Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-03-2015, 08:40 PM
  #23296
R/C Tech Elite Member
monkeyracing's Avatar
Dirt, mashed in carpet fuzz, traction compound, maybe a haze of oil from bearings. That spur has a full season of practice and racing on it. I think the pinion was installed last season.
monkeyracing is offline
Old 04-03-2015, 08:46 PM
  #23297
sakadachi's Avatar
Wow...
sakadachi is offline
Old 04-04-2015, 10:07 AM
  #23298
sakadachi's Avatar
I got two of those 2S 1/16th lipo's MD recommended today, S6070, 60D, wheels, Sport-tuned 380 motor, etc.
I have another 1/16th nano-tech 2S coming to me next week.
Voodoo drops also arrived for my silver cans.
Thanks again everyone!! Going to start with the M03 and M05 suspension today.
Old 04-05-2015, 07:46 PM
  #23299
Mike Schumacher's Avatar
Trader Rating: 37 (100%+)
What number of oil should I put on 3racing gear diff if running on small to medium track?
Mike Schumacher is offline
Old 04-05-2015, 08:51 PM
  #23300
Locally there are cars running anything from 300,000 to 2.5M, but 500,000 seems to be the favourite right now. We run on medium grip carpet, about 36' x 70'.
Old 04-06-2015, 10:27 AM
  #23301
sakadachi's Avatar
Hey hope you all had a nice holiday weekend.
I worked on my M03 and M05 suspension. The M03 turned out real well, very much dialed in rivaling my V2. Biggest change since the corner balancing (using the M05 battery holders and shifted battery on the right by 2-3mm) was adding the white extra hard spring on the front with white Tamiya damper oil, single hole piston. I use full traction compound on the rear treads, and on the front the inner 2 treads on the 60D's. The rear is running red spring and very loose damper oil. No rake.
Too bad my ball diff's spline gave out on one side where the outdrive connects. Swapped to open diff but no issue on my tight track.
On the M05 I added the front stabilizer. It's not a huge difference, but it did improve the sway. I'm going to start softening the damper oil this week on the front. With the aftermarket pistons in there, I can probably go down to #400 (Tamiya yellow) level.
Have not had a chance to even open the M-Four's packaging yet.
Old 04-06-2015, 10:50 AM
  #23302
sakadachi's Avatar
BTW, Granpa- Thanks again on that VooDoo comm drops. It does make a noticeable difference on my silver can!
It's like right after cutting the comm on brushed motors back in the day.
The motor is plenty fast for my basement track now.
Old 04-06-2015, 11:02 AM
  #23303
eR1c's Avatar
...conversion from M05 V1 to V2 in progress!
...this was also a good time to check my gears, ball diff', etc... ...yet w/ only 2 race days on them (about 6 races) they were still good.
I was able to get 4th out of about 13-15 in the A main. Hoping the V2 will give me a bit better handling to get in the top 3.
eR1c is offline
Old 04-06-2015, 11:55 AM
  #23304
sakadachi's Avatar
Sounds like fun, eR1c! How much $ did it cost you to do this conversion? I might do this down the road on my M05.
Forgot to mention, with the tad warmer weather, I ordered 3 cans of lexan spray paint. Just the basics, red, blue, green in metallic. Will be painting the bodies hopefully soon.
Old 04-06-2015, 12:11 PM
  #23305
eR1c's Avatar
Well I got paid to do the conversion. How you ask?
I made my purchase from RCmart, Here is what I bought:
Chassis kit: $11
Motor mount piece: $15
Lower Arm Set: $8
$33 total, I think that was all w/ shipping. However while I was on the site, I happened to click on a "Flash Sale" link I saw. I noticed this part:
http://www.rcmart.com/tamiya-84407-v...h=595_744_1389
However it was listed at $9.99. So I added it to my cart. I didn't need that part, but a quick ebay search showed that they were all selling for $55-75 each. I went back the next day to buy like 10 of them, but the $9.99 price was gone. ...SO, I have this Tamiya V2 aluminum hop up set that I got for $10, which I plan on putting on eBay for $45 ...a $35 profit should be had thus making my V2 conversion a $2 profit!
(thats the long story)
eR1c is offline
Old 04-06-2015, 12:18 PM
  #23306
sakadachi's Avatar
Thumbs up
Chassis kit: $11
Lower Arm Set: $8
Wow, that's a great deal!! Nice catch on that $9.99 too lol
I am pretty sure that was a big mistake on their part.
So I guess I will think about converting my M05 to V2 as well. I will just need to get the chassis and the aluminum motor mount with heatsink. The improvement is INSANE.
Old 04-06-2015, 12:46 PM
  #23307
eR1c's Avatar
That is what I am hoping!!! (thanks)!
I think being able to run a smaller shorty battery will be a HUGE gain alone.
eR1c is offline
Old 04-06-2015, 01:17 PM
  #23308
sakadachi's Avatar
eR1c - My V2 is setup to run side-by-side NiCd's from 15yrs ago, NiMH sport pack, and the round housing 2S Lipo. Even comparing my V2 with the heavy NiCds, it is still far better handling than my M05 running the round housing Lipo which are considerably lighter than the NiCd's.
I don't know why the M05 drives so front/top heavy like the M03's while it looks more like the V2.
That piece of plastic (V2 chassis) has A LOT of technology built into the design.
Old 04-06-2015, 01:40 PM
  #23309
sakadachi's Avatar
BTW, has anyone tried the M05 aluminum counter weight?
It looks like a heat-sink. Tamiya #54538
http://www.tamiyausa.com/product/ite...oduct-id=54538
Does that little piece of metal really offset the left/right problem the M05 has?
Old 04-06-2015, 02:09 PM
  #23310
eR1c's Avatar
I too was curious about that counterweight.
It will fit the M05 perfectly and would seem to counter weight the motor.
For the M05 V2 I am not sure if it would be a perfect fit as the contact area of the V2 chassis is beveled slightly (whereas the weight is flat). -I would be curious if it is a fit though?
eR1c is offline
