Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-26-2015, 09:47 AM
  #22726
Got my mini cooper about 3 weeks ago and loving it, went with a simple paint scheme. I first drove one of these in a 3 hour enduro event, and man was that a blast! Are enduro's common in other parts of the country?
Mattkore is offline
Old 01-26-2015, 11:00 AM
  #22727
DesJardins's Avatar
Just picked this one up myself... I'm in the east valley so will be hitting some of the same tracks as you I'm guessing.
Should be fun!
DesJardins is offline
Old 01-26-2015, 03:50 PM
  #22728
eR1c's Avatar
Yes they are the 54000 M-chassis shocks.
It's sitting at 5mm front & 6mm back with very little droop around 1-1.5mm
I'll check the shock length measurements as those are written down at home
The 54000 M's are a bit longer than the stock plastic shocks, but are shorter than typical 1/1oth TC shocks. To add further frustration, you'll find that Tamiya springs you purchase for the 54000 M's will be a tad shorter than they should be in my opinion, and were probably designed for the stock shocks.
In any case, the 54000 M's are the way to go for the Tamiya Mini, and even w/ the springs that are a tad too short you'll still be able to adjust to your liking.
eR1c is offline
Old 01-26-2015, 03:52 PM
  #22729
eR1c's Avatar
-oh, and 5-6m is about the sweet spot for the M chassis. You really don't want to go lower than 5. ...you won't get much shock travel if you do.
eR1c is offline
Old 01-27-2015, 04:46 AM
  #22730
still any descent HPI bodys available out there?
coolair is offline
Old 01-27-2015, 05:57 AM
  #22731
DesJardins's Avatar
Seems like I'm right on par with what it should be for now
I'm rocking an HPI #7215 BMW & have a second one coming HPI #7209 Datsun
Both are the Mid wheelbase of 225mm
Old 01-27-2015, 09:18 AM
  #22732
eR1c's Avatar
huh? there are a ton of body options for the M-Chassis, ..there are about 1/2 a dozen from HPI, about a dozen from Tamiya and another dozen or more from other manufacturers including ABC Hobby. Is there a particular body your looking for?
eR1c is offline
Old 01-27-2015, 11:18 AM
  #22733
k_bojar's Avatar
Trader Rating: 30 (100%+)
not as common as you'd think they'd be - but mini chassis enduros seem to be the most popular that i've seen..
in NJ, we ran a 24 hour enduro a couple of years - 1 chassis/body, 6 drivers, lots of tires, lots of ducktape and headlights/taillights - it was AWESOME
k_bojar is offline
Old 01-27-2015, 12:04 PM
  #22734
HPI s are the easiest ones to get around here...
but most that fit the mini seem to be discontinued...
coolair is offline
Old 01-27-2015, 01:40 PM
  #22735
ctmandu's Avatar
I have an ABC hobby Datsun Sunny on a RWD Tamiya M03 chassis. I use it for just outdoor fun and waterproofed all electrics, kinda like a basher and raised up . More like a Rally car I guess. Would post a picture but cant yet so ill try and add a couple to my album here.
ctmandu is offline
Old 01-27-2015, 03:34 PM
  #22736
bmxcrx's Avatar
Recently picked up an M05 v2 used and it has a locked diff. It's totally uncontrollable. Does anyone have the parts numbers for the original diff or should I just go ball diff? Needs to be Tamiya parts only. Thanks!
bmxcrx is offline
Old 01-27-2015, 03:46 PM
  #22737
R/C Tech Elite Member
monkeyracing's Avatar
It's probably easiest just to go straight to the ball diff.
monkeyracing is offline
Old 01-27-2015, 04:00 PM
  #22738
Tamiya 53267, its the TA03 ball diff. It is better than the M05 ball diff.
avink007 is offline
Old 01-27-2015, 05:48 PM
  #22739
eR1c's Avatar
"PI s are the easiest ones to get around here...
but most that fit the mini seem to be discontinued..."
If your referring to the hpi bodies that were originally made for the cup racer, they are not discontinued. There are half a dozen different modela available at the major online hobby stores. -I just checked, lots of stock available.
eR1c is offline
Old 01-27-2015, 05:50 PM
  #22740
eR1c's Avatar
"Tamiya 53267, its the TA03 ball diff. It is better than the M05 ball diff."
+1 that
When putting it together be sure to tighten it like mad.
eR1c is offline
