Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-24-2011, 03:29 PM
  #15001
R/C Tech Elite Member
monkeyracing's Avatar
Neato! Silver! Stuff!
All sarcasm aside, I do like the transponder mount thingy. Good place to counterweight the motor. Also, don't you sometimes wish that the chassis were all done in a lighter colour, so when you're doing assembly it didn't look like a shapeless, depressing black mass? (must be time for my meds)
monkeyracing is offline
Old 05-24-2011, 04:48 PM
  #15002
Misiek's Avatar
Originally Posted by Timbulb
Tape works better than the plastic brackets. Touring cars use it too.
Could you educate me on what kind of tape is it?
Misiek is offline
Old 05-24-2011, 05:07 PM
  #15003
superspeed's Avatar
fiber glass reinforced tape, example: http://www.tamiyausa.com/product/ite...oduct-id=53170
superspeed is offline
Old 05-25-2011, 09:25 AM
  #15004
Default #54000 M-Chassis Shocks
Hi guys,
Got another question for you Mini experts.
I'm building the shocks for my M-05 PRO, I'm using the #54000 M-Chassis Shocks.
My question is how do you set droop in these shocks? Do I use rubber o-rings or are there proper plastic spacers? And I assume that whatever I use to adjust droop is placed between the piston and the bottom of the shock body?
Thanks for any help you can give.
Joe_Keaveney is offline
Old 05-25-2011, 10:24 PM
  #15005
spring71's Avatar
Smile
Hello Mini Racers.
Ride High Speed Gear Set is arrived.
Click Here to check out the new arrivals.
Click Here to check out the parts for Mini
Thanks.
spring71 is offline
Old 05-26-2011, 06:42 AM
  #15006
Shangrila's Avatar
Is anyone using a Gens Ace hardcase lipo in an M05?
None locally so I can only buy on the 'net. The photos of the 3500 and 4000mah are difficult to make out if the case is rounded enough or more of a square.
I've emailed vendors with no success. Thank you if you can comment
Shangrila is offline
Old 05-26-2011, 08:47 AM
  #15007
Trader Rating: 17 (100%+)
Default These fit.
If you are talking about these:
hobbypartz.com/98p-25c-4000-2s1p-hardcase.html
hobbypartz.com/98p-25c-3500-2s1p-hardcase.html
Yes, they fit both the M05 and M03. I have both of them.
I use the strapping tape described a couple of posts back to put the battery at the right place because the wires protrude on the side of the body when using the normal battery mounts.
colhazard is offline
Old 05-26-2011, 08:57 AM
  #15008
Trader Rating: 32 (100%+)
In a recent race (which only silver can motor was allowed, open esc, lipo was allowed), my M03M was set up with a silvercan motor, Futaba M330CR & a lipo 3300/25C.
Unfortunately, my car was so slow compared to others.
I have no idea what esc the others were using.
Any recommendation on what esc to use???
(I was told that the Futaba M330CR is not power enough).
Right now, I am thinking of using TP-M8.
What do you guys think???
hobbs is offline
Old 05-26-2011, 09:03 AM
  #15009
Originally Posted by spring71
Hello Mini Racers.
Thanks.
You have a PM
Granpa is offline
Old 05-26-2011, 10:19 AM
  #15010
spring71's Avatar
Smile
Originally Posted by Granpa
You have a PM
I got it.
Thanks.
spring71 is offline
Old 05-26-2011, 10:56 AM
  #15011
Shangrila's Avatar
Thank you very much this is such a great thread/community
Any preference between the two? I notice the 4000mah is slightly smaller/better packaged.
Old 05-26-2011, 11:07 AM
  #15012
The 3500 has a smooth rounded shell and no wavy bumps under, just a bit lighter and hobbypartz has it on sale now for $18. I only bought it because the 4000 was out of stock and I was impatient.
I'd get the 4000 again because it's a small difference in price and additional run time. Also the wavy bumps fit the chassis holes on the TA05 and TB03 battery side if you have those RCs.
Had to solder dean's/t plugs to both of them though, they came with the bullet plug type.
There's also a hobbypartz coupon code for 5% off, "hobbymodel".
Old 05-26-2011, 03:10 PM
  #15013
Shangrila's Avatar
Thanks very much, great info and thanks for for coupon info
Old 05-26-2011, 03:34 PM
  #15014
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default Hobbypartz coupon
It's expired! Anyone have a picture of the Gens Ace 25c 3500mAh battery on their M-Chassis, with the body installed? I want to see how much the wires make the body bulk out. I was also thinking about getting the Intellect stick pack w/bullet connectors, but I'm not sure if the M-03 quick release battery holder will clear the bullet connectors. Can somebody chime in on this?
gtfour93 is offline
Old 05-26-2011, 03:41 PM
  #15015
The quick release battery holder won't clear bullet connections in batteries. You could use the quick release at one end and a regular battery holder at the other. I've done this before and it worked well.
Jim
