Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-24-2011, 04:03 PM
  #15166
maxepower's Avatar
Exclamation REMEMBER?
Originally Posted by Granpa
Make your own-----much,much cheaper. All they are is a 3x12 mm set screw with 5mm adjuster ends.
GRANDPA YOU GOT PM! :s neaky:
maxepower is offline
Old 06-25-2011, 12:12 PM
  #15167
Perhaps this has been asked before-does anyone know what brushless motor is the "equivalent" of a silver can motor? 17.5,21.5,25.5 or something else? Thanks, Don
DLS II is offline
Old 06-25-2011, 12:19 PM
  #15168
R/C Tech Elite Member
monkeyracing's Avatar
A 540 sized 21.5T should be fairly close to a good silver can. A 380 sized rotor (like a Hobbywing) type motor would be around a 17.5T.
monkeyracing is offline
Old 06-25-2011, 08:48 PM
  #15169
Fluffy622's Avatar
Default M05 Bodies
Has anybody ever tried the bodies from abchobbyusa.com? I like the mini countryman and the austin mini truck body. They don't say the thickness or what wheel base they require.
Fluffy622 is offline
Old 06-25-2011, 09:20 PM
  #15170
The ABCHobby bodies have 210mm wheelbase.
Sydewynder is offline
Old 06-25-2011, 09:21 PM
  #15171
Nice to see you're back monkeyracing.
Old 06-25-2011, 11:15 PM
  #15172
GreazyFinger's Avatar
i ran the mini ute ABC shell for a while , theyre quite thin in construction , i suppose if you dont crash than thats not an issue , it was a SWB shell
GreazyFinger is offline
Old 06-25-2011, 11:49 PM
  #15173
Can't keep a good man down.
Speaking of shells, has anyone ever tried an ABS Mardave shell? I know they'd be heavy, but the way I burn through mini shells, it might be worth it.
Old 06-26-2011, 01:56 AM
  #15174
tony gray's Avatar
Mardave shells dont fit Jim. The wheelbase and the width are wrong.
I used to be the Aussie Mardave importer....
tony gray is offline
Old 06-26-2011, 02:30 AM
  #15175
caltek1's Avatar
Trader Rating: 38 (100%+)
Jim,
You can always reinforce your mini body with some gyprock open weave tape,(as used on gyprock joints between two sheets), and hot glue. That way they might last longer.
Later,
Calvin.
caltek1 is offline
Old 06-26-2011, 09:23 AM
  #15176
Fluffy622's Avatar
Well I crash a lot so that would be a big problem! lol Thanks for the help. A friend of mine tried using fiber glass mesh and shoe goo. Worked great and was real strong.
Old 06-26-2011, 10:12 AM
  #15177
Craig Richter did some testing with Brushless systems here at the Tamiya USA track. I believe this is what he concluded. 21.5 is way too slow. 17.5 is better but was a bit slower. Hobbywing was like the Blackcan or Sportuned motor. Also Tony and his group did some extensive testing and came similar findings.
Personally, I like the Hobbywing the best.
Granpa is offline
Old 06-26-2011, 01:09 PM
  #15178
Fluffy622's Avatar
Which hobbywing are we talking about? Ive been looking for a brushless motor for my M05 recently. Part#?
Old 06-26-2011, 01:57 PM
  #15179
I suppose I forgot to mention that my club, karz.ca, has chosen our replacement for silver cans. We've decdied to go with the new Orca Q Spark ESC and 17.5T combo. The motor is built like a Hobbywing, with a 380 sized rotor in a 540 sized can.
We had them spec'd to 2300kv, so they're dead on with a regular, non-mutant, non-cheatin' silver can. The torque is the hardest thing to get used to. It's instantaneous and the motor pulls hard to it's limit.
The reason we went with 17.5 rather than 13T has to do with our track. Running on a tighter, stickier carpet surface, with a RWD dominant field required that we slow it up a little. If we had a large outdoor track and lots of guys running FWD, the HW 13T would have likely been our top pick. It's a great system and the price is positively unbeatable. (Unless you're shopping for shanzhai!)
Jim
Old 06-26-2011, 07:46 PM
  #15180
Zac_with_no_K's Avatar
Exclamation
+ YouTube Video
I'm wondering if there's something wrong with my speed control or something? It randomly started doing this and I thought making a video of it would be easier than typing out whats going wrong.
Notice the tansponder light blnks or dims when problem occurs
Also, the light on the Futaba receiver turns from green to red or orange when the problem occurs.
In the video all I do is turn all the way right or all the way left. 1 throttle on accident.
The throttle also lags along with the steering when the problem occurs.
Any advice helps,
Thanks.
Zac_with_no_K is offline
