Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-28-2013, 10:28 PM
  #18646
R/C Tech Elite Member
monkeyracing's Avatar
Ah, the humble silver can. I'm breaking one in for the first time in a few years. It's hooked up with a piece of fuel tubing to an RV bathroom fan motor that spins very slowly. I'd guess it's running about 600rpm at 5v right now. Just need to oil and check the comm every hour or so. Wheee!
monkeyracing is offline
Old 03-29-2013, 01:35 AM
  #18647
Originally Posted by KA2AEV
Thanks guys for all your input
I actually followed what my Driver said and we took a ride over to our local
shop and talked with the owner. He pointed out that his Diff needs to be repacked
that it is wayyyy too loose and he seems to think that the reason why he is loosing
power on the turns is that one drive wheel is coming off the ground slightly
so he got parts and I got alot of work to do!
We did pick up the Front Shock part that you mentioned Grandpa as wellas the
Aluminum Hex for the wheels
I know about breaking in the silvercan and don't think thats too much of an issue
but going to try plopping in a spare Johnson that we have in our motor pool
and see what that does after installing all these parts and repacking the gear diff
with stiffer grease.
I'll let everyone know how we made out when Im done
Again Thank You Guys!!!
Mike
Good grief, DO NOT pack a Tamiya Mini gear diff with grease. Nothing good can happen or will happen. You tighten up diff action by adding extra shims and various incantations or magic spells. Building a snug to tight gear diff is an art form and is mastered by very few. There are many that think they've mastered the 'trick" to building a good gear diff, but they are delusional.
Thus, my recommendation has always been a TA03 ball diff. If you follow the directions that came with the diff, add antiwear grease to the diff balls, and loctite and tighten the diff screw all the way down, you'll have near perfect diff every time. There are a few tricks for these diffs, but most have been posted at one time or another and are pretty well known.
Granpa is offline
Old 03-29-2013, 09:54 AM
  #18648
KA2AEV's Avatar
Can the TA03 Ball Diff fit directly into a 05 chassis?
I remember reading that one of the diffs or the chassis has to be modified
slightly to make it fit, or am I confusing myself?
KA2AEV is offline
Old 03-29-2013, 10:11 AM
  #18649
Just drop it in bro
cheapskate.brok is offline
Old 03-29-2013, 10:25 AM
  #18650
rccardr's Avatar
Mike, you should also check to make sure your speed control is actually hitting full speed- most have an indicator light that turns a different color or blinks when it reaches full throttle.
Seems simple, but a very experienced A-Main level driver (not me!) discovered this past weekend that this was the reason he was so slow. He'd somehow reduced the forward travel on his radio and was only getting part throttle at full trigger pull.
Wish you had come over to our pits this past weekend, we'd have fixed you right up!
rccardr is offline
Old 03-29-2013, 11:16 AM
  #18651
whitrzac's Avatar
Trader Rating: 97 (100%+)
What ball diff fits the m04?
Is there a 3 racing one that will work?
Why does tamiya make 3-4 different ball diffs that are labeled to work with the minis?
whitrzac is offline
Old 03-29-2013, 11:22 AM
  #18652
KA2AEV's Avatar
RCCARDR YGPMed!!!
BTW Our guy at our local shop mentioned that also
Im going to check that right now and make sure he does get full power when he hits the trigger!!!
Thanks for that!
KA2AEV is offline
Old 03-29-2013, 11:24 AM
  #18653
KA2AEV's Avatar
Originally Posted by cheapskate.brok
Just drop it in bro
Thanks Im going to see if my local shop has them in stock now!
KA2AEV is offline
Old 03-29-2013, 11:48 AM
  #18654
It will come squishing from the outdrives making a mess. Good advice!
I'm not sure if you're being serious or sarcastic on this one. Built mine with shims 6 months ago and it's been an absolute gem since. No tricks or special prep, just careful assembly and adjustment. All the instructions, tips and tricks have been posted.
Yes. You'll need to use the bearing adapter parts from the kit to fit the bearings, but if you're running a gear diff, you already are!
TA03 is your best bet.
The 3Racing diffs for the 03/04 have been out of production for a few years, but weren't very good to start with.
The outdrive bearing size changed when the 05/06 came out. The 03/04 could use the TA03 or the Manta Ray diff. The 05/06 got dedicated ball diffs. The old bearing size was 5x10, the newer minis use s 10x15. Tamiya supplied bearing adapter cups with the 05/06 kits, because they come with the old style gears diffs, using the smaller bearings.
Old 03-29-2013, 12:06 PM
  #18655
ruebiracer's Avatar
Just a little correction,
old bearing size has always been 5x11mm (Tamiya 1150 code), not to mislead anyone.
BR,
Matthias
ruebiracer is offline
Old 03-29-2013, 12:12 PM
  #18656
GasGod's Avatar
RCCARDR YGPMed!!!
Thanks for that!
hook a voltmeter up to the motor leads
GasGod is offline
Old 03-29-2013, 12:34 PM
  #18657
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Must have been a senior moment!
Carl Giordano is offline
Old 03-29-2013, 12:39 PM
  #18658
BR,
Matthias
Quite right. Thank you!
Old 03-29-2013, 02:50 PM
  #18659
At the Nats 2 years ago, I'd purchased a new radio, set the throttle travel to 100 and reset the esc. Unfortunately, I discovered with this particular radio, throttle travel needed to be set at 150 the following weekend. Cost me nearly a second a lap. Won't mention the name of the radio cause it's a great radio, just stupidity on my part.
Also panic. I thought that old age had caught up with me big time and was ready to hang up racing altogether.
Granpa is offline
Old 03-29-2013, 05:17 PM
  #18660
whitrzac's Avatar
What tires should I run on a M04? S back M front seems to work with the m06 at my track...
I have a set of the long onroad springs from my f1. Should I use those, or should I go buy the 'short' set?
whitrzac is offline
