Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-29-2011, 03:38 PM
  #16216
joe c's Avatar
Anyone know if the body posts on the tt01 mini conversion line up with an actual mini?
Also, what chassis will the fiat abarth 1000 fit?
I don't know why tamiya put the body on a fwd chassis?
I'd like to fit it on a rwd or awd chassis instead of my fwd.
joe c is offline
Old 11-29-2011, 04:58 PM
  #16217
clittle's Avatar
If you're talking about the 3-Racing conversion, no they don't. They're not far off but it's not a one-to-one match. Also you might find that the conversion length is closer to the M length mini. You can modify the wheel base slightly but when it's really short the front wheels start hitting the chassis when turning. Just need a little adjustment.
clittle is offline
Old 11-29-2011, 05:44 PM
  #16218
joe c's Avatar
Thanks for that.
I'm new to minis (just grabbed an m03)
I also just ordered an abarth body to go on it, then found that the 1:1 is rwd!
I could live with awd though, too.
When I get the body I'll try lining it up with my tt01 for an idea.
joe c is offline
Old 12-01-2011, 03:05 AM
  #16219
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by sosidge
Hopefully you have chosen CVA Super Minis as they are the ones you need to get good travel.
I don't think the TRF pistons will work as the shocks have a much narrower bore.
I would use the 1-hole CVA pistons and heavy oil (Tamiya supply #900 with the Super Minis) if you want anything approaching a damper, rather than just a spring support.
In the past I've used betwen #600 and #900 in the shocks to get the handling balance I want.
Those shocks will handle well on the car, but they are prone to wearing out and leaking. You also have a shade less adjustment than on the TRFs.
i have trf but for 1/10 touring, not mini T
RF. touring TRF very imited move ment on a mini M..am i wrong to say so?
edwintklee is offline
Old 12-01-2011, 03:20 AM
  #16220
sosidge's Avatar
With 55D tyres the TRF shocks should have OK travel, with 60D tyres you might be a bit limited.
I've put bumpstops on my Mini TRF dampers which makes them the same length as TRFs anyway! I use Sweep tyres which are 55D.
sosidge is offline
Old 12-01-2011, 05:07 AM
  #16221
silvalis's Avatar
Trader Rating: 29 (100%+)
Has anyone tried putting Sakura Zero shocks on an m05?
silvalis is offline
Old 12-01-2011, 01:20 PM
  #16222
joe c's Avatar
...I'm new to minis (just grabbed an m03)
Well, I got the body and it's perfect on my m03, but I'd prefer rwd.
I've been doing some research and it looks like thus body came on the m02 originally.
Also, are the m01 and m02 basically the same, just flipped?
and how hard is it to get parts for them?
joe c is offline
Old 12-01-2011, 02:11 PM
  #16223
tony gray's Avatar
An M01 can be made into an M02 and vice versa, it's a 5 minute job.
But...new parts are thin on the ground now as we're talking cars that are over 10 years old.
tony gray is offline
Old 12-01-2011, 03:09 PM
  #16224
joe c's Avatar
Yeah, that's what I was concluding.
Maybe I can flip an 03 or 05?
joe c is offline
Old 12-01-2011, 03:20 PM
  #16225
R/C Tech Elite Member
monkeyracing's Avatar
I've been successful this week! I've removed almost all the newer, blue things from my M-03. I've got the old gold coloured TRF dampers on it, along with the gold steering knuckles. I've returned all upper links to the solid plastic chunks from the kit, Tamiya S-grip pre-mounts all around...it's a thing of beauty and it goes like stink.
monkeyracing is offline
Old 12-01-2011, 03:22 PM
  #16226
tony gray's Avatar
Power to the Old School M03 Jim!
Joe, you cant flip an M05, but with a bit of work an M03 is possible.
Refer HERE
Old 12-01-2011, 04:00 PM
  #16227
Mr RCTech's Avatar
Would like to see it.
Do you have a picture?
Mr RCTech is offline
Old 12-01-2011, 07:17 PM
  #16228
joe c's Avatar
Refer HERE
Sweet!
I thought I saw a conversion somewhere.
joe c is offline
Old 12-02-2011, 01:51 PM
  #16229
I'll try to get some pics on Monday. Just about to start 3 days of racing! Whoo!
Old 12-02-2011, 03:02 PM
  #16230
Mr RCTech's Avatar
Great.
Good luck on your race!
I hope you win monkeyracing!
