Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-27-2011, 07:47 PM
  #15316
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by Pirty
some mini action shots
I love this first pic! Seems so familiar...flying minis!
monkeyracing is offline
Old 07-28-2011, 12:57 AM
  #15317
digitrc's Avatar
is anybody using a rapida pro on their mini? maybe you can share your esc setup. i'm planning to use my rapida pro on my m05 with silver can motor. thanks
Good choice. Great ESC.
I run the pre-loaded setup P5. Very punchy and smooth.
digitrc is offline
Old 07-28-2011, 01:25 AM
  #15318
Trader Rating: 32 (100%+)
Can share with us about this Rapida Pro esc???
What model & where to get it (& price)...???
Thanks.
hobbs is offline
Old 07-28-2011, 06:46 AM
  #15319
caltek1's Avatar
Trader Rating: 38 (100%+)
Default S-SPEC PHOTOS
Here are some shots of my S-Spec. I have added the rest of the Tamiya alloy steering rack. I have also added alloy front knuckles, battery holders, rear swaybar, TRF M Chassis shocks, Tech racing steering rod and 3Racing oil gear diff.
The car has 2.5 degrees rear toe in, using the kit supplied items. I will give the car a test run tomorrow night. I used the black chrome chassis instead of the supplied chrome finished chassis.
There are more photos on the Aussie Mini thread.
Later,
Calvin.
Attached Thumbnails Tamiya mini cooper-dsc_0339.jpg   Tamiya mini cooper-dsc_0341.jpg   Tamiya mini cooper-dsc_0344.jpg   Tamiya mini cooper-dsc_0350.jpg   Tamiya mini cooper-dsc_0353.jpg
caltek1 is offline
Old 07-28-2011, 07:08 AM
  #15320
Pirty's Avatar
Trader Rating: 35 (97%+)
Thanks.
http://www.rctech.net/forum/electric...a-pro-esc.html
Pirty is offline
Old 07-28-2011, 09:05 AM
  #15321
Later,
Calvin.
Looking good
Is this your first time running an SWB config?
Cant wait to hear your view on the two configs and your new machine
mr lee is offline
Old 07-28-2011, 12:39 PM
  #15322
over gear's Avatar
Trader Rating: 18 (100%+)
Later,
Calvin.
does the alloy rear suspension mount add any toe-in?
over gear is offline
Old 07-28-2011, 01:18 PM
  #15323
caltek1's Avatar
[QUOTEdoes the alloy rear suspension mount add any toe-in? ][/QUOTE]
Yes it adds one degree. As pictured the car now runs 2.5 degrees rear toe and if you use the two degree rear hubs you will have three degrees in total. If you use the old zero degree rear hubs you will have one degree rear toe.
mr lee,
I have use run a SWB MO5 with a Colt body before, but only ran it on carpet for a very short period. Since then I have refined my car/shock setup, so this might work better.
Hopefully I will find out tonight. I will be taking my MO5 LWB car just in case I am not totally happy with the car, although I should just refine shocks/springs and radio setup.
Regards,
Calvin.
caltek1 is offline
Old 07-28-2011, 04:38 PM
  #15324
Fluffy622's Avatar
Default New body from Proline
Well i just got home with my new proline protoform panel wagon body for my M05 and holy crap is it a long body for that wheel base! The body probably sticks out 2-3in's in the front and 3in's in the back. I don't know what proline was thinking but it seems to me that the body is way to long for the car. Be cautious when purchasing.
Fluffy622 is offline
Old 07-28-2011, 04:45 PM
  #15325
Timbulb's Avatar
Are you using mini tires with it? It was designed to use 1:10 size tires.
Timbulb is offline
Old 07-28-2011, 08:08 PM
  #15326
Fluffy622's Avatar
I'm using mini tires and the wheelbase and wheel wells are fine. its the length of the body thats bad
Old 07-29-2011, 04:18 PM
  #15327
Zac_with_no_K's Avatar
I have spare oil filled shocks from my TA05v2 after switched to TRF's. I think they're the same size. Should I use the same spacer and spring that are on my car right now? or will I have to change how the shocks are set up?
Anything helps,
Zac_with_no_K is offline
Old 07-30-2011, 10:56 PM
  #15328
Tamiya M05s racing with open motors. The winner ran a 4.5T brushless.
I ran a 13.5T motor with turbo esc (white Miata). Casualty were blown tires and burnt motors.
But loads of fun lapping 3 secs / lap faster than a typical mini.
+ YouTube Video
Thanks for looking.
rccartips is offline
Old 07-31-2011, 12:23 AM
  #15329
digitrc's Avatar
Anything helps,
The shocks are the same. NOt sure about the springs.
You need to rebuild the shocks with the 6mm spacer inside them. I would recommend getting a set of the "short" Tamiya springs, these are the right length to get good ride height on a Mini.
digitrc is offline
Old 07-31-2011, 05:14 AM
  #15330
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Would love to see some pics.
Sith Lord is offline
