Tamiya mini cooper
#1891
Originally Posted by danjoy25
Can someone tell me if the 53222 M-Chassis Super Slicks are also reinforced and if it will provide more grip than the Type A.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGH75
#1892
my car will steer to a side..is it due to the suspension slop
or the stock servo saver is causing the problem?
#1893
#1897
just wanted to know if I can use steering blocks for the TL01 on my mini or just the one's for the TA03?
#1900
What's the dealio with the TA03 ball diff?
I built it according to the (hot tips) and adjusted it all the way tight then backed off. It slips on throttle maybe more than I like.
I am racing on a high grip track so accerlation is important.
How tight should they be? I noticed after taking it apart again that one of the larger cone washers is flat. Should I shim it tighter with some flat shims. I don't want to buy a rebuild kit because it will probably just happen again.
Any help here would be appreciated. Thanks
#1902
put a little thread lock on the screw that way it won't come loose.
#1903
Thanks guys for your input but I have tried both it still seems loose to me.
#1904
Originally Posted by team green
Look at all those mini's
Hey those 3 guys standing in the middle back facing the camara 2 in blue shirts and 1 in black with the hat.. Those are my friends from So Cal!!!
It's good to see them up there in North cal. Maybe next year I'll make it too.
#1905
Sorry guys, I didn't mean to kill the thread...
chirp chirp chirp....ribeet....ribeet
