Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-12-2012, 05:26 AM
  #17266
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Peter $
Hi Guys
I want my M05 to look like this:
But I need to find some white and red Pirelli stickers (I already have the other stickers).
Can you help me find some? I have searched and Googled, but no results so far
Cheers,
Peter
A bunch of guys in the Painting section will be able to help as well. 'cSeils" I think his tag is, advertises mainly on the US VTA thread as well.
Sith Lord is offline
Old 07-12-2012, 06:20 AM
  #17267
CSeils's Avatar
Trader Rating: 54 (100%+)
Hi Guys
Cheers,
Peter
Perhaps I can help?
Send me dimensions of what you need, I'll see what I can do.
[email protected]
CSeils
CSeils is offline
Old 07-12-2012, 06:39 PM
  #17268
R/C Tech Elite Member
monkeyracing's Avatar
Don't you hate when your mini starts getting all invisible?
This is just a couple layers messed with in photoshop.
monkeyracing is offline
Old 07-12-2012, 06:51 PM
  #17269
Big Fran's Avatar
Trader Rating: 14 (100%+)
Very COOL!!!
Big Fran is offline
Old 07-12-2012, 08:27 PM
  #17270
^ what chassis is that - M03? looks really good from this side.
Do you have more pictures?
Profoxcg is offline
Old 07-12-2012, 09:30 PM
  #17271
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
yes it is the M03
OVA is offline
Old 07-12-2012, 10:07 PM
  #17272
Yup. Just a humble little M03. Old TRF shocks, old M03 front uprights, 3Racing axles, Orca brushless system, Spektrum rx and a good servo. Thinking about adding a rear sway bar.
Old 07-12-2012, 11:23 PM
  #17273
Peter $'s Avatar
Thumbs up
Originally Posted by CSeils
Perhaps I can help?
[email protected]
CSeils
Thanks, I will do that
Peter
Peter $ is offline
Old 07-13-2012, 06:52 AM
  #17274
I notice a lot of racers use hard inserts up front and soft at the rear, what's the reasoning behind this?
How does the insert affect lateral and longitudinal grip levels?
I've tried m-grips all round on carpet with just soft inserts and was pretty impressed with the grip they provided.
2hundy is offline
Old 07-13-2012, 07:15 AM
  #17275
superspeed's Avatar
More grip on the back with softer insert. Typically the front is setup a bit stiffer than the rear, so there will be a bit of understeer rather than oversteer.
superspeed is offline
Old 07-13-2012, 08:05 AM
  #17276
^ great that is what I thought also. The inserts work like air almost.
Profoxcg is offline
Old 07-13-2012, 09:36 AM
  #17277
I'm having some front end traction issues but the car is perfectly balanced through the bends. Current setup for ozite carpet is:
Front
Kit 60d radials soft insert
Blue springs
#700 oil 3 hole
Shocks in outermost hole
Ta-03 diff, very tight with AWG.
5mm ride height
Rear
m-grip soft insert
Red springs
#400 oil 3 hole
6mm ride height
When I tried the m-grips, soft inserts, on all four corners, I could brake far later and the car accelerated a lot quicker but the balance wasn't quite there in the bends. Too much steering, a little loose at the back on corner entry. My fastest lap was no quicker but my average lap time was over a second faster.
Will the m-grips with hard inserts sort this?
ETA M-05 chassis
2hundy is offline
Old 07-13-2012, 11:44 AM
  #17278
superspeed's Avatar
Lower rear ride height and try before changing the insert on the front.
Old 07-13-2012, 02:43 PM
  #17279
Hey I have the same lightswitch.
Sydewynder is offline
Old 07-13-2012, 02:58 PM
  #17280
Yes, but what about the vacuum cleaner that appears to be coming out of the roof?
