Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-12-2015, 10:02 AM
  #25216
hprt's Avatar
Originally Posted by sakadachi
The SportTuned has less torque but higher RPM...
I think you will find that the Tamiya Sport Tuned (black can) actually has more torque and higher rpm for a given input voltage than a Johnson or Mabuchi 540 silver can.
hprt is offline
Old 08-12-2015, 10:03 AM
  #25217
eR1c's Avatar
Gears typically only die when you impact them - just don't hit stuff and the gears will last a while.
I've actually never seen any wear on my internal gears ...maybe because I take the chassis apart and clean after about every 2 or 3 race days to get any grit out. In general the plastic gears actually work very well and are pretty robust. I wouldn't worry about this, if your gears are getting chewed up or worn then you have something else going on that would have to be sorted out.
As for the motor, I'd go w/ Sakadachi's recommendation of the tamiya sport tuned motor ...I believe it will just plug into the two wires from that stock tamiya ESC ...you wouldn't have to solder anything (if I am not mistaken).
eR1c is offline
Old 08-12-2015, 10:38 AM
  #25218
sakadachi's Avatar
Sounds good, more the better! It just feels weaker at lower RPM as the overall RPM is noticeably higher vs the stock can, and noticeably different from their TorqueTuned motor I run on my GF01's.
eR1c - Yes, the black can is PNP (plug and play). It's a great motor for bashing imo.
I wish I can say the same on my idler gear. Must be the braking I do.
sakadachi is offline
Old 08-12-2015, 10:44 AM
  #25219
eR1c's Avatar
possibly, ...i've never used the brakes!
eR1c is offline
Old 08-12-2015, 10:52 AM
  #25220
sakadachi's Avatar
The new rubber runners I installed this Spring has tremendously improved traction so I do not need to brake as hard as before.
In fact, I got the runners in April, I haven't had to change out the gears yet on any of my m-chassis.
Old 08-12-2015, 10:58 AM
  #25221
Originally Posted by howardcano
Fewer turns = More torque, higher free-running RPM (Kv rating).
This is assuming the armature or stator is at or near 100% copper (wire) fill.
This motor Is rated at 30000 rpm and 167 watts and 16T
M05 newbie is offline
Old 08-12-2015, 10:59 AM
  #25222
sakadachi's Avatar
deleted..
Old 08-12-2015, 11:19 AM
  #25223
KA2AEV's Avatar
Newbie YGPM'd
KA2AEV is offline
Old 08-12-2015, 11:20 AM
  #25224
KA2AEV's Avatar
Brakes????
What is that???
KA2AEV is offline
Old 08-12-2015, 11:22 AM
  #25225
Golddust's Avatar
Originally Posted by KA2AEV
Brakes????
What is that???
Thats the thing you use to slow the car down instead of plowing into the wall as I pass you to beat you!
Golddust is offline
Old 08-12-2015, 11:25 AM
  #25226
KA2AEV's Avatar
Oh Never Mind
I should know better!!!:
KA2AEV is offline
Old 08-12-2015, 11:29 AM
  #25227
howardcano's Avatar
Trader Rating: 37 (100%+)
Brakes????
What is that???
The car directly in front of yours.
howardcano is offline
Old 08-12-2015, 11:48 AM
  #25228
sakadachi's Avatar
Thanks, monkeyracing. I did some digging and the M04M uses the same 50736 b-parts and found a 1 degree toe-in for that car for $10 to use on my M03. Part is now ordered.
The M03 uses identical B4 parts left and right meaning it has zero toe-in.
I noticed the M03M has left and right designation for rear uprights so that chassis came with whatever toe-in from the factory.
It's been a while since my first two M03's I built back 16-17yrs ago so forgot all this.
Old 08-12-2015, 11:58 AM
  #25229
hprt's Avatar
My V2 has a lot of work to do.. Thought it was fast until I started messing with the Sabre.
you just have to work with the V2.
Mine was coming along nicely before it got parked for the summer - In its current state it is significantly quicker than my previous years' WCICS series-winning M05, and I believe (I haven't had the opportunity to run them back to back on the same track) even quicker than my M03r. It sure is much smoother and easier to drive fast.
hprt is offline
Old 08-12-2015, 12:10 PM
  #25230
What do u think about the 16t 167 watt 30000rpm motor? I just don't want to be disappointed and have to buy another one to go faster but i dont want to have to swap the esc either....defeats the purpose of a brushed motor. Eventually I'll get a brushless...probably next year. But with a gear diff and a quicker motor I think I should be happy enough for this year.
