Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-31-2011, 12:54 PM
  #15331
PizzaDude's Avatar
Originally Posted by Fluffy622
Well i just got home with my new proline protoform panel wagon body for my M05 and holy crap is it a long body for that wheel base! The body probably sticks out 2-3in's in the front and 3in's in the back. I don't know what proline was thinking but it seems to me that the body is way to long for the car. Be cautious when purchasing.
Will it fit a M03 as well?
PizzaDude is offline
Old 07-31-2011, 01:49 PM
  #15332
Fluffy622's Avatar
It says it fits all M-Chassis cars, as long as its a 225mm wheelbase.
Fluffy622 is offline
Old 07-31-2011, 10:26 PM
  #15333
Zac_with_no_K's Avatar
Originally Posted by digitrc
The shocks are the same. NOt sure about the springs.
You need to rebuild the shocks with the 6mm spacer inside them. I would recommend getting a set of the "short" Tamiya springs, these are the right length to get good ride height on a Mini.
Thanks.
I actually have a bunch of different kinds of short tamiya springs because I accidently got them for my touring car.
I don't have to add more spacers if I use these just let the shocks compress that much and put them back on?
What hardness levels should I use? soft front medium for rear?
I also have 45 and 35 weight shock oil. would either of these be better than the stock Tamiya shock oil?
Any advice helps,
thanks
Zac
Zac_with_no_K is offline
Old 07-31-2011, 10:58 PM
  #15334
Does this fit a M05 as well? Anyone tryed one?
3Racing gear diff for M06
They have them at RCMart.
4beenevil is offline
Old 07-31-2011, 11:39 PM
  #15335
Skitee's Avatar
Your answer is ONLY 1 page back.
Skitee is offline
Old 08-01-2011, 12:19 AM
  #15336
digitrc's Avatar
Originally Posted by Zac_with_no_K
Thanks.
Any advice helps,
thanks
Zac
You use the spacers on the outside to set your ride height. Most people run the Mini with the arms level or just below.
Normally people run a stiffer spring on the front. So medium front, soft rear to start.
Shock oil is your choice and is used to tune the car. Any of those oils will be a fine starting point.
digitrc is offline
Old 08-01-2011, 01:04 AM
  #15337
caltek1's Avatar
Trader Rating: 38 (100%+)
Post #15281 on page 1019 will answer your question regarding the 3Racing oil gear diff. This fits all MO5 and MO6 mini kits.
Photos, are included in that post.
Mr Lee,
I ran the S-Spec mini on friday night at Castlehill, which is a tight technical track. I used the 1.5 degree rear hubs, with the alloy one degree rear bottom plate, giving a total of 2.5 degrees rear toe in.
I also used a ABC Mitsubishi Colt body and small 55mm rubber tyres front and rear. I also ran blue and yellow short TRF springs with a rear swaybar.
Initially the car was way to responsive, so I adjusted my radio settings and the car was way better to drive. The car had excellent corner speed and still changed direction really well. I think with a few more tweaks the car will be even better.
After running the car I checked the shocks and found that one had no oil , that would have caused some handling deficiencies. I have since rebuilt the shocks and look forward to testing again this weekend.
All in all the car was very good. I will see if I can get the car as good as my MO5LWB. I could actually get the car up on two wheels and the car was still stable when being pushed hard through corners.
Later,
Calvin.
caltek1 is offline
Old 08-01-2011, 01:59 AM
  #15338
Thanks!
Old 08-01-2011, 02:51 AM
  #15339
Originally Posted by caltek1
Mr Lee,
Later,
Calvin.
Thank for the feedback Calvin
Please keep us posted on your findings.
mr lee is offline
Old 08-02-2011, 08:22 PM
  #15340
Fluffy622's Avatar
Default New Panel Wagon Body
Here are some pics of the new proline protoform panel wagon body painted up. I just have it sitting on my M05.
Old 08-03-2011, 12:49 AM
  #15341
sosidge's Avatar
Attachment 789987
Attachment 789998
Attachment 790000
Would be really nice to see some normal sized pictures of the shell.
sosidge is offline
Old 08-03-2011, 01:17 AM
  #15342
I)arkness's Avatar
+1
I)arkness is offline
Old 08-03-2011, 02:27 AM
  #15343
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Mr_Gleeman is offline
Old 08-03-2011, 02:29 AM
  #15344
Mr_Gleeman's Avatar
Not much bigger than my avatar actually
Old 08-03-2011, 02:36 AM
  #15345
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Just in case........ Some bigger pics wouldn't go astray
Sith Lord is offline
