Old 03-06-2004, 04:02 PM   #661
R/C Tech Charter Subscriber
Default delrin
I've also had problems when using delrin with trying to tighten the diff as it just seems to slip....anyone else noticed this?
keithander is offline   Reply With Quote
Old 03-06-2004, 11:29 PM   #662
ausracer's Avatar
has anyone heard more news of the new atlas shaft drive, maybe some prototype pics. they anounced it a while ago maybe they arent continuing?
ausracer is offline   Reply With Quote
Old 03-06-2004, 11:42 PM   #663
seaball:
Yeah i agree.. delrin is the only way to go... rotating mass on your drive train makes a HUGE difference to your acceleration. I have seen many other cars have probs with slipping diffs but none of them where glued.
ausracer:
I hope that it nevers goes forward and they keep producing belt driven cars. If you like japanese cars and shaft drives.. get a barra or pro 4.
Dragonfire is offline   Reply With Quote
Old 03-08-2004, 05:24 PM   #664
macaofriend's Avatar
Trader Rating: 19 (100%+)
Default YM34 T and V3 for sale
Hi, I have a YM34T for sale. It's 1 season old and I am going to do offroad now so I am selling it. I have pics if you want them. Just email me macao_friend @ yahoo.com for them.
Also, it includes a brand new YM34 V3 as a parts car. You can put it together since this is a brand new kit, I bought it together with the T because I know my LHS doesn't carry Atlas stuff.
Anyway, both cars shipped, $170.
macaofriend is offline   Reply With Quote
Old 03-18-2004, 02:58 AM   #665
Hi guys...
Has anyone used the high roll centre suspension mounts on their type t or si yet????
the front one is called u2 and the rear a u3.
seaball: i have made an order from rainbowten.. will let you know how it goes. ordered some stuff that is not listed on integy or rainbowten website.
Old 03-18-2004, 06:39 AM   #666
seaball's Avatar
Send a message via Yahoo to seaball
dam,
i didn't even know there was a u2. that would be nice if it were 0* kickup, as well as, the higher roll center. i have the A and the U3, but a B and U2 would make nice compliments. i would acutally use the U2 in rear as well, to reduce toe if the conditions called for it.
actually, using the U3 up front reversed would give antidive, and some inboard toe out. that might be fun since i have found this car to generally not be very aggressive from entry to apex.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-19-2004, 05:34 AM   #667
I order the 1 degree rear uprights to bring total toe in to about 1.5 degrees. the standard toe in is 2.5 degrees (according to my setup station).
Will wait and c what the U2 looks like.. might be good for the rear. Part No. for U2 is ym8-351 (front sus mount type F0-U2)
I have also raised the front uprights up with one spacer below and one above. you need a different set of screws to do this but it seems better so far.
Any advice where to buy novak brushless on-line???
Old 03-31-2004, 08:52 PM   #668
Got the new high roll center suspension mounts. They raise the inner hinge pins 2mm both front and back.
Also have the delrin outdrives and they are 17g lighter than the steel ones so hello to more punch.
Took 1 1/2 weeks to get order in from rainbowten even tho they didn't have the parts in stock. not bad i think. way cheaper than integy too.
Will let you know how it goes with after the weekend (1 race meet on rubber and another on foam to test it all out)
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Old 04-22-2004, 12:43 AM   #669
Hi,
Can anyone tell me the different between using high roll center mount on the front and using 2mm spacer to raise the upright?
Rhes4 is offline   Reply With Quote
Old 04-22-2004, 04:40 PM   #670
seaball's Avatar
not much difference at all, but...if you run the camber link off of the kingpin, using the spacers under the hub will give you more room above the carrier for a ball end. and you won't have to spend the $ for the block.
Old 04-22-2004, 05:51 PM   #671
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Seaball is my hero!
J_Longbrake is offline   Reply With Quote
Old 08-04-2004, 01:43 PM   #672
Default Atlas Si
Anyone know where to get a manual and some set-ups for the Si?
Old 08-04-2004, 03:06 PM   #673
seaball's Avatar
Thumbs down
i think there is less information about this car, than any other sedan chassis ever made. i don't know why, but there is about 10x the information for the type t. go figure.
on a side note, i will likely have one of these for sale here if corally, meets their anticipated september release date. it's got a few goodies, is in good shape, and will be very affordable.
sorry i was not more help to you.
Old 08-04-2004, 03:33 PM   #674
Default Si
That's ok Seabal, you've been a great help in the past with the Type T. There's even very little info. on the Miawahobbies website for the Si and no other sites seem to mention them!
Old 08-04-2004, 03:49 PM   #675
robk's Avatar
Trader Rating: 22 (100%+)
MUUAAAHAHAHAHAHAAHA!!!!!!
The Corally lives!!!!!!!
RUN FOR YOUR LIVES!!!!!!!!!!!!!!!1
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New Atlas YM34CE touring chassis? seaball Electric On-Road 36 04-16-2004 11:27 PM
Team Atlas YM34 stradith Electric On-Road 6 03-24-2004 01:11 PM
atlas type t for sale with cyclone purple label and... seaball R/C Items: For Sale/Trade 14 07-14-2003 02:53 PM
