Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-13-2015, 01:08 PM
  #24616
eR1c's Avatar
Yeah, I'm with Granpa on the bearings. The metal ones are my preference too.
You'd think bearings are just bearings, but the Tamiya' bearings (metal) are so much smoother.
I've been using nylon bearings ..I may have some metal sealed ones new at home ..will have to check. BUT, sounds like some more work on the Mini is in order.
thanks guys-
eR1c is offline
Old 07-13-2015, 01:12 PM
  #24617
Originally Posted by sakadachi
Unfortunately the servo splines and how they align to the servo prevents this. I can't remember the last time the horn perfectly lined up to my servo 90 degrees. So already the setup is not perfectly square. I don't prefer it, it's just the way it is and it is not a big deal as it can be compensated elsewhere (sub trim and EPA).
Apology is accepted and I don't plan on arguing with you either. It's been the 'I'm better than you because I race at a Tamiya track and you only play in your little toy track' attitude that I got me ticked off at times. I do envy that you are near Tamiya's track and I think that's great. But you're forgetting that I too have thousands of hours experience racing TC and M03's, maybe not TCS and while I may not be fully up to date with the current electronics due to my long hiatus, I do understand how RC cars and trucks work, how demanding racing is on your car, the driver, and even the driver's spouses.
My experience says that these minor imperfections is not something that will make or break your race especially when the goal is achieved another way. Plus, we're not talking about a huge mis-alignment in degrees here, well within the tolerance of the steering system. It's not a big deal.
But then I do agree a newbie may not know what is considered a 'big deal' and what is not. That area I need to be careful on my posts. Like me not gluing my tires on the inside lip on some of my tires. Experience tells me which tires will not grip well enough to come apart from the wheels in certain driving conditions, but a newbie may not know what that threshold is.
I can tell you've outgrown the level of advice I dispense-----like I said, it's for the newer guys and not the Pro's like you. No sarcasm meant in the Pro's comment, but for the level of your expertise.
The reason I say this is in Step 5 of the procedure I outlined for a relatively inexperienced guy, I say to adjust to 90 with the sub trim of the TX. I put some time and careful thought into that post and in essence you said it was bull shit and then didn't bother to read it. That's not fair and some "newbie" may decide based on your comment that don't bother cause you can fix it with the TX. That's misleading and careless.
If you don't read my advice, don't comment. If you do, read the whole thing. Let's try to help the guys who might read this stuff.
Granpa is offline
Old 07-13-2015, 01:23 PM
  #24618
thanks guys-
Nylon shield bearings are okay as long as you don't try to eliminate the grease. Here's the problem----the degreasers, at least those in my experience, cause the seals to swell and make them drag a bit. That's why the metal shielded bearings. You can clean those.
I keep some metal shield bearings, good ones like from Boca, for racing. The rest of the time I just use $1 ones from places like Avid and throw them out when they get rough. Those are nylon shielded
Granpa is offline
Old 07-13-2015, 01:47 PM
  #24619
axle182's Avatar
Trader Rating: 18 (100%+)
+1. This is why the incorrect information must be corrected. Sure there are ways to "take the easy way out" to do something, and when pressed for time we all have at one point or another. But unless the person asking for information requests the "cheapest and easiest way regardless of the end result", you cant continue to argue with the correct way to do things. Geometry PROVES that having the servo horn at 90 deg to the steering arm is the correct way to set your steering, due to equal steering throw left to right. This isn't an opinion. An opinion is "this works for me".
On bearings, I have always used the cheap metal bearings, removed the grease, and used a little Elf high speed oil. They last a decent time and aren't expensive to replace. I have 1 or 2 of each size in my RC box, to replace in an emergency.
Also spend time to ensure your not pinching the wheel/hub assembly when you attach the wheel. make sure you have at least one small shim between the hub and the bearing. Little things like that can make sure you have minimum friction on the rear wheels.
axle182 is offline
Old 07-13-2015, 03:02 PM
  #24620
tony gray's Avatar
20C is like old NiCd territory discharge rate (a weak one at that). You'll want something more like 60C and above if you want full power to your brushless.
Discharge rate is one of the key elements of providing consistent power to your motor. In a nutshell, higher is better as you have more headroom.
MYTH - BUSTED
from rc-mini.net several years ago...
There has been a lot of discussion lately regarding the C rating on batteries, and how the higher the C rating the more current the ESC and motor will use which is then mean to be a huge advantage on the track. People keep clamouring for the latest battery, sure that the extra 5C will give them an advantage… But will it?
This argument already has a serious flaw as it completely dismisses that fact that the speedies we are limited to using, have a 25A and 35A continuous current ratings, with burst ratings of 90A and 190A respectively. Which implies that the most current you could sustain through the speedies would be 25/35A. Straight away there's an issue there.
Looking at the most popular batteries at the recent Victorian State Titles:
Harris 3200 20C 20 * 3200 = 64000mA = 64A continuous
Team Orion 3200 Carbon 20C 20 * 3200 = 64000mA = 64A continuous
Peak Racing 3200 Carbon 20C 20 * 3200 = 64000mA = 64A continuous
Team Orion 3400 Carbon 25C 25 * 3400 = 85000mA = 85A continuous
Yeah Racing 3200 20C 20 * 3200 = 64000mA = 64A continuous
Looking at the speedies and the batteries we are using it's easy to see that the batteries are already capable of supplying more current then the speedies can handle continuously. Logic should then kick in and say that since everyone isn't thermalling, nor are the heatsinks on the speedies even getting warm after a 6 minute run, that we are not using anywhere near the current rating of the speedy. Even when running outside on the hottest February ever, when the temperature got to 46 degrees (this was during Black Saturday in Victoria) we ran the ESC for 1000 laps (Wodonga Mini Enduro) and although the heatsink was hot to the touch it was no where near thermalling.
Now just to try to see if what we believed was really true, we decided to make absolutely sure by actually monitoring the battery usage during actual races. Below is a table showing the results of 2 race meetings, the Victorian State Titles, and the Warm up race the weekend before.
As can be seen in the table below we have summarised the data from each run over the two race meetings, and we can see which pack was used for each run, plus the maximum amps recorded, the average amps used per run, maximum voltage, minimum voltage average voltage and the runtime.
Before we begin interpreting the data, some background on the races. The Warm up race was a race where I was trying to find a good setup for the car and was not really happy with anything that was happening. The car was handling really badly, and was very difficult to string consistent runs together. At the Vic Titles the car was great, easy to drive and just worked, the driver a couple of times left a bit to be desired - but overall I would consider it a good race meeting.
Looking at the peak amps data we can see the highest was in final 2 of the warmup race where the peak amps reached 42.3A. Looking at the graph below it can be seen that the 42.3A was only reached once, probably as a result of a coming together with another car on the track. The only other 2 peaks in the chart only reached 32/35A which is considerably lower, and more consistent with the remaining results
Analysing the rest of the results it would seem values of 28-35A would seem to be the expected peak current for the ESC/Motor system chosen as the control for our mini class. Looking a bit further, the average current draw is about 1/3rd that of the peak current which would mean the constant current draw from the battery would be a lot less then the peak current.
Breaking it down a bit further we can look at the graph below which shows the highlighted gray area representing a full lap of the track. We can see that most of the time the graph has short sharp peaks indicating the burst in current draw on acceleration, and then longer troughs where the acceleration has taken place, and speed is just being maintained. On a small tight track it would be that the average current draw could increase, but only marginally so.
From all this information what we can see is that the Mini with the Hobbywing ESC and 13T motor combo is drawing much less current then even the 20C batteries are able to easily continuously supply. Another interesting point is that there was no real significant difference between some packs that were nearly 2 years old, as opposed to some that were brand new. Yes, there are differences, but those differences could also be attributed to any number of factors anyway, not just age. And the differences are so small as to absolutely not represent any sort of significant, provable trend in any way. Thereby also effectively destroying the 'it's better to have new packs for a big event' myth as well.
So, what's the bottom line? Well, as Jamie and Adam are fond of saying on the tv – MYTH BUSTED. The whole contention that a higher C rating gives you more punch is complete rubbish. Yes, in a faster car with a lower turn motor it MAY make a difference, but in a control motor class such as Mini it makes no difference at all. There is simply no evidence to support it. At no stage does the amp draw even come close to the continuous rating of the lowest C rated battery (20C), so having a higher one will make no difference at all.
tony gray is offline
Old 07-13-2015, 03:18 PM
  #24621
sakadachi's Avatar
Hummmm? Wait, I never stated your post was BS. I never argued that your approach was wrong; I even encouraged that there is nothing better than a completely square and perfect setup, but my comment was is it really necessary to go that far when a servo horn doesn't even align perfectly from the getgo, and at the end of the day, the approach I posted works just as well?
That's when I asked about the nerdy scale.
I don't even get a reading on the nerdy scale according to monkeyracing..
sakadachi is offline
Old 07-13-2015, 03:29 PM
  #24622
eR1c's Avatar
...bearings,
Thanks for the helpful advice (Granpa, Sakadahi and Axle 182).
I have been using Nylon bearings and have been trying to clean them (blast with air, then regrease). Guess this is not good. Doh! Going to switch to metal sealed bearings. Also the advice about using shims ...I have not been doing that for my Mini ...but will try it out. This is super helpful info (why I love these boards)!
eR1c is offline
Old 07-13-2015, 03:43 PM
  #24623
sakadachi's Avatar
Originally Posted by tony gray
[The whole contention that a higher C rating gives you more punch is complete rubbish. Yes, in a faster car with a lower turn motor it MAY make a difference, but in a control motor class such as Mini it makes no difference at all. There is simply no evidence to support it. At no stage does the amp draw even come close to the continuous rating of the lowest C rated battery (20C), so having a higher one will make no difference at all.
Interesting find. Tell that to all the hobby shops that sell high discharge rate batteries of no good, huh?
(just in case: Tony, I am laughing at the stores with you, not at you. Thanks for the info!)
Old 07-13-2015, 03:47 PM
  #24624
sakadachi's Avatar
...bearings,
I've tried several different methods but it took a lot of motor spray and time to get it back to where a new one was. Even so, the balls wear anyway and was not worth my time.
The amount of spray I had to use did not economically make sense either, so I consider ball bearings a wear item like tires, and just replacing them.
Amazon has the nylon bearings going for like $10-11 for 10pcs.
A can of motorspray costs me about $10+ shipped. I rather just buy new bearings.
Old 07-13-2015, 03:59 PM
  #24625
sakadachi's Avatar
Since when is the setup I noted "incorrect"? That's how the owner's manual shows how to do it too, are you saying the owner's manual is also incorrect?
Old 07-13-2015, 04:00 PM
  #24626
sakadachi's Avatar
Everything sakadachi posts =
INCORRECT!
Old 07-13-2015, 04:25 PM
  #24627
eR1c's Avatar
guys, guys, guys...
hesitant to get involved, but just want to remind you all that we are grown men talking about toy cars. Let's take a deep breath and go easy on each other.
Not taking any sides here, but you all (including Sakadachi and Granpa) have provided me great advice that has been extremely helpful. Sometimes the info I've received has worked for me and sometimes not. Regardless it's all been helpful as it would have taken way longer to figure out on my own, nor am I sure I would have discovered various solutions or things to try. We are all here to help each other with what we know, believe to be true, and have discovered. Looking at the cars on our track, our top 3 driver's cars are setup differently yet they are all very close to each other in performance. I take that to believe there are different ways to get to the end result and various setups work for various drivers.
that's all I have to say, ...you guys are my friends even if I've never met you in person. Would hate for this to escalate further.
eR1c is offline
Old 07-13-2015, 04:28 PM
  #24628
R/C Tech Elite Member
monkeyracing's Avatar
Wow. Big letters.
Thanks for posting that again, Tony. I've got that somewhere in the archives from when i downloaded the entire site. Did you know you guys had 2500 photos on that thing?
monkeyracing is offline
Old 07-13-2015, 04:39 PM
  #24629
axle182's Avatar
Well Geometry is proof that your way is incorrect, as is the M chassis manual. For the servo horn to have the same effect on the steering linkage, left to right (IE move the steering linkage the same distance), you must start at 90 deg. If you don't, for the same rotation of the servo left to right, your steering linkage will NOT move the same. Yes the manual is incorrect. Read a TC manual, they put the horn on at an angel, precisely for this reason. The M chassis has the servo horn square to the servo for simplicity reasons. They also supply the kit with terrible tires. This doesn't mean you can argue that the kit tires are the best.
While I feel I know a lot about RC, I am always here to learn, and I have learnt so much from contributors like GP, Monkey, and Tony. Tony's website was the best mini site on the planet, and I learnt so many great things from it. I hope I have been able to give back too! Please stop taking these discussions personally, this isn't Sakadachi's M chassis thread, this is a public thread.
axle182 is offline
Old 07-13-2015, 04:44 PM
  #24630
Here's my point. Since you didn't really read my post, that's what I said. I said to use the the sub trim to adjust to a perfect 90. The implication was that most servo horns,as you put it, won't come to 90 just use the sub trim. What I wanted the modeler to do was to spend a little time with the servo saver insert and try to get it as close to 90 as possible so that he didn't use much more than 10 points of sub trim.
Sure you can adjust the turning radius with end point adjustments and so on. you can use all the short cuts and make the car run straight, turn the same amount etc, but you still wind up with a car that's pure shitze.
Like I said, my advice is for the newer guy and not for the Pro's. If what I posted will give the guy a "square" car, leave it alone. All you do with short cut advice is to confuse the issue and encourage sloppy habits. Pro's like you know what you can short cut and what you probably shouldn't.
This is a personal preference, but I save the shortcut radio adjustments for temporary things like steering and throttle trim. I don't get off the drivers stand for example and adjust the linkages-----I'll use radio trims, but then I'll check the car over physically later. If it's more than a few points, I get off the stand, take off the body and go over the car. I know my car is square, so I'll know what to check and so will anyone who has taken the time to build a square car. This is why you won't see short cuts in my advice.
Now, I don't think I'm better than anyone cause I run at the Tamiya track. I usually post that as a disclaimer cause if the guy I'm posting to is running on a postage stamp size indoor carpet track, what I'm saying may not be valid for him. That's all period.
Granpa is offline
