Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-24-2006, 09:19 PM
  #1681
Trader Rating: 28 (100%+)
ok mini mad men...what causes a mini to chatter (at the rear of the car) from apex thru exit of a turn?
thx in advance
madjack is offline
Old 06-24-2006, 09:22 PM
  #1682
Slotmachine's Avatar
thx in advance
Too much rear traction.
Slotmachine is offline
Old 06-24-2006, 09:34 PM
  #1683
JC, if it is the regular cooper or the L then it could the body dragging lightly on the inside rear tire. It could also be the diff being loaded too tightly. It will show up as a chatter on power. The diff cannot act independantly and acts as a spool.
Difuser is offline
Old 06-24-2006, 10:51 PM
  #1684
You know to much about these cars! How's things going?
Juan Aveytia is offline
Old 06-25-2006, 12:10 AM
  #1685
ali_g's Avatar
my mini rear will slide out .... any suggestion?
ali_g is offline
Old 06-25-2006, 12:20 AM
  #1686
Smile REAR SLIDING OUT
Are you using the rear toe in Uprights? Tamiya PNo 53345 Fit MO3 and TL-01. These come standard in the MO3-M. These will cause alittle bit of drag but settle the rear of the car down.
caltech1 is offline
Old 06-25-2006, 04:45 AM
  #1687
rccardr's Avatar
JC- Can also be caused by to little (or too much) droop relative to the piston and shock oil viscosity. Think grip-release-grip-release.
rccardr is offline
Old 06-25-2006, 02:16 PM
  #1688
Z-Mann's Avatar
i use 27 mm inserts(eagle) cut down to size and never traction roll
they support the side wall while cornering
Z-Mann is offline
Old 06-25-2006, 03:04 PM
  #1689
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
does anyone use these toe in rear uprights http://www.tamiyausa.com/product/ite...duct-id=53345? if so, what kind of a difference do they make? Thanks much.
-Hotrod Hopkins.
HotrodHopkins is offline
Old 06-25-2006, 03:58 PM
  #1690
a quick fix is softer rear tires.........
Ginsu is offline
Old 06-25-2006, 06:19 PM
  #1691
Hey Juan good getting a little more time to run now. Give me a call tomorrow I need to get pricing on these spurs you left up here.
Difuser is offline
Old 06-25-2006, 06:36 PM
  #1692
Smile REAR TOE IN UPRIGHTS 53345
HotrodHopkins,
These uprights make the rear end of the car more stable, however they also create abit of drag. I am using these presently on my car and they are very good for low traction tracks. Most people here in Oz use them.
Cheers
Calvin.
caltech1 is offline
Old 06-26-2006, 03:08 AM
  #1693
Originally Posted by caltech1
HotrodHopkins,
Cheers
Calvin.
great, thanks alot for the info.
Old 06-26-2006, 10:59 PM
  #1694
JoeyE's Avatar
Trader Rating: 45 (100%+)
M04's are fun!
Attached Thumbnails Tamiya mini cooper-m04-1.jpg   Tamiya mini cooper-m04-2.jpg
JoeyE is offline
Old 06-26-2006, 11:02 PM
  #1695
JoeyE's Avatar
TCS Fremont. Sorry for the bad picture. It was from my phone.
JoeyE is offline
