Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-07-2014, 02:28 AM
  #21826
sosidge's Avatar
I've always felt that the cause of rear end skipping is a lack of droop in the rear suspension. Assuming you have used the equivalent mounting positions on the Yeah racing hubs as you had on the Tamiya parts.
sosidge is offline
Old 08-07-2014, 04:04 AM
  #21827
caltek1's Avatar
Trader Rating: 38 (100%+)
Jim,
I knew parts for the new MO5 V2 would be hard to obtain for awhile, so I purchased two kits. Assembling one and the other is still sealed, but ready to be canabilised if required. Overkill possibly, but have readily accessible spares.
Just the way I roll.
Regards,
Calvin.
caltek1 is offline
Old 08-07-2014, 04:06 AM
  #21828
caltek1's Avatar
Thanks voodoo, I got an update today saying the rules have been amended.
caltek1 is offline
Old 08-07-2014, 04:30 AM
  #21829
I'm looking at getting some TRF shocks, but the new TRF short shocks are also suitable for the mini ( part No 42273) These also have adjustable collars unlike the std Mini shocks.
Has anyone else tried these yet?
Qatmix is offline
Old 08-07-2014, 05:28 AM
  #21830
caltek1's Avatar
I would purchase the newer TRF mini shocks, rather than the 54000. I am finding that the 54000 shocks have a shorter shaft than the kit supplied items in the new MO5 V2. Even without the o ring under the piston, the length is shorter. I know you can just wind up the droop screw but defeats the purpose of being able to have fully adjustable droop.
caltek1 is offline
Old 08-07-2014, 08:37 AM
  #21831
They are perfect for a Mini. IMO much better than the #54000.
Granpa is offline
Old 08-07-2014, 08:53 AM
  #21832
You're right in that too little droop can cause rear end hop, but there are many, many other causes. Most of these are individual to the specific car. Just increasing the droop won't stop rear end hop----sorta depends on how much droop you had to start with. It isn't as simple as that.
Granpa is offline
Old 08-07-2014, 09:19 AM
  #21833
Originally Posted by Bigmic
Where to buy a KO VFS-1 Competition v3 or a LRP Competition Quantum 3 best? Didn't find any here in Europe...
Originally Posted by eR1c
Try PM'ing "Madjack" -I believe he has one to sell.
Doesn't it finds a shop where I can buy one..?
Bigmic is offline
Old 08-07-2014, 09:31 AM
  #21834
sosidge's Avatar
99% of the high end brushed escs have been out of production for five years - very hard to find in shops unless you go to a back street shop with loads of old stock and an owner that hasn't heard of eBay...
sosidge is offline
Old 08-07-2014, 11:43 AM
  #21835
Trader Rating: 28 (100%+)
Thumbs up
eR1c is correct, I still have a QC3 if your interested?
http://www.rctech.net/forum/r-c-item...-sell-off.html
madjack is offline
Old 08-07-2014, 12:43 PM
  #21836
If you have your heart set on a KO, go to the KO Propo America website. Expensive, but the best.
Stormer Hobbies shows the they have one Tekin FX Pro in stock. madjack has an LRP Q3 that I know works cause I've raced him.
Granpa is offline
Old 08-07-2014, 03:19 PM
  #21837
Thanks, gonna order these
Qatmix is offline
Old 08-07-2014, 04:34 PM
  #21838
These comments are for lower grip asphalt tracks and not for carpet.
Use the 3 hole pistons and leave out the red sponge. You'll have to use 2mm more of spacers than you would on the #54000shocks cause the shock bodies are 2mm longer. This is why this shock is smoother than the shorter 54000. Build them as a 0 rebound shock. With new bladders this is impossible to do, so drill a #60 hole in the plastic end cap to bleed the trapped air. Depending on the amount of droop you want, the shocks should be 56-58mm in overall length, measuring from end to end.
If the above isn't clear, you can PM me on the subject. I've posted this stuff before and just don't have the patience anymore to discuss this with those who don't agree with my methodology.
Granpa is offline
Old 08-08-2014, 01:41 PM
  #21839
EricP's Avatar
... so drill a #60 hole in the plastic end cap to bleed the trapped air...
Speaking of which, guys, this is not legal for the TCS Series, so for those that are competing, don't do it.
EricP is offline
Old 08-08-2014, 02:42 PM
  #21840
FMW
FMW's Avatar
Yeah! What he said. Don't modify the shock parts.
FMW is offline
