Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-09-2011, 07:49 PM
  #15976
CSeils's Avatar
Trader Rating: 54 (100%+)
Originally Posted by monkeyracing
As with many things Tamiya, you'll need to buy the complete unit.
Not true. I also striped the threads out of my ball diff a while ago.
You can order single parts. What your looking for is "pressure plate B". I can not recall the part number at this moment, but i did send an e-mail to Tamiya and they supplied the correct number. I ordered directly from Tamiya but your LHS should be able to stock one for you.
Hope this helps.
CSeils is offline
Old 10-10-2011, 04:43 AM
  #15977
Default Swift bodyshell stickers
Ive been given a Susuki Swift bodyshell but dont have the sticker set for it. Ive trolled Ebay but cant find any. Can anyone point me toward a seller please?
scoop is offline
Old 10-10-2011, 06:02 AM
  #15978
sosidge's Avatar
Default Mini stand...
Any recommendations for a car stand that holds the not-flat-bottomed Mini securely with good clearance for the wheels?
sosidge is offline
Old 10-10-2011, 07:32 AM
  #15979
Make your own. Cut piece of wood 2 1/4" wide by approx 6" long. Glue a strip of window moulding down each side. Not the most elegant of solutions, but mine works great and certainly less costly than the anodized aluminum ones that weren't meant for a Mini.
Granpa is offline
Old 10-10-2011, 07:33 AM
  #15980
jcr
I made my own too. Got a sheet of plexi glass heat it up and bend the two sides.
jcr is offline
Old 10-11-2011, 07:46 AM
  #15981
Default M-05 Ball Differential
so im kinda new rc's
and would like to know about Ball Diff's ( is lt like a slipper clutch?)
tamiya has 2 ...... M-05 Ball Diff set and TA03 Ball Diff Set
what one is better one? why?
as a newb do i need a ball dif?
thanks from a new guy
hotrod306 is offline
Old 10-11-2011, 07:58 AM
  #15982
The TA03 ball diff gear too if it wears out?
stocker is offline
Old 10-11-2011, 08:09 AM
  #15983
No. In fact many prefer the gear diff
Granpa is offline
Old 10-11-2011, 09:07 AM
  #15984
should you stuff it full of grease ?or just to coat the gears?
im on a small track 2 sharp corners?
Old 10-12-2011, 02:53 PM
  #15985
Misiek's Avatar
Does anyone know the part number just for the bearing that comes with TA03 ball diff?
Misiek is offline
Old 10-12-2011, 03:51 PM
  #15986
oldnwise's Avatar
53136 is the thrust bearing.
You can also use other option parts that have the same 1150 thrust bearing. Part 51346 is the thrust bearing from an F103. They are the same bearing, just discard the extra parts.
oldnwise is offline
Old 10-12-2011, 08:49 PM
  #15987
R/C Tech Elite Member
monkeyracing's Avatar
Hey guys, just a heads up: I'm still hunting for the (almost useless) instructional manual for the Xevo Chariot. If you've got a decent resolution scan, please let me know.
monkeyracing is offline
Old 10-13-2011, 12:22 AM
  #15988
tony gray's Avatar
I still haven't found my (unbuilt) kit yet, which obviously has the instructions in it...
Mind you, if you saw how many kits and bits lived under my house you'd understand WHY I cant find it....
While standing doing some airbrushing last night I looked around, and I could count 25 cars/kits within 2 metres of me. Yet somehow, I still need more...
tony gray is offline
Old 10-13-2011, 07:10 AM
  #15989
SilverShelby's Avatar
I have many sets of decals they are missing window and light decals and have wing sets for it let me know
SilverShelby is offline
Old 10-13-2011, 07:30 AM
  #15990
They are the bits I need most. Thanks anyway
scoop is offline
