Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-08-2015, 11:08 PM
  #24451
Last week did a full shock rebuild on my M05 swift body...pulled the dampers out, refilled with oil, hard springs up front, medium on rear, put new shimizu tyres on, hard up front medium on rear.
Hit the track and as soon as I turn a corner the car spins 180 on itself. Tried all kinds of shock adjustments including winding them fully down to eliminate as much play as possible. Same problem. Put hard springs on the rear as well as front, problem started to subside a little but too much turn it still spun.
Then went back to my old rear tyres (also medium) and the problem pretty much went away, except it was grip rolling. I adjusted the Tx settings and swapped grip rolling for slow cornering. I'm now wondering if the medium tyres really are medium...
Can't figure out what else might be the problem and have another meet tonight on the same setup, so expecting more of the same tonight...Finicky things lol.
Depth_Charge is offline
Old 07-08-2015, 11:14 PM
  #24452
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by M05 newbie
Ebay has em for about 20 a set roughly.
The only good thing about those wheels is that they stopped making them. Try somewhere like RCMart and buy 8 wheels for under $10. Don't buy into Tamiya's "reinforced" parts, or at least not the gears and wheels.
monkeyracing is offline
Old 07-09-2015, 01:06 AM
  #24453
tony gray's Avatar
Jim is 150% correct. (All hail the Monkey!)
The Tamiya 'reinforced' bits are designed only to reinforce the feeling of fullness in Tamiyas bank account.
The parts themselves (especially the wheels as Bob has already pointed out) are complete and utter shite.
tony gray is offline
Old 07-09-2015, 05:29 AM
  #24454
sakadachi's Avatar
monkeyracing- I was going to order the reinforced gears next time around, but those are no good?
Why? Do they crack or..
sakadachi is offline
Old 07-09-2015, 06:32 AM
  #24455
Ummm I just did so I kind of hope they are good :s
M05 newbie is offline
Old 07-09-2015, 06:47 AM
  #24456
sakadachi's Avatar
Maybe noisy? My Sabre's gear set appears to have reinforced fibers may be carbon. They are noisy.
Old 07-09-2015, 08:27 AM
  #24457
Pit Shimizu make a 60D and a 55D tire. Tamiya alone makes at least 4 different spring sets for the Mini. What kind of track?????? Shocks were rebuilt, but what kind and how????? Also, this or a similar question has been answered many times in the last month.
I'm guessing PS 60D tires, Tamiya Mini springs, outdoor asphalt track. Also #456 and 454 PS tires with the insert that came with the tire. The only time I had a problem like yours with Pit Shimizu tires is when I got them mixed up and put the hards, #456, on the rear and the med, #454, on the fronts. Also the foam inserts that come with the tire are too soft. If you got the tires mixed up there is no way to distinguish which is which-----I know from embarrassing experience. Unless you can find a durometer.
You could run a set of PS #452 in the rear and use your present tires in front if you got them mixed up. I generally use the 452 in the rear unless temperatures are in the 100+ range. The 454 is usually too hard of a cpd for a rear tire.
Grip rolling is, contrary to popular belief, not fixed by going to a harder spring. Softer springing, especially in front, is more helpful.
Granpa is offline
  #24458
I just hope they last. I ordered 2 sets lol. I've heard so many different things on gears.
Monkey....what do u use for a good gear that will last?
Old 07-09-2015, 08:29 AM
  #24459
Smile
Yup...answered to me lol. Check the pages 1610 and up....I beleive Granpa gave some good advice on tires for me from about those pages in this thread. Maybe before but around there for sure
Old 07-09-2015, 09:10 AM
  #24460
axle182's Avatar
Trader Rating: 18 (100%+)
For me, the stock gears last a really long long time. For the price, I keep a set of new ones in stock, but there shouldn't be any reason to get different gears. The reinforced gear set was a gimmick Tamiya put out. just like the reinforced wheels, the reinforced TC parts, anything reinforced. Its crap. Oh, and stay away from the carbon shafts...... I also use the 3 racing oil gear diff, and a Tamiya hardened 20t pinion. A little silicon spray in there, and its relatively quiet (for m chassis standards) and hasn't been touched or looked at in a year or two.
The Sabre etc could be using std plastic gears, only in black.
axle182 is offline
Old 07-09-2015, 09:15 AM
  #24461
I installed a set in my M05 about 2yrs ago, maybe a little less or maybe a little more than. Still there, working fine. Can't say that they are better or worse than the standard set. The standard gears last a long time also. Just don't hit anything with the power on and they should last nearly forever.
Granpa is offline
Old 07-09-2015, 09:31 AM
  #24462
Well I already ordered them so we will see. Info aquired lol. Now axle...the gear oil diff. What do u recommend for a set up for that. I think I'm leaning towards that over a ball diff. What should I lo out for as far as install..oil weight...bearing/bushing setup etc...
Old 07-09-2015, 09:47 AM
  #24463
axle182's Avatar
If you are running on a tight carpet track, put 500,000wt in it. If running outdoors, id start with 250,000wt or 200,000wt. You should be in the ball park if you use these oil weights. Build the diff as instructed, no special ways to build it. But make sure you pick up a set of the bearings you need, to fit it in your 05. I seriously love these diffs, IMHO these are the best diff for a M chassis bare none. Now if your running an 03, your out of luck as these wont fit without modifications to the chassis halves.
This is the diff here
Note the mention of the required bearings.....
axle182 is offline
Old 07-09-2015, 10:23 AM
  #24464
Reinforced gears aren't any better, just noisier and they don't fit the m03 very well. They're not terrible - just not better than stock. Regular gears and a good pinion should last ages. The set pictured have a whole season on them. Practice, racing, crashing...
Old 07-09-2015, 10:57 AM
  #24465
.... Oh, and stay away from the carbon shafts......
Axle, can you elaborate on the carbon shaft issue, please? I've been using them for about 6 months now and haven't noticed any problems, but is there something specific I should be looking for, or ...?
V-point is offline
