Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-20-2006, 02:45 AM
  #1561
414play's Avatar
Anyone use the HPI Civic Body on the M03 chassis? How does it fit? Am particularly interested in the front hood. Is it high enough to fit the front body post without being too high? Can the body be lowered properly? Please advise before I buy a few of these bodies. Thanks
the new m03-m fits the hpi civic body. the body posts are fine, but the wheel base you have to watch.
414play is offline
Old 05-20-2006, 12:43 PM
  #1562
Default Ball diffs and more
Will the Manta Ray ball diff work on the mini? Also would it be more beneficial to run a Front wheel drive mini or a rear wheel drive Alfa in an oval race? My friends and I are running oval with the mini's and having a blast...........I like the look of the alfa but it is rear wheel drive so I am not sure if it will work as well..........thanks
Ginsu is offline
Old 05-20-2006, 10:54 PM
  #1563
414play's Avatar
Yes the Manta Ray ball diff will fit the m03/m04 mini, as will the ta03 ball diff.
I think on an oval track the rear wheel drive m04 would be better as it is a little taller geared for better top speed.
414play is offline
Old 05-21-2006, 06:07 AM
  #1564
Thank you very much for your reply...................
Ginsu is offline
Old 05-21-2006, 04:54 PM
  #1565
Default servo saver
Does the stock tamiya servo saver that comes with the RTR's fit Futaba servos?
Ginsu is offline
Old 05-22-2006, 03:17 AM
  #1566
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Yes, there should be a peice that says "Futaba" on it.
HotrodHopkins is offline
Old 05-22-2006, 05:56 AM
  #1567
ICEMAN's Avatar
Yes the HPI civic fits the MO-3M , the NEW SWift Chassis ONly, the Civic is a 225mm wheel base, the MO-3 60's Mini, only fis the tamiya and Hpi Mini Cooper body, which is 210mm wheel base.
ICEMAN is offline
Old 05-22-2006, 06:00 AM
  #1568
jedi's Avatar
Thanks Iceman. Will order a couple right away.
jedi is offline
Old 05-22-2006, 08:54 AM
  #1569
AdrianM's Avatar
To All - We just got a shipment of Take Off Mini Cooper size RP30 and RP36 belted slicks and RP Mini Med and Med/Soft inserts.
If you want to try some have you local shop contact Schumacher or order on line at www.racing-cars.com tomorrow (the website will be updated to show new stock tonight).
AdrianM is offline
Old 05-22-2006, 11:37 PM
  #1570
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Default Spool??
Guys,
Has anyone tried to lock the diff (spool) and what did it go like or is the ball diff the best option.
Taffyjnr5
Taffyjnr5 is offline
Old 05-23-2006, 02:45 AM
  #1571
414play's Avatar
I've locked the diff with super glue before, no good for a track with tight corners as it pushed real bad and is not tcs legal. Most people run the Manta Ray ball diff. If tcs legal is not an issue and your track will allow it you could try the one way, It works real well unfortunatly the clubs near me that run mini won't allow it.
414play is offline
Old 05-23-2006, 04:13 AM
  #1572
Taffyjnr5's Avatar
OK I will try the ball diff as I am losing mid corner speed with wheelspin on the unloaded inside wheel and is killing lap times.
Taffyjnr5
Old 05-23-2006, 11:21 AM
  #1573
tamiyarcracer's Avatar
Taffyjnr5
Try using a thicker grease, or packing the gear diff with thick grease, like AW grease.
I feel that the gear diff still pulls better than a Ball diff.
tamiyarcracer is offline
Old 05-23-2006, 11:58 AM
  #1574
A link or who makes the fornt oneway for the Cooper. Thanks
tunnelhead is offline
Old 05-23-2006, 12:17 PM
  #1575
Tamiya made one for the TA02 that fit into the mini
