Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-29-2014, 09:25 PM
  #20296
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Got my M05 up and running today. Ran about 25 laps total. Broke a left front steering knuckle then later on I completely demolished a servo saver which parked the M05 for the rest of the day.
During the time it was on the track I felt the motor was over powering the front inside wheel during the corners. Looking at getting a TA03 ball diff for my M05 to try and get better forward drive. Need to toughen up this guy so I can finish a 5 minute run.
Any tips on what I need to do or should do?
AudioStylz is offline
Old 01-30-2014, 11:22 AM
  #20297
Originally Posted by Timbulb
Can anyone supply some links to M-Chassis rally cars? All the old threads' links are no good it seems. I wanna put together an m03RA.
Here's some links: http://www.geocities.jp/feriocruise/minirally/
http://www.tam.ne.jp/nic/tires/tires_01e.html (Making cheap rally tires)
And then a few pictures of a chopped up $10 Tamiya Mini body to fit TC tires. (and what the chassis looks like.) (Not completely recommended. Silly thing likes to traction roll and it ate a pair of diff cups, and threw a pinion) http://imgur.com/a/WkcjR
pizzaboy192 is offline
Old 01-30-2014, 01:51 PM
  #20298
silverbmr's Avatar
is a TA03 ball diff better than a m05 ball diff? or are they both the same?
silverbmr is offline
Old 01-30-2014, 01:58 PM
  #20299
Samich's Avatar
When I built my M05 a few weeks ago I started out with the TA03 diff from the get go. I got a second M05 for the wife to play around with (she just loves the Mini Cooper) and it has the stock diff. Even just running them around the basement, every time she turns I can hear the inside wheel spin up. Since I have my spare diff I was going to try putting some silly putty in it and drop it in her car to see the difference.
I see you're in Kenosha. You practicing at Harbor Hobbies? I bought my M05 with the intention of running the TCS in March. I'm hoping to make it there this weekend as well for some practice; weather permitting.
Samich is offline
Old 01-30-2014, 08:29 PM
  #20300
fresnojay's Avatar
Just got done test running my mini for the first time on brushless. All I can say is . I think I am going to like this.
Jason
fresnojay is offline
Old 01-30-2014, 08:54 PM
  #20301
AudioStylz's Avatar
Yeah I race/practice at harbor hobbies. My main class is VTA and I have my TC3 fairly setup. I bought a TA05 and M05 with the intentions to race them both at the TCS event as well. Right now it's looking like the TA05 will not make the event mainly because I still need body, wheels/tires, servo mount hardware and a servo that will actually fit! Looking at roughly $125 to complete it.
I got my M05 running but not very reliable. It will run down a VTA car fairly easy but still seems kind of slow IMO. Last time I ran a M05 I packed the diff with the tamiya silver based grease which worked great. Might have to do that next week.
I plan on racing this Sunday as long as the track is open, last I heard northern IL was put under a Winter Storm Watch which will most likely turn into a Storm Warning by tomorrow afternoon. I've heard snow amounts of up to 7-9".
Old 01-31-2014, 07:54 AM
  #20302
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
Originally Posted by SerpentCT4S
I have another question.
When I'm not using my Mini, I'd like to mount the body lower, but it seems it hits the front shock tower. Is there a way to mount it any lower?
Anyone have any info?
SerpentCT4S is offline
Old 01-31-2014, 09:27 AM
  #20303
whitrzac's Avatar
Trader Rating: 97 (100%+)
Is there any demand for the HPI miata bodies? I have a NIP one I was going to send to TBG to have copied...
whitrzac is offline
Old 01-31-2014, 02:30 PM
  #20304
Im having a total brain fart moment with the rear hub carrier. I took the standard hub carriers off to fit the 3racing rear hub carriers with adjustables and i cannot for the life of me work out how to fit them. Ball ends etc are there but looking at the original and these there worlds apart in shape. Any advice or pics of your adjustables attaches to ball on hub would be great.
Green_Machine is offline
Old 01-31-2014, 11:35 PM
  #20305
fresnojay's Avatar
Well my plans to hit Tamiya this weekend are a bust as the whole trip fell apart. So the mini will have its first trial run locally tomorrow. Hopefully Carlton you can make it and bring Daniel with you. I really would like a run together to compare notes and performance.
Jason
Old 01-31-2014, 11:52 PM
  #20306
Schs2013's Avatar
Are super mini CVA shocks worth the money?
Can not afford the tfr shocks. Maybe the 3racing ones.
Which ones would most of you suggest?
I am at least upgrading the shocks to have less basketball affect on the track when i hit a small bump or imperfect surface area
Schs2013 is offline
Old 02-01-2014, 12:08 AM
  #20307
fresnojay's Avatar
I think the TRF's are well worth it besides being TCS legal. I might be wrong but if TCS means nothing the 3racing ones should be good too. When I have the TRF's and seemed to me to be one of the single biggest upgrade I did over the stock plastic shocks I had on mine.
Jason
Old 02-01-2014, 01:09 AM
  #20308
R/C Tech Elite Member
monkeyracing's Avatar
Since the discontinued it there seem to be more people looking for one. It's very low profile and fits the M05 pretty good, especially when using a set of M03 front body posts at the rear.
Which car are you working on? Any part numbers for the items you're attempting to fit?
monkeyracing is offline
Old 02-01-2014, 01:16 AM
  #20309
Which car are you working on? Any part numbers for the items you're attempting to fit?[/QUOTE]
Hi yeah its MO5 chassis adustable upper arms # 54182 and fitting them to the 3racing aluminium rear hubs.
Old 02-01-2014, 09:57 AM
  #20310
Schs2013's Avatar
Arrow
Jason
Well i just need something better than the friction shocks. I do not race tcs. If i could afford the tfr shocks i am still not looking to spend over 30$ for shocks on a mini. So thats why i asked about the CVA shocks and 3racing ones.
Marc
Schs2013 is offline
