Old 07-18-2002, 08:21 PM   #256
TRF414M's Avatar
I just got my Type Si yesterday. There are lots of modificatiion from Type T. Mainly for the top deck is a lot more flexible than type T. This time they use two short shocks in front and two long shocks in rear. New type of steering post.
TRF414M is offline   Reply With Quote
Old 07-18-2002, 08:42 PM   #257
AO
AO's Avatar
Problem problem, a lot of type T parts cannot be used for the type SI
AO is offline   Reply With Quote
Old 07-18-2002, 11:28 PM   #258
TRF414M's Avatar
Yes. This is correct. By looking at the car, they used a lot of heavy duty items.
I am checking right now whether I can use Comet quick shock change screw set for this car.
Old 07-26-2002, 03:45 PM   #259
gospeed's Avatar
I didnt know they were doing a new car...does anyone have any pics??
Also, Does anyone have a rollout or gear ratio for running a 9x2 on a rather large parking lot?? Any inputs would be great
gospeed is offline   Reply With Quote
Old 07-26-2002, 08:08 PM   #260
The new SI is nice. It has weight moved to the left. The new tranny has an almost perfect circular path for the rear belt and allow the use of much smaller spur gear. The SI has more out of the corner torque and top speed than the Type T. The overall CG is lowered. New steering bell crank puts out a lot more torque to the steering blocks without any end play either side. Also new are stronger, lighter shock towers, longer upper camber links, higher rear roll-center, new oversized front one-way.
integyarthur is offline   Reply With Quote
Old 07-26-2002, 10:07 PM   #261
TRF414M's Avatar
Si is limited edition. If you want to see the pictures, you can go to Atlas Website and take a look at it. You need to put 10-20 grams of weight on the left side to reduce the difference for left and right steering.
Old 07-26-2002, 10:21 PM   #262
TRF-Powered's Avatar
what's the website for Atlas??
TRF-Powered is offline   Reply With Quote
Old 07-27-2002, 01:02 AM   #263
www.miwahobby.co.jp
Old 08-01-2002, 04:15 PM   #264
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Does the new SI come with front and rear sway bars? The car looks AWSOME..I hope to god its not a limited piece..If so I'm in trouble..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 08-01-2002, 05:26 PM   #265
gospeed's Avatar
Am i blind??...im not seeing the new car on the website I love my Type T so this car better bring alot to the table
Old 08-01-2002, 08:20 PM   #266
http://secure400.automatedshops.com/...57102096129.bc
Copy and paste that link..Its on Integys site now..A few other ?? I thought of is..How about the aluminum 2 deg rear hubs ,aluminum front knucles/steering block?
Old 08-01-2002, 08:34 PM   #267
AO
AO's Avatar
Yes, It comes with sway bars
but it only a limited production.
Old 09-08-2002, 09:33 PM   #268
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the new car still has no droop screws. is this true? man, it's a masterpiece, but uhhh, what's up with refusing to drill some holes in those arms? am i just missing something? later.
seaball is offline   Reply With Quote
Old 09-09-2002, 08:40 PM   #269
AO
AO's Avatar
I think they just want you to use the spacer in the shocks to control the droop. For me i have no time for that i just drill my own holes.
Old 09-10-2002, 01:39 AM   #270
seaball's Avatar
you've never broken an arm as a result? they seem fairly light. not stock, but i can't see where there's room for droop screws. of course you can use like 4-40 or something really small.
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New Atlas YM34CE touring chassis? seaball Electric On-Road 36 04-16-2004 11:27 PM
Team Atlas YM34 stradith Electric On-Road 6 03-24-2004 01:11 PM
atlas type t for sale with cyclone purple label and... seaball R/C Items: For Sale/Trade 14 07-14-2003 02:53 PM
