Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-30-2015, 05:07 AM
  #24196
heretic's Avatar
Vacuum pump is really useful. Wouldn't even attempt to do my shocks without one.
You can drill a 1mm- 1,5mm hole in the cap, to get rid of most of the rebound from the air trapped behind the bldder.
Ghetto-er shock holder: Take the cap off your brake cleaner can and drill four holes with a body reamer.
heretic is offline
Old 06-30-2015, 05:29 AM
  #24197
What gears and hop ups and pinion should I use for a brushless 3750kv motor??
M05 newbie is offline
Old 06-30-2015, 08:36 AM
  #24198
byteme909's Avatar
that looks very nice.
does anyone know where I would be able to locate the old Tech Racing M05 conversion kits? I don't really care if its the FF or RWD version. I didn't see any place online that has them in stock.
byteme909 is offline
Old 06-30-2015, 10:34 AM
  #24199
eR1c's Avatar
Nice build, thanks for sharing!
I have a TOP 4wd mini, -it drives like a full size TC. You can whip it around the turns and it just doesn't slip or tip. Super nice car!
i'll get a photo of mine up soon.
eR1c is offline
  #24200
eR1c's Avatar
eR1c is offline
Old 06-30-2015, 11:24 AM
  #24201
eR1c's Avatar
nice build Sakadachi!
I have not driven the FWD Sabre mini, but do own a 4WD Sabre mini. Speaking for the 4WD version it handles incredibly well as good as a full size touring car. I can whip that little car around the tightest corners at near full throttle and at worst the tires may slip a tad ..it just hugs the road so well. Its a fun little car.
Here are a few photos of mine,
I just upgraded the servo and receiver (to match my new controller), so the wiring is still a mess.
eR1c is offline
Old 06-30-2015, 11:30 AM
  #24202
eR1c's Avatar
eR1c is offline
Old 06-30-2015, 11:38 AM
  #24203
sakadachi's Avatar
Took a while, but I got the body posts to fit the Tamiya Rover Mini body without drilling new holes in the body.
Front required about 5mm of spacing. I drilled the bottom hole on the Sabre body post.
My ride height is pretty high so no issue of upper arms hitting the bottom of the posts when
the chassis bottoms out.
The rear took some thinking...Used my M-Four's body post at one of the rear hole locations
on the Sabre, then drilled 2 new holes through the chassis as the post has 2 mounting holes
each. Then used my HPI CupRacer extension to lengthen the post.
The M-Four's transponder bracket also acts as a brace.
Regardless, the fitment is perfect, no rubbing.
Next up, I need to figure out what to do with the bumper..
sakadachi is offline
Old 06-30-2015, 11:39 AM
  #24204
sakadachi's Avatar
deleted..
Old 06-30-2015, 11:43 AM
  #24205
sakadachi's Avatar
deleted..
  #24206
sakadachi's Avatar
deleted..
  #24207
sakadachi's Avatar
Test test, I can't post..
Old 06-30-2015, 12:31 PM
  #24208
sakadachi's Avatar
deleted..
  #24209
sakadachi's Avatar
deleted..
Old 06-30-2015, 12:45 PM
  #24210
marcos graveyar's Avatar
Probably not legal in some race series.
marcos graveyar is offline
