Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-27-2015, 07:31 PM
  #22741
bmxcrx's Avatar
Originally Posted by avink007
Tamiya 53267, its the TA03 ball diff. It is better than the M05 ball diff.
ahh, I keep hearing that. Thanks, any other parts needed to make it work?
bmxcrx is offline
Old 01-27-2015, 08:20 PM
  #22742
Core Creations's Avatar
Trader Rating: 108 (100%+)
I'm curious as to why people still say the TA03 ball diff is better than the M05 ball diff? Ive had dozens of TA03 ball diffs through the years and they were always a pain with very little adjustment IMO. I have had the same M05 ball diff in my car for almost 3 years without any rebuild and its still smooth as butter. I've never broke a diff screw or anything and I find it very adjustable. Anyone that knows me knows I don't drive my mini like Miss Daisy...just curious...
Core Creations is offline
Old 01-27-2015, 10:49 PM
  #22743
R/C Tech Elite Member
monkeyracing's Avatar
Good question. I heard the earlier ones were a bit fragile. I've only ever owned a few TA03 diffs, because they're tough as nails. Just rebuild every few years and you're good. I have heard of some breaking the adjuster nut, however.
I missed having an actual diff in my car so much - we all went to the fluid filled diffs here, with 500,000 - 1.5M wt silicone - that I've stuffed a fairly loose TA03 diff back in there. I don't win races (and I wouldn't anyway) but my car is an absolute joy to drive.
monkeyracing is offline
Old 01-28-2015, 06:45 AM
  #22744
I am using the Spec-R mini oil diff for my M-06 and M-05pro2. I also got several of them with different type of oils. From 2k to 150k, depending on the track I am driving on.
Liking it better than the ball diffs, but that is my personal opinion.
They are quite cheep and you can prepare them at home, just swap at the track.
On my local track I use the same diff all year.
NoBrainer is offline
Old 01-28-2015, 08:07 AM
  #22745
firefoxussr's Avatar
I just installed 54409 Low Friction Step Screw set in my M05 as new kingpins and they have a lot of play. Thinking it was worn out C-hubs, I replaced em with new ones...the same thing.
Am I missing something here? Like bushing or have to use a non-standard C-hub (e.g. hop up or aftermarket)?
firefoxussr is offline
Old 01-28-2015, 10:45 AM
  #22746
m-chassis big bore and "black bits"..scroll down
on display at Nuremberg toy fair
these should be in stores soon? (announced at Tamiya Fair)
54613 OP1613 M-05 Ver.II Stainless Steel Suspension Shaft Set
54614 OP1614 M-05 Ver.II Carbon Reinforced L Parts (Suspension Arms)
54615 OP1615 M-05 Ver.II 3 x 58mm Titanium Coated Suspension Shaft (2 pieces)
54623 OP1623 M Chassis Ring Fixed Type Wheel Axel
Last edited by torg; 01-28-2015 at 12:17 PM. Reason: DesJardins: pointed out hotlink issue
torg is offline
Old 01-28-2015, 10:49 AM
  #22747
DesJardins's Avatar
They kill hotlinks
DesJardins is offline
Old 01-28-2015, 12:16 PM
  #22748
Going with big bore dampers seems excessive when they only need to move a few MM, but they sure are pretty. The black anodized bits, though...I'm digging those. Just need to find black front uprights.
I think my favourite M chassis hop ups were when they were done in that pale bronze/almost titanium finish. Subtle, functional and not bright freaking blue.
EDIT: Looked through the rest of the stuff and one thing stands out - the new 15.5t motor. Why? There are standards and rules everyone has adapted to for different classes of racing worldwide (13.5, 17.5, 21.5, etc) and Tamiya's banging their head against a wall again. Yikes.
Old 01-28-2015, 12:35 PM
  #22749
DesJardins's Avatar
Big Bore... If they make it people will buy it I guess
Old 01-28-2015, 12:43 PM
  #22750
Hell, I'm still running "small bore" dampers on my B4 buggy. It's carpet racing - no jumps.
Old 01-28-2015, 01:05 PM
  #22751
caltek1's Avatar
Trader Rating: 38 (100%+)
A new MO5 V2 Pro kit to be released. Photo from Tamiyablog.
caltek1 is offline
  #22752
OSherman's Avatar
im still curious about this Ring Fixed Type Wheel Axle mumbo-jumbo...
uhmmm.. what is it?
OSherman is offline
Old 01-28-2015, 01:09 PM
  #22753
OSherman's Avatar
found it.. just as i suspected..
nice addition
OSherman is offline
Old 01-28-2015, 01:12 PM
  #22754
DesJardins's Avatar
nice addition
Now that I'll try
Old 01-28-2015, 01:15 PM
  #22755
patorz31's Avatar
It will probably wind up being the TC spec motor for TCS.
Still no motor for the mini though....
patorz31 is offline
