Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-28-2012, 01:12 PM
  #16621
sosidge's Avatar
Originally Posted by monkeyracing
Is that droop measured from ride height, then with the car picked up? And that's at the dampers?
Measured at the shocks.
sosidge is offline
Old 01-28-2012, 02:27 PM
  #16622
dirtman71's Avatar
I know the HW 13t seems to be the most popular set up, but has anybody ever tried the Tacon 12t 2950?
http://www.hobbypartz.com/96m26-car-3650-2950.html
I have a feeling you would get quite a bit more bottom end out of the 540 tacon.
Do you still run a 20T pinion with the HW 13t?
I have seen a couple of vids with the 13T and they realy scoot
does the 35a HW esc get hot without a fan? not that there is not room to keep it on.
dirtman71 is offline
Old 01-29-2012, 03:40 PM
  #16623
Travis S's Avatar
Trader Rating: 46 (100%+)
So I bought a used M05 and planned on making it look my real mini cooper s that I drive. However I did not realize the 2006 Mini Cooper S body is longer and I guess it is meant for the long M03L... http://www.tamiyausa.com/product/ite...oduct-id=58400 Has anyone used this body on a M05? If so, how did you mount it because it already has holes in the body and I really didn't want to add more... Is there any different body posts that I can use? Thanks for your help.
Travis S is offline
Old 01-29-2012, 03:44 PM
  #16624
I)arkness's Avatar
you just make the m05 into lwb by following the instruction manual. everything you need is already on the chassis, its not like the m03 where you need extra bits to do it.
I)arkness is offline
Old 01-29-2012, 03:46 PM
  #16625
Travis S's Avatar
Thank you very much! I didn't get a manual with the car so I will go to their website and download it now. I was starting to get bummed out I couldn't use that body! You made my day. - (this was the whole reason I got a M05... )
Travis S is offline
Old 01-30-2012, 06:05 PM
  #16626
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Quick question with hopefully a quick answer:
Are the M04 bodyposts the same position and an M05? ie: Will a body designed and drilled for an 04 fit an 05?
Cheers
Sith Lord is offline
Old 01-30-2012, 06:37 PM
  #16627
R/C Tech Elite Member
monkeyracing's Avatar
M-04 posts are positioned differently. More like an M-06.
monkeyracing is offline
Old 01-30-2012, 10:54 PM
  #16628
I have a rc boat I want to get rid of
dose anyone want to trade there mini for a rc boat?
if your interested email me
[email protected]
tomicamilleri is offline
Old 02-02-2012, 11:22 AM
  #16629
tony gray's Avatar
A new release Mini from Tamiya. M05 (LWB we assume) JC Works Mini Coupe.
tony gray is offline
Old 02-02-2012, 11:46 AM
  #16630
SpeedyDad's Avatar
Oh, must have
SpeedyDad is offline
Old 02-02-2012, 01:36 PM
  #16631
dirtman71's Avatar
I found a TC body for the mini...SWB
Old 02-02-2012, 01:38 PM
  #16632
Sith Lord's Avatar
..... which are frowned upon in the racing ranks.
Old 02-02-2012, 01:40 PM
  #16633
Sith Lord's Avatar
Yep - LWB
This is a Radio Control replica of the MINI JCW Coupe race car, which raced in the SP 3T class at the 39th ADAC Zurich 24 Hours of Nurburgring 2011. This car was based on the new 2-seater MINI Coupe and features race-spec modifications including a sharper windshield angle, adjustable suspension and rear wing, and a 247hp 1.6-liter four-cylinder twin-scroll turbo engine that enables a top speed of 240km/h. The Tamiya RC car is built on the popular M-05 M-Chassis platform, which is easy to build and fun to drive.
Specs and Features
1/10 scale R/C assembly kit.
Kit includes FREE BONUS PARTS (Matte-Finished Gold-Plated 8-Spoke Wheels x 4pcs.) Initial 2012 release only.
Polycarbonate body, rear wing and light bucket cases included.
Separately-molded side mirrors are made of ABS plastic.
Body is mounted on the nimble front wheel-drive M-05 chassis with long wheelbase (239mm).
M0-5 Chassis features front wheel drive, independent double wishbone suspension with oil filled damper units.
Gear differential included.
Vinyl sticker sheet and masking seals for windows included.
Includes 540 motor and Tamiya TEU-104BK ESC.
Old 02-02-2012, 03:50 PM
  #16634
Why do you think they made a point of mentioning that it has a gear diff? New type of of gear diff or just taking advantage of the current hype? I'm hoping for new product.
Old 02-02-2012, 04:09 PM
  #16635
dirtman71's Avatar
Well thats why I bought a 240Z...not to sure of the response at the track yet. If we start an open class I think I might have to try one out.
