Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-28-2014, 04:26 AM
  #20911
I found the only "upgrades" that helped me were
1. Superglue on outside of front tyres to help stop grip roll (on carpet).
2. Tamiya short spring set to lower the ride height.
I did eventually put on oil shocks, but other than that, my M05 is as it was built. And it's very competitive at our local club.
tonybod is offline
Old 04-28-2014, 12:40 PM
  #20912
Clawhammers's Avatar
Originally Posted by tony gray
We don't have time any more. Plus there isn't a lot that we haven't already covered.
Also, the site need to be upgraded to later edition of the OS to keep functioning and its not worth the time and effort for us to do so.
We've done what we wanted to do, and our FB page will keep running.
I feel sorry to hear that TonyG. I am lucky that I could learn a lot from your website. I look forward for your future post/guide on FB.
Originally Posted by niznai
Clawhammer, if you read the mini site you'd have found out no upgrades are needed for a mini, all you need to do is just build it as per instruction manual and go have fun.
Hi Niznai, your point taken, but I wish to learn a lot from RC Tuning, and this can be achieved by trying various setting of hop-ups. Further, I also love to put hop ups in my Mini, and seek a lot of bling colors under the bodyshell.
Clawhammers is offline
Old 04-28-2014, 03:40 PM
  #20913
Yes, it's true, it is not necessary to do any upgrades. The car will run just fine and in some hands may even be competitive. You'll find tho that many will suggest some upgrades. I'll go thru just a few and let you come to your on conclusions.
1. Aluminum steering rack or linkage. The kit one works fine till you "tweak" it. If you're a great driver that never "hits" anything the kit one will be fine. The rest of us will tweak it and be replacing it very frequently. It's much cheaper in the long run to add the upgrade.
2. Oil filled shocks. There may be a way to build the stock ones to work as well as the oil filled ones, but every time you adjust the ride height it's a rebuild.
3. Al front uprights. The kit ones will bend, the al one do not. Use the stock ones till you bend them then upgrade to the Al units.
4. CVD. Dog bones constantly fall out and get lost especially in crashes.
You get the idea. If upgrades are done for sound reasons, they are worthwhile. They will increase the "fun" if you're not constantly replacing bent parts, rebuilding something that could be adjusted with a twist of a collar and so on.
I really don't know how it is in other locales, but around here, all of the competitive cars have a number of upgrades.
Granpa is offline
Old 04-28-2014, 09:30 PM
  #20914
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Doing upgrades for the sake of durability isn't a bad reason to do them.
Much better than "that looks hot" or "I want it!"
CraigMBA is offline
Old 05-02-2014, 10:55 AM
  #20915
more CAD drawings for M.05 Ver.II
tamiyablog .com/wp-content/uploads/2014/05/tamiya-58593-1.jpg
tamiyablog .com/wp-content/uploads/2014/05/tamiya-58593.jpg
Old 05-02-2014, 10:56 AM
  #20916
double post
Old 05-02-2014, 11:03 AM
  #20917
MD
MD's Avatar
Trader Rating: 136 (100%+)
Here's a picture from the Tamiya site.
http://www.tamiyausa.com/items/radio...ssis-kit-58593
MD is offline
Old 05-02-2014, 11:17 AM
  #20918
R/C Tech Elite Member
monkeyracing's Avatar
I wonder if motor cooling will become problematic. What about motors with the solder tabs on the side of the can? That was a tricky thing on the ta06.
monkeyracing is offline
Old 05-02-2014, 02:16 PM
  #20919
It looks like the motor mount is aluminium and reaches up to the heat bars on the top so that will help with the motor cooling
Qatmix is offline
Old 05-02-2014, 02:51 PM
  #20920
The last one did that too.
Looks like there won't be any problems with motor fitment, but no I'm wondering about gears again. Someone had suggested that they'd probably just slide the pinion further onto the motor, but I mocked it up and that would have the spur gear right up against the can, leaving no room for the motor plate or the spur shaft. I'm eager to see how they pulled this off. I'm going back to thinking they whole gear box just got shoved to the right 4.5mm. Minimal new parts required. Maybe a longer intermediate gear.
Also, looks like the front lower arms match now. No more left/right.
Old 05-02-2014, 03:17 PM
  #20921
It looks as if the motor is completely enclosed, which can be a problem, especially for the TCS guys. Just from the photo, a fan for motor cooling won't be any help.
I'm going to pass on this one unless they change the motor rules for the TCS series.
Granpa is offline
Old 05-02-2014, 04:03 PM
  #20922
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Ahh...the clear shocks are back. =/
Dan is offline
Old 05-03-2014, 04:26 AM
  #20923
KA2AEV's Avatar
You mean again???
KA2AEV is offline
Old 05-03-2014, 05:02 AM
  #20924
Cadman1981's Avatar
How come the Mini Monster body is so popular? I don't want to insult anyone, but it's bulbus and...a little ugly, but everyone seems to be running one...
Cadman1981 is offline
Old 05-03-2014, 06:08 AM
  #20925
caltek1's Avatar
Trader Rating: 38 (100%+)
Sorry I don't believe that picture is the finished MO5 Ver 2. It maybe a pre production chassis but that car can not fit a square battery pack. Yes it may have some of the changes on it but not all of them. Or are they going to let you choose either a square or round battery front chassis.
Plus you will require different battery outer supports.
Forever the skeptic
Calvin.
caltek1 is offline
