Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-22-2006, 01:55 AM
  #2326
TENCHO's Avatar
Yes the VW body is by Active Hobby. Do you like it?
TENCHO is offline
Old 11-22-2006, 02:05 AM
  #2327
Originally Posted by akuhon
I only need a really small hook to make such turnbuckles.... not lucky so far ...
did you try the Ta-01 turnbuckles for upper links? they are the smallest i have found, didnt try them on my mini yet dought
DrKucho is offline
Old 11-22-2006, 07:16 AM
  #2328
AdrianM's Avatar
Hi guys. I just wanted to let you know that Take Off just released RP40 compound mini tires. We now have the RP30, 36 and 40 compounds in the US. They are working on molded inserts and racing wheels for Mini Coopers right now. They will also have all tire compounds available as premounts once the inserts and wheels are done.
AdrianM is offline
Old 11-22-2006, 07:49 AM
  #2329
akuhon's Avatar
Never have it ... how's the quality of the plastic ?
Thick or thin ?
I still prefer Monster "M" from Chevron models ....
akuhon is offline
Old 11-22-2006, 08:08 AM
  #2330
akuhon's Avatar
Don't think it works...
I've used this MB7 screw (see attached pic) and use Tamiya shortest ballcup adjuster (p/n 50797) still no work on ... It's still longer than stock plastic upperlink from the kit.
TA01 upper link, probably has the same length for TL-01 not M03 ...
akuhon is offline
Old 11-22-2006, 08:19 AM
  #2331
Customworksking's Avatar
Trader Rating: 74 (100%+)
Arrow car
here is my new VWbody and my mini pics.
note the yokomo shoks/springs and rare Honda S800 wheels.
NICE wonder how it will handle with the bug body vers the swift...BTW I feel better today
Customworksking is offline
Old 11-22-2006, 08:22 AM
  #2332
Trader Rating: 28 (100%+)
Adrian, thats great news. I ran the RP30's at the KO Grand Prix this year...huge improvement over the tires I used in the past
The car was on rails to say the least!
John
Attached Thumbnails Tamiya mini cooper-img_3441-copy.jpg   Tamiya mini cooper-img_3444-copy.jpg
madjack is offline
Old 11-22-2006, 08:23 AM
  #2333
f1larry's Avatar
Trader Rating: 22 (100%+)
have you tried using the mb7 screw and cutting 3-4mm off of each ballcup adjuster (leaving enough for the screw to catch) Not sure if that would be too long still, but worth a try
f1larry is offline
Old 11-22-2006, 08:27 AM
  #2334
f1larry's Avatar
Originally Posted by Scottrik
COMPLETELY new to the Mini's--bought an M03 "classic" Mini to run on our medium-grip carpet during breaks, etc. Can someone (or a couple someones) make a tire recommendation? Prefer something that mounts on the Minilite wheels (either reinforced or not).
Many thanks,
Scottrik
front use the Tamiya s-grip with tamiya hard sedan insert (cut to fit) with foam insert (also cut to fit).
wrap foam around wheel and then the insert around the foam.
Rear use Tamiya m-grip with tamiya hard sedan insert (cut to fit).
Tamiya use to have hard inserts for the mini wheels but discontinued them so now people are using the medium narrow hard insert (black) cut to fit the mini wheel.
Thats been the setup of choice at the track I race mini's at.
f1larry is offline
Old 11-22-2006, 08:33 AM
  #2335
Scottrik's Avatar
Trader Rating: 261 (100%+)
Thanks for the info Larry. I'll see what I can find from that list--if it isn't perfect, it'll be a starting point.
Scottrik
Scottrik is offline
Old 11-22-2006, 08:35 AM
  #2336
akuhon's Avatar
If you cut it, there'll be not much contact between the screw and the ballcup ...
It will pop off easily ....
akuhon is offline
Old 11-22-2006, 09:52 AM
  #2337
you have not much options, i think cutting the adjusters is the only way to go , use glue once you screw it to aviod from pop off
DrKucho is offline
Old 11-22-2006, 10:10 AM
  #2338
Default camber
Yes, I know but I run outlaw class ... and use foam-tires... I need extreme chamber angle 'cause the foam tires wear out so fast (the outer part).
For upper link melting, not a good idea 'cause you can't set the camber equally left and right ....
BTW thanks for the advice.
what u can do is cut the link in 1/2 thread a ti rod in each side say a corally rod and see if that will work
Old 11-22-2006, 05:12 PM
  #2339
Many thanks,
Scottrik
So you sold 2 GenX to get a mini copper?
If you're looking for rubber setup and I really can't help you cause I'm looking myself. If you're running foams and don't need TCs legal then I have some setups
Sydewynder is offline
Old 11-22-2006, 05:14 PM
  #2340
I've tried them. They aren't short enough in the front. I'm using the rears with the cups screw all the way in butted up against each other..... And they end up being about the same length as the stock plastic rear link.
