Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 09-10-2006, 04:05 AM
  #1921
nice update !!!!
damn the rocket mini is owesome !!!!!!!!!! LOL !!!! any chance you doing upgrades and run it again?
DrKucho is offline
Old 09-10-2006, 05:08 AM
  #1922
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Nice! I love the last scene where the rocket goes *poof*
Toink
Mini Toink is offline
Old 09-10-2006, 08:13 AM
  #1923
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default mini
Originally Posted by Mini Toink
I have an M03 Mini and bought a TRF Damper Set (#53571) with Yellow Springs. I dont know what damper oil to use. Can anyone please let me know what oil # should I buy? 400? 500? 600? etc etc.
Any help please.
Toink
try 70wt and shim the inside to 2 or 3mm of droop ...r u running indoor or out ? Also I have a good 3800 pack for the mini promatch 1.215 485 run time ir 1.8 and the key is I sodder each cell to each other I won the Novak and 2nd at TCS trackside with this pack its only been used at the 2 races say 20 to runs on it ....55.00 shipped paid 75.00
Customworksking is offline
Old 09-10-2006, 01:43 PM
  #1924
tony gray's Avatar
Rocketmini will definitely run again... have some ideas to sort out the problems and there is now a second one as well.
However it'll be a month or at least before it happens, putting everything up online at the moment is taking all my time. Still loads of content to go up...
tony gray is offline
Old 09-11-2006, 03:54 AM
  #1925
tony gray's Avatar
More updates on rc-mini.net online now.
M03 Oval racing video added (Oh yeah!!!......)
Old 09-11-2006, 08:48 PM
  #1926
Anybody have some M04 swaybars they want to sell. . .?
A-Ko is offline
Old 09-11-2006, 09:23 PM
  #1927
f1larry's Avatar
Trader Rating: 22 (100%+)
Jeff,
Your gonna start running your mini now. Which M04 do you have?
f1larry is offline
Old 09-12-2006, 07:23 AM
  #1928
Originally Posted by f1larry
Jeff,
Larry,
I have the M04m Eunos Roadster.
So far yes on mini, we will see what the next few months of racing can bring. . .
A-Ko is offline
Old 09-12-2006, 07:48 AM
  #1929
SilverShelby's Avatar
Jeff,
I think I have a spare set of sway bars
Will get back with you later
mm
SilverShelby is offline
Old 09-12-2006, 11:16 AM
  #1930
mm
The track out here was closing and I got some deals.
They had a pack, funny thing was they were missing the swaybars
Let me know, trying to avoid buying them from the UK for $40. . .
Jeff
A-Ko is offline
Old 09-12-2006, 11:32 AM
  #1931
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
hey all. I am having a seriouse problem with rolling. mostly on tight tracks, but i do tend to roll on loose tracks as well. i'm using CVA minis with a white springs in front and short blues in back. s grip tires that are fairly worn. any help would be great. thanks.
HotrodHopkins is offline
Old 09-12-2006, 12:59 PM
  #1932
Deves's Avatar
What is your ride height?
What inserts are you using in your front tires?
Deves is offline
Old 09-12-2006, 01:16 PM
  #1933
about 12mm front and rear for ride height.
and the inserts i have are stock kit all around.
Old 09-12-2006, 01:52 PM
  #1934
Deves's Avatar
What car are you running?
I'm no expert but here's what works for me on my MO3M.
You need to get your ride height down, the lower the better 5mm in front and 6mm in the rear. You can go lower if possible. If your using the TRF shocks put 3 rubber O rings on the shaft inside the shocks.
Try short yellow springs in the front and longer blue in the rear.
Deves is offline
Old 09-12-2006, 01:56 PM
  #1935
i'm running the M03 with Tamiya CVA mini's.
