Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-05-2015, 03:51 PM
  #24346
[QUOTE=Granpa;14081889]
Originally Posted by 32819toon
To get better turn in the obvious things to do are to increase weight or weight transfer to the front wheels. The other is to use tires with a higher coefficient of friction-----stickier tires. 454s are what I usually use, but traction roll can become a problem unless you add glue to the side walls. While both tires are important, the outside front wheel is the oe that's most important.
Let's go through the things you can do to your set up one by one. The first is the one you mentioned which is to go to a softer spring. The second is to lower the front ride height in relation to the front. The 3rd is to increase the length of the rear shocks. These are the obvious ones.
There are some others, but I don't know what option parts you are using. The stock hex drives are 6mm, you could use the option 4 or 5mm alloy hexes----expensive, but nice parts to have. If you have the option shock towers, try the second hole on the front and play with the shock angles in the rear. If you do't have the rear shock tower you could try a spring one step softer. If you have the roll bar on the rear, you could go to the softer one or remove it. You could also bump your ride height up a mm or two all around. As you can tell these are to let the car roll a bit more so you'll have a little more lateral weight shift, which will load the outside front wheel.
The one most overlooked by less experienced racers is the toe out and also the most disputed. I'll give you my take on it and you can try both ways and come to your own conclusions. If you want better turn in, I reduce the amount of toe out. Often I use almost zero. Guys with a TC background think you add or increase toe out. I think this makes the car sluggish. This is also the one that affects the turn in the most.
I recently posted a tip on the way I check toe out cause, for me, it's very difficult to check by eyeballing it while the car is resting on all 4 wheels. I turn the car on it's side, then put the front tire resting on the table, flat against the table. Then check the angle of the upper wheel. This will in effect double the angle you're judging, thus making it much easier to gauge your toe out.
Hope this helps and I don't mean to sound like your high school math teacher.
Just to add Granpa... the metal toe links and steering bar you suggested to me that make adjusting the toe easier...ordered and can't wait to install!!
M05 newbie is offline
Old 07-05-2015, 04:46 PM
  #24347
sakadachi's Avatar
For me, I use toe-out mostly to stabilize tracking. These M03's and M05's (with the exception of the V2 behaving better than the others) have a hard time tracking straight while going on/off throttle for me unless I give them ample toe-out.
I don't know which chassis we're talking about, but the M03 and M05 both have fast turn-in in factory form as long as the tires are gripping. I would practice the off-throttle timing on top of the tips Granpa posted about softening the front suspension and lowering the front ride height, giving more rake. If you are using stiff diff setting and under steering, then you will need to find even grippier tires for the front, put some traction compound on the outer treads. May cause traction roll.
sakadachi is offline
Old 07-05-2015, 04:55 PM
  #24348
KA2AEV's Avatar
Originally Posted by M05 newbie
So more or less pack it a little bit. I'm going to try this. See if it helps out a little bit. It'll get me rolling sooner when I get my gears next week considering the diff isnt even ordered yet. I'll post pics if I can and show the process of what i did. Hey I know I've been told about gears a few times but I think in going with the tamiya reinforced (black). Any other favorites out there when it comes to m05 gears? Mainly for toughness.
Try and stick with the Tamiya and stay away from the Fast Racing ( Im not sure if that's the proper name) but they are supposedly a higher gear ratio to give more speed, but they seem to be made of inferior plastic and turn to mush fast
KA2AEV is offline
Old 07-05-2015, 05:35 PM
  #24349
patorz31's Avatar
RW Racing in england make a machined fast gearset for the mini. It is machined delrin like the TC spurs he makes.
patorz31 is offline
Old 07-05-2015, 05:40 PM
  #24350
But wouldn't the machined metal eventually wear on the plastic body and cause wear that will cause the body to be replaced? And wouldn't metal with no oil to lubricate and cool cause overheating which would cause the metal to soften and strip easier??
Old 07-05-2015, 05:51 PM
  #24351
R/C Tech Elite Member
monkeyracing's Avatar
The number one killer of M chassis gears is the crappy stock aluminum pinion Tamiya supplies with kits. Those things go all shark toothed in a hurry and destroy the spur gear. Get a Robinson Racing or a Kawada pinion, or even Tamiya's own hardened version. They're cheap and you'll replace far fewer gears. I'm running the same, stock, white gears I did last season and expect they'll last another.
Here's the key to M chassis pinions: The pitch of the gears is 0.6 mod, .6 module, or some variation on that. They are not 48P, no matter what the dude at the hobby shop says. Robinson Racing sometimes uses the term "48P metric" but it's inaccurate.
monkeyracing is offline
Old 07-05-2015, 06:00 PM
  #24352
sakadachi's Avatar
Really? I go through Tamiya pinions pretty fast, but it's the small idler gear that goes first with the pinions. Spur looks pretty decent even though it meshes with the pinion.
I tried the RobinsonRacing one and it's noisy + whining noise. I'd like to try the Tamiya's hardened one next, if I can locate one. I haven't tried the Kawada.
Old 07-05-2015, 06:42 PM
  #24353
The Robinsons are noisy (STEEL!). The Kawadas (duralumin) are the quietest I've tried and last forever.
Old 07-05-2015, 06:52 PM
  #24354
Sometimes, you have to read the question, before you give an answer. He said that he had a bad push using the PS 456 & 452 combination. I'd used that combination quite a bit and never had a really bad push with it so knew that it could be "cured" or improved with some chassis adjustments. Also, you had to know that the chassis was an M05 cause he said his shocks were in the outer hole of the shock tower. The M03 does not have a shock tower.
But as I hit the submit reply button, I knew there were things I may have forgotten cause my wife had distracted me several times during my reply. One you mentioned and that is if the diff is too tight, the car will push. The second thing was if his shocks were built with a high rebound, the car would also push as that would inhibit weight transfer.
Also, as I mentioned in my reply, the effect of altering the toe out's not a settled question and opinions vary. But I, personally, have found toe out adjustments as one of the most important things available to us.
Granpa is offline
Old 07-05-2015, 07:00 PM
  #24355
sakadachi's Avatar
Yes. In additon, practice driving is also important. Letting off throttle alone provides more weight to the front giving bite.
  #24356
patorz31's Avatar
They are machined Delrin, not metal.
patorz31 is offline
Old 07-05-2015, 07:04 PM
  #24357
sakadachi's Avatar
Thanks, I shall give the Kawada's a try!
Old 07-05-2015, 07:24 PM
  #24358
And delrin is.......???
Old 07-05-2015, 07:36 PM
  #24359
Hey guys...just thinking can u guys post some tool tips or pics and sets of what u guys have being veterans at this. I only have the t bar that came with the m05 and a few Phillips. .pliers and cutters..and now a 2.5 mm because I had to replace the hardware for the control arms. What else is a must?!?!
Old 07-05-2015, 07:58 PM
  #24360
patorz31's Avatar
A strong engineering plastic. Go look at some high end spur gears for touring cars. They are usually made of Delrin.
patorz31 is offline
