Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-31-2012, 02:58 PM
  #17146
Originally Posted by bkspeedo
Is there a setup sheet available for the M-03 or M-05? Can you provide a starting point setup even though it's for pavement?
Where's the best place in the US to but tires and parts?
Thanks for the help.
I posted my M05M set up a few pages back. I've run it on outdoor low grip asphalt, indoor hi grip asphalt, and on carpet. It worked on all three surfaces with only minor adjustments. There may be better set ups, but it is good starting point. It's still a work in progress, but you can just throw it down on any surface and run competitively.
Speedtech is where I usually start and have always had good service with absolutely no problems. TQ RC Racing has the widest selection of Mini tires. I've placed a couple of orders with them recently and their service was really good also. There may be other sources out there, but I'm loyal to the local guys.
Granpa is offline
Old 05-31-2012, 08:49 PM
  #17147
dameetz's Avatar
Can anybody confirm the Sakura FF oil filled gear diff can be used in an M05?
dameetz is offline
Old 05-31-2012, 09:14 PM
  #17148
cannon's Avatar
Trader Rating: 35 (100%+)
They use different side plates on the diff (alloy in the M05 diff) . Theoretically the FF diff is narrower and should fit in but you would need a large number of shims. far easier just to get a M05 diff
cannon is offline
Old 06-01-2012, 09:01 AM
  #17149
niznai's Avatar
Did anyone measure the Sakura gear diff between the bearing shoulders? I need a narrow diff for a project.
niznai is offline
Old 06-01-2012, 09:38 AM
  #17150
TT_Vert's Avatar
Trader Rating: 72 (100%+)
Are any of you guys running the M05 NOT using a tamiya servo saver? I was looking at that kimbrough others are using on their M03s but I'm unsure if that'd work ok in the M05. I'm going to be heading to the hobby store soon.
TT_Vert is offline
Old 06-01-2012, 09:59 AM
  #17151
kwkride's Avatar
I'm running a Kimbrough on mine with no problem. I couldn't give you a part number because it was one that was laying in my spare parts bin.
kwkride is offline
Old 06-01-2012, 10:06 AM
  #17152
TT_Vert's Avatar
Does it look like the one I have pictured or is it a narrower one w/ just one hole?
Dave
TT_Vert is offline
Old 06-01-2012, 10:24 AM
  #17153
kwkride's Avatar
Dave
It's like the one you have pictured
kwkride is offline
Old 06-01-2012, 11:07 AM
  #17154
jcr
I am using the medium length servo saver with the middle hole.
jcr is offline
Old 06-01-2012, 05:41 PM
  #17155
dameetz's Avatar
Thanks Cannon for that info. I might try the FF gear diff coz I have a couple of Sakura diff laying around and I assume the internal gears and diff out put cup are the same, so I just need the FF casing.
Any of you have tried modding the M05 batt slot to fit a rectangular TC type lipo batt? Can you post a pic of it?
Thanks.
dameetz is offline
Old 06-01-2012, 11:40 PM
  #17156
Trader Rating: 62 (100%+)
This thread I started has more than 17,000 replies. Tamiya USA do I get something for promoting the Mini ? lol! Never thought it would be this popular.
sipaboy is offline
Old 06-01-2012, 11:55 PM
  #17157
Thanks.
Not mine.
http://www.rccartips.com/titc-2012-t...ini-rc-car.jpg
rccartips is online now
Old 06-02-2012, 12:05 AM
  #17158
dameetz's Avatar
Originally Posted by rccartips
Thanks, anymore close up pics?
dameetz is offline
Old 06-02-2012, 01:26 AM
  #17159
Lol. Wazzup H. I'll give you a cookie next time I see you at the track.
Sydewynder is offline
Old 06-02-2012, 01:31 AM
  #17160
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I started the HPI Cup Racer thread and I never even bought one.
Dan is offline
