Old 05-15-2002, 10:47 PM   #211
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
anyone have a type t that they will sell me? i see this thread is kink of dead. much like the kyosho touring one. oh well, i still like the car. i hate saddle packs. that narrowline chassis is a nice layout. let me know.
[email protected]
seaball is offline   Reply With Quote
Old 05-15-2002, 10:56 PM   #212
ernestf's Avatar
Send a message via ICQ to ernestf
seaball, i am waiting for the YM34 Type Si now
ernestf is offline   Reply With Quote
Old 05-16-2002, 12:16 AM   #213
seaball's Avatar
Post
yeah, i got word that there's a new one on the block. looks real similar to the t from the solid modeling that i saw. keeping the sidexside config. props. you guys gonna sell me the type t cheap to help our efforts?
Old 05-16-2002, 07:44 AM   #214
ernestf's Avatar
Type Si layout is more or less the same as MR4TC SP, but in more expensive and long lasting material. However, it is going to be limitied production only. No way for me to give up my Type T, plus, I just get the alloy servo saver + steering posts !
Old 05-19-2002, 09:10 PM   #215
AO
AO's Avatar
Does anyone know when the SI will be coming out.
AO is offline   Reply With Quote
Old 05-24-2002, 11:56 PM   #216
rcruv's Avatar
I heard that it would be June.
Does anybody know the sizes or the product numbers of bearings used in front/rear hub carriers (knuckles)?
I want to check if I can use them for barracuda.
Thank you in advance.
rcruv is offline   Reply With Quote
Old 05-25-2002, 12:34 PM   #217
v12xc's Avatar
Did anyone notice that rear shock tower is misalignment left to right... So if you set same lenght shock.... you'll get difference
arm drop.????
And the front knuckle wont stay on tight corner ..always wobble...Please help ...I neeed more steering...
How you guys change rear anti-squat ????
My alum. centre pully also wear quickly .....
v12xc is offline   Reply With Quote
Old 05-26-2002, 02:53 PM   #218
robk's Avatar
Trader Rating: 22 (100%+)
rcruv: I think the barsings are 5x8, like std. Tamiya size. I'll check.
v12xc: On the rear tower, I have not checked that. I did drill droop screw holes in all 4 arms, so the tower makes no difference to me. You may want to try that.
You might want to try a very small dab of thread locker on the screws for the knuckle. that helps a lot.
The anti squat cant be changed unless you have a custom part made. However, you could try a front arm mount on the rear. The front is identical except for the abscence of toe in. No inboard toe in means no arm sweep, and this should free up the car a lot.
What's your setup? Maybe there's something there you could use to get more steering.
Old 05-26-2002, 04:41 PM   #219
AMGRacer's Avatar
I have anti-squat in the rear of my YM34. Use the alloy lower blocks and put shims under the blocks. I use a 2mm shim under the farther back block and 2 x 2mm shim under the other block and it angles the rear hingpins upwards towards the front of the car.
AMGRacer is offline   Reply With Quote
Old 05-26-2002, 04:43 PM   #220
AMGRacer's Avatar
I ran my Atlas YM34 for the first time yesterday. I am normally a full time 200mm gas driver and it was set up for my by a friend. Wow I was instantly on the pace of stock class using a Green Machine 3 motor and 2000 cells. This car has unlimited steering and just keeps incredible corner speed. I was actually using some worn rubber tires and cornering as fast as guys on foams. Amazing car and great setup, thanks Manticore
Old 05-27-2002, 04:26 AM   #221
opel92's Avatar
Ditto to that statement............... my car was not quite as set up as AMG's but i was still having no problems keeping up with a couple of our friends who are at the pointy end of the grid...... thanks x 2 to Manti
opel92 is offline   Reply With Quote
Old 05-27-2002, 09:33 AM   #222
Manticore's Avatar
not at all AMG and OPEL !
Manticore is offline   Reply With Quote
Old 05-27-2002, 12:26 PM   #223
robk's Avatar
v12xc: Hmm, where you talking about ym34 or ym34 type t? If it's a ym34, removing the antisquat is easy. Type t not so easy.
Old 05-27-2002, 12:51 PM   #224
v12xc's Avatar
I'm using Type T, hpi R35 or Sorex 36R.
I wonder if the new type S, carry adjustable antisquat ?
I think ym34 is more adjustable than type T, dun no about Type S.
Robk :
Using 20wt oil won't creat body roll?
Old 05-27-2002, 02:26 PM   #225
robk's Avatar
v12xc: I think the light oil lets the car roll a bit more, but I have been running it at like 6.5mm ride, and i have no problems with scraping. The type T has more pack in the shocks due to the new pistons, so it seems like the light oil works. I had run 60 wt oil with the older verson Ym34, and had good results. It did not work out so well with even 45wt with the type t. Maybe as I have more time on asphalt i will find out differently, but fr now, I am following Arthur's advice as he knows better than me. BTW Patt T of Team Integy 3rd place in spec class at the Reedy race. good Job!
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
New Atlas YM34CE touring chassis? seaball Electric On-Road 36 04-16-2004 11:27 PM
Team Atlas YM34 stradith Electric On-Road 6 03-24-2004 01:11 PM
atlas type t for sale with cyclone purple label and... seaball R/C Items: For Sale/Trade 14 07-14-2003 02:53 PM
