Tamiya mini cooper
Try changing one thing in the setup at a time. Manta Ray ball diff (TA02) didn't work as well as TA03 ball diff. I have a M05 ball diff but yet to try it. By the way, the Honda CRX body is a nice addition to the fleet of M chassis bodies.
Renault turbo:
http://www.tamiyausa.com/product/ite...oduct-id=84227
Nissian S15
http://www.tamiyausa.com/product/ite...oduct-id=84267
I remember seeing lots of 1/10 Silvia bodies in the past. Is the real car pretty small? Does anyone think it looks weird on m-chassis or it's more scale this way?
Nissian S15
I have some killer lipos but there all hard squared packs.
I have the new M05 and I'm thinking of doing it.
I am thinking a dremil is all I would have to do to the chasis and velcro straps at the ends?
Really? You'd hack up a chassis rather than popping $13 for a new battery? (hobbypartz, gens ace 2400mah packs)
I don't mean to criticize, but I value my car's structural integrity.
Jom
Jom
Jim/Jom,
You only need to square the edges of the battery hole, top and bottom to make a larger capacity, higher C rated battery fit. It may actually give the chassis a little more flex and added stability with the battery being heavier.
A new MO5 chassis parts is not really that expensive. Also in Thailand they race open mini, with most using a 10.5 BL boosted system with speed gear sets, so extra voltage etc is better.
Remember not all play to our rules.
It is a diverse mini racing playground.
For this years TITC we are all using speed gear sets, with a max 24 tooth pinion, fixed time 17.5 motor and Critix SP ESC. About as fast as our 13T BL hobbywing setups, however the system is less demanding on the cars. The power is more evenly spread than the sudden torque of the HW systems. Weight limit 1200 gms. So some highly dremeled chassis do and will make it to the racetrack.
later,
Calvin.
later,
Calvin.
Domn, I mean damn! Stupid tiny keyboard on my iPhine always gets me.
Jim
Jim
Jim,
I suppose its not as bad as auto correct.
What's a IPhine??????
Calvin.
Calvin.
I realy dont want to cut up the chasis. I still need to see what they are running. I know that they are trying to keep all the cars as equal as posible so running a 2s might not work. will probably have to pick up some NiMh...is 2400 enough? is 5000 to heavy?
looking for shocks....how are these?
http://www.ebay.com/itm/Hot-Racing-T...item23175d9a9c
what is the best esc to use with a silver can motor? looking for something to advance timing or add boost. will a tekin rs have any adjustments to help me keep up with the others in the straights? one fast guy said his secret was a gm vr8 esc.
there's no such thing as a brushed motor esc that has timing and boost, thats only for brushless. some brushless esc's can run a brushed motor but those features do not work with the brushed motor.
honestly the tamiya esc is just fine for the brushed silver can motor.
I race an M05 on carpet, 5 min races with black/silver can motor and a Tamiya TEU101-BK. Never had a problem with 2400's , I use 3 sets, each set does a heat and a final. Charged with a Pro-Trak to 40°.
I was running 12-15 mins at time on 2400s last night. (Orca 2200kv BL system)
What's a GM VR8 esc?
Jim
Jim
What are the diameter of tamiya tuned short spring??? as im hoping those will fit on 3racing shocks on my m05.
It doesn't change the chassis integrity of the plastic.
As far as the lipo battery pack, we use 70 C 4000 Mah 7.4 volt.
For two reasons, power and weight.
The hobbypartz, gens ace 2400mah packs doesn't have the punch or speed.
