Old 03-02-2004, 03:27 AM   #646
Originally posted by robk
Hpi shafts should fit fine and will be longer. Also yokomo gas car springs might work for you.
how long are they unloaded?
Dragonfire is offline   Reply With Quote
Old 03-02-2004, 03:41 AM   #647
JohnA's Avatar
Dragonfire
I have found that the car handles best with a softer set-up, the Atlas purple springs are quite hard though, I'm sure you wont want anything stiffer. What I have done is made some heavy sway bars, 1.2mm front & 1mm rear this stops the car leaning too much in the corners.
I run purple atlas up front and blue (kit) rear springs.
JohnA is offline   Reply With Quote
Old 03-04-2004, 06:46 AM   #648
Yeah i have laso wanted heavy swaybars but I haven't been able to buy the rear kit cause integy's website is not up to date!!!!
Wish i could speak japanese.....
Old 03-04-2004, 07:56 AM   #649
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default parts
hey dragon, john a,
i am finally getting ready to get my si out of the lab, and onto the ozite.
i need a few things first. parts. dragon you talked about getting some susp blocks and whatnot. did you ever get that stuff? if so where from?
here's what i need.
- u3 block
- b block
- delrin out drive set
- f/r arms
john, dragon, tell me where to go, because the integy site is a p.o.s and they won't answer the phone. oh yeah, and the prices are absurd.
help. thanks.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-04-2004, 08:36 AM   #650
JohnA's Avatar
Seaball
Email rainbowten www.rainbowten.co.jp, they dont have Atlas parts listed but get a delivery from Miwahobby weekly so they can get what you need, prices are about 50% of Integy.
Dragon
Make yourself some swaybars, get some 'music wire' from a hobby shop and bend them to the same shape as your original bars. Costs about 50c per metre!!
Old 03-04-2004, 10:33 AM   #651
seaball's Avatar
john,
have i told you, lately, that i love you? - rod "the bod" stewart.
seriously though, thanks. i've heard they are kind of lazy in getting back, but we shall see.
i'll give it a shot.
Old 03-04-2004, 02:31 PM   #652
Default Type T on the Integy Weight guage
I've read in the past on this forum that the left/right weight distribution is way out on the type T.
Having just checked mine on the Integy weight guage I found that each corner was pushing equal weight giving a cross weight percentage of exactly 50%.....
Does this sound right, am I doing something wrong?
The car was fitted with 3300 GPs, KO 2143 servo, Monster Stock motor, KO 301 receiver with 30g (just over 1 oz)of weight added to the servo to meet our 1500g (3.3 pound) weight limit.
keithander is offline   Reply With Quote
Old 03-04-2004, 07:23 PM   #653
Originally posted by JohnA
Seaball
Dragon
How do i order stuff from ranbow10 if they don't have it on the site?
Will look for some wire for those stabilisers.. can't stand a car without em.....
keithander:
You might have balanced the car with the weights you put on. The type t has the battery near the middle i belive so it shouldn't be to far out to begin with.
Old 03-04-2004, 07:29 PM   #654
Default Re: parts
Originally posted by seaball
hey dragon, john a,
here's what i need.
- u3 block
- b block
- f/r arms
I am after the delrin outdrives too... Want to make car lighter...
Also would be nice to find a ti screw set as well and some ti turnbuckles. must look for these....
Old 03-05-2004, 05:58 AM   #655
Dragon,
open miwahobby site and press Japanese page on the top left hand side on the page. Translate it using altavista or just look at the picture and get the parts no. and give the parts no. to rainbowten
Rhes4 is offline   Reply With Quote
Old 03-05-2004, 08:47 AM   #656
seaball's Avatar
dragon,
control centre has most of what i need. i still can't find the delrin dif outs. get me a set too, if you locate them. haha.
let us know if you do find them at rainbow ten. i have them for the rear, and they are awesome. worth every penny. now i need them for the front, as we really don't run oneways on carpet.
cheers
Old 03-05-2004, 09:51 AM   #657
Default delrin
guys - i found the delrin fragile on our indoor track so went back to the kit outdrives....
Old 03-05-2004, 09:08 PM   #658
I'll have a go at ordering by email and i'll let you know how i go....
Just out of intrest.. I have found this car to rival the pro3 for direction change performance. What does everyone else think??
I am told that tamiya make their hard tuned springs in a short version. Must have a look for that as the normal ones are only a little to long.
Old 03-06-2004, 11:31 AM   #659
JohnA's Avatar
Dragon
I'll back up Keith (he's my brother) and say dont bother with the delrin outdrives they are expensive and dont last vey long before they start slipping. Also get the Atlas short purple springs they are as stiff as you'll need.
Running my Pro-4 tomorrow, bet I'm back to the type-T for heat two
Old 03-06-2004, 02:05 PM   #660
seaball's Avatar
i'm going against keith...haha. he's also my brother too...what?, . no, but really, i've used acetal (delrin) outdrives on other cars, without any real problems. this a very slippery material, so gluing the rings with ca is usually a requirement. no big deal, as it can be chipped back off when you rebuild.
and as long as the bones are inserted the correct distance into the outdrives, and an anti-spreading retainer clip (integral to the atlas design) is used it's tough to hurt them. most plastic outdrives are ruined by the cvd bone exceeding the travel allowed by the outdrive. use external limiters on the shock shaft, and that usually does the trick.
the diff action keeps the joint from seeing the large impacts that a oneway can bring. it will just break loose upon impact provided the other side isn't seeing the same force(s).
aside from hardened steel, which wears the steel cvd pin flat anyway, delrin wears less than any other material that our industry uses for outdrives. the beauty of the atlas outdrives is that they are machined. they run very true, are tons lighter than steel, and also run quiet as the vibrations in the bearings are slightly dampened by the plastic.
properly done, acetal outdrives should provide for plenty of usable life. i'm actually looking to use irs cvd's with this car. the one's that have the plastic pincushion. the pin cushion is .094, but the slot for the atlas drives is only like .082. that will actually allow me to file a small flat on the bones. plastic to plastic contact with increased surface area on the pin. if this works the car should see almost zero backlash for it's lifetime. and the best part is that the bones are like $12 for 4. i think this configuration should hold up for 27t stock racing.
my $0.02
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New Atlas YM34CE touring chassis? seaball Electric On-Road 36 04-16-2004 11:27 PM
Team Atlas YM34 stradith Electric On-Road 6 03-24-2004 01:11 PM
atlas type t for sale with cyclone purple label and... seaball R/C Items: For Sale/Trade 14 07-14-2003 02:53 PM
