Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-06-2011, 03:03 AM
  #15076
crabboy's Avatar
Trader Rating: 58 (98%+)
Hard to go past this web site
http://www.rc-mini.net/joomla/index.php
Built my M03 as they said on the site and it is faultless, as i got told the other day, TYRES are everything on a mini, hope this helps.
Rhys
crabboy is offline
Old 06-06-2011, 04:46 AM
  #15077
IndyHobbies.com's Avatar
Thanks for the tip Rhys
IndyHobbies.com is offline
Old 06-06-2011, 05:37 AM
  #15078
caltek1's Avatar
Trader Rating: 38 (100%+)
IndyHobbies.com,
The lower you can get all of your electronics on the car the better. Most guy's put the reciever and ESC into the rear of there MO3's.
The other thing is to make sure you have the car slammed to the ground. Max ride height of 6mm or lower. I run no more than 5mm most of the time.
Here in Australia the MO3 and MO5's are as fast as each other and comes back to driver preference, car setup and tyres. We do not have to use Tamiya 60D size tyres and the majority of us use 55mm tyres. A good combination is Ride 3035 front and Cross 36 rear. However in the USA to be TCS legal you need to run the Tamiya S grip tyre.
I think you would be better of getting advise from Granpa or other US based mini drivers. Replacing your shocks and springs will also assist with dropping your ride height and making the car handle better. Run 0.5-1mm toe out and be smooth on the steering input.
Just my thoughts. Others will offer more advice. The rc-mini site is very good, but more aligned to what we run here in Australia and suited to our different grip tracks.
Later,
Calvin.
caltek1 is offline
Old 06-06-2011, 07:21 AM
  #15079
Tim K's Avatar
Originally Posted by IndyHobbies.com
I bought a "like new" M-03 on ebay.
I learned that "everyone" uses aluminum steering blocks, so I will get those. Other immediate suggestions for hop ups? It was fun to race! But, the guys with the M-05's and M-06's were faster. No question.
From what I can see in the photo, I would suggest buying the following parts:
54177 (you'll need 51238 for the C-hub to suit), 54178, 54000, 53267, 53597, 54120 with 51000, not sure which servo you have, but a decent one would help. Are you running lipo batteries? if not then buy some, if you have some then consider adding some lead to the front bumper and front half of the chassis - see rc-mini.net article.
Apart from that, if you have ball bearings already, then wheels and tyres are going to make a big difference too, just depends what surface you race on - carpet or tarmac.
With all of that sorted you should be able to take on the M05's and M06's
ps. great to see a Scion body! haven't seen one on any of the tracks in Oz yet.
Tim K is offline
Old 06-06-2011, 07:26 AM
  #15080
Misiek's Avatar
I bought a "like new" M-03 on ebay. Came with everything pictured but the RX, ESC and battery. I raced it last week at RCAR Indy.
I had fun painting two bodies for it too using Faskolor paints and my airbrush. The Honda Civic R from HPI and HPI's Scion body. The Scion is key lime green with an undercoat of neon green, then white. It really pops!
I really like your Honda Civic-I'm planning on getting the Honda Civic from HPI as well.
Misiek is offline
Old 06-06-2011, 10:01 AM
  #15081
i have the honda civic shell.. alittle battered as its my practice shell and learning shell but it is pretty stable.
pokiou is offline
Old 06-06-2011, 01:32 PM
  #15082
The M03 is every bit as fast as the M05 on the medium to low grip asphalt tracks. Also the 03 is a little easier to chassis tune and behaves a little more predictably to changes. For most new to Mini racers the M03 is the better choice. you'll be pleased with your choice.
Couple of general suggestions would be to not run the car too low. The 03 likes softer springs and lighter shock oils so you might start with 40wt oil, 3 hole pistons. The stiffest springs would be new reds in front and maybe new yellows in back. A rear sway bar is also very beneficial in smoothing the car out. A softer set up would be old reds up front with new reds in back.
For higher grip tracks like carpet or hi grip asphalt, the lower cg of the 05 can be a big benefit.
Granpa is offline
Old 06-06-2011, 01:44 PM
  #15083
Robs Pics is offline
Old 06-07-2011, 04:05 AM
  #15084
tony gray's Avatar
ABC Gambado (or GRID in the US) electronics mocked up, should hit the track very soon... Its an intriguing car. And yes punters, it comes with an oil-filled gear diff as standard!
Full review as soon as it stops raining!
tony gray is offline
Old 06-07-2011, 04:15 AM
  #15085
TFG,
Doing a review soon? Car looks like it has friction shocks and an HPI switch like suspension setup.
Sydewynder is offline
Old 06-07-2011, 07:42 AM
  #15086
Hello Guys!
I'm looking tire for my Tamiya GB-01, which uses the same wheel size as Tamiya mini series. (inner 1.5" / 38mm, wide 1" / 25.4mm)
Which tires do u using with the mini series? I want to play on asphalt/concrete, and iam looking for a "long-life" tire.
herK is offline
Old 06-07-2011, 09:39 AM
  #15087
skadoosh's Avatar
English version of the M05 s-spec video from tamiya
http://www.youtube.com/watch?v=AM4uKx6zn5o&
skadoosh is offline
Old 06-07-2011, 11:44 PM
  #15088
ska_seattle's Avatar
Trader Rating: 62 (100%+)
Default esc for M03
Can anyone give me an idea of a good esc to use when running a silver can in tcs racing....
The rules say you can run any esc but I am not sure what to use???
I would like to use lipo...
I have an old LRP F1 pro reverse (270A - 1sec,100A-30sec,55A-contin.)
Is that to much of an old school esc to use???
Thanks.
~SKA
ska_seattle is offline
Old 06-08-2011, 04:13 AM
  #15089
Shangrila's Avatar
What date is the S type due to be released? And does anyone know the part numbers for the new items - shock tower etc?
Shangrila is offline
Old 06-08-2011, 05:20 AM
  #15090
caltek1's Avatar
I hate double posts. Doh
caltek1 is offline
