Old 08-04-2004, 07:24 PM   #676
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
keithander, yeah man, you're right. the si is such a nice car. i'm not sure why it never took off. the type t seems the most popular, and like you said, even that information is scarce.
robk, i'm foolishly counting the days. i can honestly say, i can find nothing wrong with it. it is a near manifestation of my thoughts. the diffs look heavy, but a losi 41t should swap out if we up the layshaft from 21 to 22 teeth to make up for the difference. that's based on the assumption that the pullies have not changed from the assassin. sure, i'm mildly sick.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-05-2004, 03:09 AM   #677
Hey seaball....
The si is working well for me but I have found a few flaws now... The upper deck is easy to break with a good hit (I have trashed 2 now) and the diff rings slip against the outdrives. CVD's wear quick too.
Apart from that it has been fast and I have already had a good victory (mod) against drivers of calibre (here in oz anyway). The best change I made was using the front suspension mount on the rear! Better overall grip with 30wt oil and shocks mounted inboard.
I too am looking at the new corally, simply because I would like identical f/r suspension geometry and better quality in the components (MIP CVD's with blades will be great!) Just trying to find a decent adjustable shock to use on it (No evil x-ray parts on my cars). Anyone know parts numbers for the serpent adjustable shocks?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-05-2004, 04:26 AM   #678
Dragonfire, the xray shocks are an evolution of the serpent shocks, and are much better. the only other adjustable shock i know if is the CRC ones, i believe they are made for the TC3 but should fit any tourer, no idea on pricing etc
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-05-2004, 07:53 AM   #679
seaball's Avatar
i've got a set of serpent shocks i'll sell for cheap off of a corally c4.1. infact, i'll sell the whole car for almost nothing.
lmk.
it's good to hear of your success with the atlas car. i have not put my si on the track. i never found a diff for the front of it.
and yes, the identical geometry is an attractive attribute of the corally. it will be an awesome car, but the diffs look heavy. i know the assassin ones were, and these look the same.
Old 08-05-2004, 04:25 PM   #680
robk's Avatar
Trader Rating: 22 (100%+)
After assembling the diff, putting glue on the *** back side *** of the diff rings where they meet the outdrive can help to prevent slip. This is by no means a perfect fix, but you can give it a try.
The Atlas cars have both great ideas and huge annoyances. I wish that I spoke Japanese so I could write scathing letters of praise and fury........
Old 08-06-2004, 03:50 AM   #681
I did glue the diff rings to the outdrives (delrin) and I roughed up both before hand. It held very well for a while but to test my diffs, I try to rotate one wheel while locking the other and the spur. This caused the glue to fail if I pushed it a bit hard... but I can't avoid it as the diff has to be set right....
The diffs would be better if they had a flat edge somewhere on the inside of the rings so they couldn't slip.
Hi brad: sorry but I will always maintain an x-ray free zone in my garage.... Just trying to find a modern adj shock so I can get spares/replacements when required. Will look into the crc ones tho.... thanx...
Powered by Falco
Old 08-06-2004, 06:58 PM   #682
robk's Avatar
Another idea might be trying to "pin" the diffs. this involves driling a small hole into the outdrive so a small rod can be inserted into the outdrive . The thing is the diff rings need to be notched so the end of the rod will keep them from rotating. That's the hard part.
A lot of 1/10 pan cars used to use this.
Old 11-21-2004, 12:22 PM   #683
Default New Atlas - YM34 type Si II
Seems to be a new Atlas on its way!
From what I can make out it looks like a lot of new parts compared to the old Si version - new bulkheads, new 3 piece top deck, new battery mounts/bar etc. The motor also seems to be mounted further forward.
Anyone know anything else about the car? Is there a front normal diff available? Release date?
keithander is offline   Reply With Quote
Old 11-21-2004, 08:01 PM   #684
ausracer's Avatar
they had lots of cad pictures in rcworld and rcmagzine, the car looked very nice but no info on release date. also from the cad pictures the topdeck is one peice not three.
ausracer is offline   Reply With Quote
Old 11-22-2004, 12:12 AM   #685
There's a download to the instruction manual here....
manual
looks like the top deck has a separate part over each of the bulkheads.
Old 01-23-2005, 06:18 PM   #686
loopedeloop's Avatar
Default has anyone used the new si2 yet
Hi Guys
I'm loking at getting an si2 or trf415 and was wondering ........
Which is the better car , what are the drawbacks of the new si2?
Your comments would be appreciated
cheeers
loopy
loopedeloop is offline   Reply With Quote
Old 03-05-2005, 11:26 AM   #687
hey guys i'm hopping you can help a newbie out. I have theoption to purshase an atlas ym34t. is this a decent car for ashalt. i'm looking for a good comp car for our summer racing. I've narrowed my choos to a tc4 hpi rs4p or maybe this cause the price is right. let me know please
cyrrus is offline   Reply With Quote
Old 03-05-2005, 11:47 AM   #688
Suspended
racingkd's Avatar
Send a message via MSN to racingkd Send a message via Yahoo to racingkd
guys around here arent liking there there tc4's much
racingkd is offline   Reply With Quote
Old 12-18-2007, 06:16 PM   #689
robk's Avatar
ATLAS
Old 12-18-2007, 09:54 PM   #690
Din Viesel's Avatar
Originally Posted by robk View Post
ATLAS
Rob you still running your Atlas?
Din Viesel is offline   Reply With Quote
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New Atlas YM34CE touring chassis? seaball Electric On-Road 36 04-16-2004 11:27 PM
Team Atlas YM34 stradith Electric On-Road 6 03-24-2004 01:11 PM
atlas type t for sale with cyclone purple label and... seaball R/C Items: For Sale/Trade 14 07-14-2003 02:53 PM
