Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-16-2015, 10:14 AM
  #25306
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by Vrooom
I purchased big bores shocks (tamiya #42291), it doesnt have ball connectors. What size do I need? 4.8mm or 5mm ?
5mm.
monkeyracing is offline
Old 08-16-2015, 02:23 PM
  #25307
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by bertrandsv87
Good luck on making the Amain Greg, I just want to be able to have fun ...lol.... Way too many $250 21.5t motors in the Amain...lol....
Actually, only $94.99.
Greg Sharpe is offline
Old 08-16-2015, 05:36 PM
  #25308
Wow.... That's still up there.....
bertrandsv87 is offline
Old 08-16-2015, 06:24 PM
  #25309
Yeah, but any BL motor for any class these days is going to cost a few bucks. For me, I had to buy a new motor anyway having been out of the game for a few years, so I don't mind how much it costs.
As for my odd outdrive issue, turns out the black o-ring that WAS in there got chewed up and only part of it was still buried in the outdrive. Not sure how that happened, but I put a new o-ring back in there and naturally there is no more excessive play. I'll pay more attention to it from now on.
Old 08-17-2015, 05:41 AM
  #25310
Originally Posted by howardcano
That should be plenty.
Another good choice would be the Spektrum A5040. It's spec'ed at 66 oz-in, and is reasonably affordable. I use these in my 17.5 TC cars, and they work fine.
I actually have one of those, I also saw the KO RSx mini servo (Torque: 104.15 oz-in @ 6.0V (7.5kg-cm) I installed the savox 1250 but I may get the KO too.
disaac is offline
Old 08-17-2015, 08:50 AM
  #25311
sakadachi's Avatar
Not bad with 0.13sec.
Savox 1250 micro servo is below... if you guys are okay with the 63.9oz, I'd do this one instead:
Speed(@6.0V sec/60): .11
Torque(@6.0V oz-in): 63.9
But I wonder if this servo also has the bottoming out of servo horn issue..?
sakadachi is offline
Old 08-17-2015, 09:25 AM
  #25312
howardcano's Avatar
Trader Rating: 37 (100%+)
One needs to be careful with anything called a "micro" servo. Many have output shafts that don't match any available servo savers. Maybe someone can let us know if, indeed, this is true for the Savox 1250.
howardcano is offline
Old 08-17-2015, 09:37 AM
  #25313
axle182's Avatar
Trader Rating: 18 (100%+)
I have used the futaba mini servos (same ones used in 12th scale) with great success in the 03 and 05. Splines are the same as a std futaba ones, and it saves a lil weight.
axle182 is offline
Old 08-17-2015, 09:42 AM
  #25314
OSherman's Avatar
If it is the Tamiya Black o-rings.... They are very hard and dont hold/retain much oil if any.. over time they dry up, crack, get brittle.. Then you can guess the rest..
OSherman is offline
Old 08-17-2015, 11:30 AM
  #25315
sakadachi's Avatar
Thanks for looking out for me, howard.
I think I'm going to stick with standard sized and the low profile servo's.
Old 08-17-2015, 11:58 AM
  #25316
eR1c's Avatar
I've always liked Futaba servos, ...I have the S9551 low profile servo in my Mini and am very happy with it.
eR1c is offline
Old 08-17-2015, 12:07 PM
  #25317
howardcano's Avatar
I learned the hard way, when I was trying to shave some weight in my 1/12 scale. I ended up with a couple of micro servos that work great, but have these skinny little output shafts that only fit the horns that came with the servo.
There was a post just a little while ago in the 1/12 scale thread that showed the Savox 1250 with a servo saver on it, so it seems your recommendation was good!
Old 08-17-2015, 12:24 PM
  #25318
sakadachi's Avatar
I see. Actually I didn't recommend the 1250, it was disaac. I personally don't run micro servo's on my cars as weight is not that critical.
I do feel that my M03 would benefit though if I run even less weight than the low profile Savox I installed on there a few weeks ago. Thing is so top heavy.
Old 08-17-2015, 12:31 PM
  #25319
sakadachi's Avatar
S9551 has good specs, $20-25 more vs Savox SC1251MG and Spektrum S6070.
If I'm not running the Tamiya High Torque Servo Saver, my go to servo is the S6070 and run Kimbroughs.
The SC1251MG uses the same Futaba 25spline, so I may end up using more Savox down the road for Tamiya cars that run Tamiya High Torque Servo Savers. I'm currently running one in my M03 and I like it.
For some reason Spektrum's 23 spline is SUPER TIGHT to put on when I use Tamiya servo savers. This is why I only use Kimbroughs with Spektrum servo's.
BTW, has anyone tried this servo? Power HD 1207TG (half the price of the Savox)
Torque(6.0V): 8.0 kg-cm (111.10 oz/in)
Speed: 0.10 sec (4.8V) │ 0.09 sec (6.0V)
48g
Old 08-17-2015, 01:03 PM
  #25320
These Servos are still too heavy at 48gram.... Blue bird Servos weigh 32grams, and are analog.... It saves the cost of a new radio, Rx, etc.... That's almost $600 savings right there.... I think mini racing has become too expensive.... There are $1300 minis racing tcs... That's absurd.....
M03: $149.99...m05:$200
fm radio: $100... 2.4ghz:$650.
Brushed: free($50 red dot)... Untuned Brushless:$240...(tuned:$450)
Tires:$50 more or less...
