Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 09-19-2011, 11:06 AM
  #15766
academygaz's Avatar
Originally Posted by YankeeFan123
If I have the m03 rye Suzuki, what other bodies can I use?
Any which are 225mm wheelbase, there are a lot and the RC Mini website has a pretty big list.
Anyway, anyone fancy a Willys Hot Rod Body for their Mini?
http://www.ebay.de/itm/Willi-s-Lexan...item2567443029
academygaz is offline
Old 09-19-2011, 11:35 AM
  #15767
R/C Tech Elite Member
monkeyracing's Avatar
Nice dream, but..."Width 225 mm Approximately 265 mm wheelbase"
Translated from German Damn! I had my hopes up there for a minute. It was almost find of the day.
Y'know YankeeFan, you can always take the spacer out of the middle of the chassis to run short (210mm) wheelbase, as well. Many more body choices.
Jim
monkeyracing is offline
Old 09-19-2011, 01:48 PM
  #15768
justchris's Avatar
Originally Posted by bertrandsv87
I also think certain flag type symbols should be excluded, on top of offensive names , right M....racing !!! Please reconsider, and choose a more suitable name/flag, etc...we also have children read our posts !!!
Your mad !!!!!!!!!!!!!!
My daughter comes on here with me and finds no offence
after all its a free world
AND monkey gives good constructive advice
justchris is offline
Old 09-19-2011, 02:09 PM
  #15769
jsinclair's Avatar
I just ordered a m-05 for myself and a m-03 for the girlfriend, so we can do some carpet racing. My only real question is will standard touring car shocks work with these. If not what what is a good and reasonably priced oil shock option.
Josh
jsinclair is offline
Old 09-19-2011, 02:17 PM
  #15770
Misiek's Avatar
Josh
You could get Tamiya 54000 (around $55) or 3Racing (around $25).
I got Tamiya's and like them a lot however they are kind of pricey...especially if you are buying them for two cars.
Misiek is offline
Old 09-19-2011, 02:20 PM
  #15771
ZEe_NYC's Avatar
Trader Rating: 78 (100%+)
Josh
I asked this question a few posts back and got one vague (but decent) response.
So I went ahead and attempted to fit TC shocks on. And guess what? They fit. I used my old PRO-2 hpi setup I had. Put a 2mm spacer inside the shock body and used new Hot Bodies springs (pink front blue back) all around. I used these parts because it's what I had. Kind of made a Frankenstein m05 off of spare HPI/HB parts. Next in line will be to fit HB universals with the mini length bones on it. The HB universals fit... Already tested them. Just got to find a bone in the right length. And I'm gonna attempt to re-drill a front HB cyclone tower to fit my m05.
I'll post pics of the shocks when I get home
ZEe_NYC is offline
Old 09-19-2011, 02:21 PM
  #15772
MD
MD's Avatar
Trader Rating: 136 (100%+)
Josh
Here's one source. Someone else may have the same ones at a better price.
http://www.ebay.com/itm/3RACING-Oil-...#ht_1642wt_847
MD is offline
Old 09-19-2011, 02:35 PM
  #15773
ZEe_NYC's Avatar
front and rear HPI pro2 shocks, HB springs (tc length) pink front, blue rear. 2mm spacer inside body, zero rebound, 25wt oil, bottom shock collar tightened to end.
Attached Thumbnails Tamiya mini cooper-img_0857.jpg   Tamiya mini cooper-img_0858.jpg
ZEe_NYC is offline
Old 09-19-2011, 02:36 PM
  #15774
caltek1's Avatar
Trader Rating: 38 (100%+)
Default Mini MO3 Build
jsinclair,
I suggest you go to the attached link and read about the MO3. The shocks built this way will also work on the MO5.
http://www.rc-mini.net/joomla/index....d=44&Itemid=60
ZEe_NYC,
I use 4mm of internal spacers on normal TC shocks for getting the car lower. The shocks need to be around 55-56mm in length. I forgot to add I only use the Tamiya short springs on my shocks.
Regards,
Calvin.
caltek1 is offline
Old 09-19-2011, 02:39 PM
  #15775
ZEe_NYC's Avatar
calvin, thanks for the insight brotha. i'll check the overall length of the shocks right now.
can't wait till the new indoor track opens in my area so i can run this little bastard.
ZEe_NYC is offline
Old 09-19-2011, 02:44 PM
  #15776
caltek1's Avatar
The 3Racing carbon fibre shock tower works as well as the Tamiya offering. The main difference is the Tamiya shocktower is slightly wider and allows you to stand the shocks up as straight as a MO3. I always use the second outer hole.
For carpet racing the front shocktower makes the MO5 work better. Just my thoughts.
caltek1 is offline
Old 09-19-2011, 02:52 PM
  #15777
ZEe_NYC's Avatar
i couldn't find any stores (state side) that offered the tamiya carbon tower??
ZEe_NYC is offline
Old 09-19-2011, 02:57 PM
  #15778
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
Josh
http://www3.towerhobbies.com/cgi-bin...?&I=LXGL65&P=7
these are a cheap but a good option
the mini trfs are good to but more expensive
RaceAce701 is offline
Old 09-19-2011, 04:08 PM
  #15779
YankeeFan123's Avatar
Trader Rating: 72 (100%+)
thanks guys for all the input.
I dont really want to look through all of the bodies, or shorten the chassis. just with the rtr suzuki what are the three most popular bodies for it.
can you post links to the cheapest places to buy them. thanks
YankeeFan123 is offline
Old 09-19-2011, 04:40 PM
  #15780
you have the most popular one, the swift, next would be the abarth
stitchy is offline
