chariot (M03 conversion) droop limiter set. If you know where to find one, let me know. Remember, I'm cheap, or poor. Whatever gets the job done.
monkeyracing is offline
