Old 01-10-2008, 03:26 AM   #1
oME
oME's Avatar
Smile WHAT IF YOU ARE THE DRIVER?
TAMIYA ASIA CUP
WHAT IF YOU ARE THE DRIVER AND YOU HAVE TO JOIN AN ENTRY LEVEL CLASS WITH THE FOLLOWING RULES WHAT WOULD YOU DO?
ENTRY LEVEL CLASS IS TT01 KITS
KITS MUST BE TT01
BODYSHELL MUST BE TAMIYA
TAMIYA BATTS ONLY(1600 NICAD, 2400NICAD, 3600 NIMH, OR 3700NIMH)
ESC MUST BE TEU 101BK ONLY
YOU MAY USE ANY SERVO
YOU MAY USE ANY RECEIVER
YOU MAY USE ANY REMOTE
WHEELS MUST BE 26MM TAMIYA WHEELS ONLY (STOCK SLICK, STOCK RADIAL, SEMI SLICKS)
TAMIYA INSERTS ONLY (SOFT FOAM & HARD FOAM)
WHAT KIT SET UP I.E. CAMBER TOE IN OR OUT?
TAMIYA GEAR DIFFS, ONE WAY, OR BALL DIFFS?
ANY HOP UPS IS ALLOWED AS LONG AS IT IS TAMIYA
WHAT WOULD YOU DO WITH YOUR HAVING TO KNOW THAT IT IS A 5 MIN RACE IN ASPHALT INDOORS?
BATTERIES?
CHARGE SETTINGS?
SET UP?
WHEELS AND INSERTS?
Itís not about winning the race itís about being on the race!
oME is offline   Reply With Quote
Old 01-10-2008, 03:37 AM   #2
MrUnlimited's Avatar
If you are an experienced driver you could intend just for fun. If you are just started it could be a great learning school
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 01-10-2008, 04:23 AM   #3
Originally Posted by oME View Post
TAMIYA ASIA CUP
KITS MUST BE TT01
BATTERIES?
CHARGE SETTINGS?
SET UP?
WHEELS AND INSERTS?
Why make it so specific about the rules you made then say all tamiya hopups allowed.
Why not just say box stock tt02 only
jamie814340 is offline   Reply With Quote
Old 01-10-2008, 04:30 AM   #4
sosidge's Avatar
If I wanted to win at any cost I would get every eligible Tamiya hop-up and do extensive back-to-back timed testing beforehand at a similar track to get the best base setup possible.
If I wanted to have fun I would just take a basic car down and run it. The TT-01 handles fine even out of the box, but I would definitely build the car with the aluminium propshaft, bearings, adjustable steering arms and some oil shocks to make everything move freely and have a degree of adjustability for the track.
Old 01-10-2008, 08:00 PM   #5
oME
oME's Avatar
Default batteries
Guys how about the batteries I think it all comes down to what tamiya battery you would use right?
NIMH
3,600
3,700
NICAD
1,600
2,400
I think with this is important because it is the power source when all things are almost equal (ESC AND KIT)
Old 01-10-2008, 08:31 PM   #6
Moonfrostee's Avatar
Default Batteries
I would definitely go with the NIMH 3700's. The increased capacity will give slightly higher voltage as opposed to the 3600's.
Moonfrostee is offline   Reply With Quote
FS: Integy Hex Wrench Driver Set_Losi Nut driver Tools_ SammyZ R/C Items: For Sale/Trade 1 03-05-2008 02:07 PM
Associated Hex Driver and Ball End Driver Tools dr_hfuhuhurr R/C Items: For Sale/Trade 4 02-26-2008 07:00 AM
Hudy Allen Driver set & 7mm driver jland R/C Items: For Sale/Trade 10 02-11-2008 06:48 PM
Milwaukee 2.4v power driver with batt and charger... High quality driver. PIC INSIDE SCUBA STEVE R/C Items: For Sale/Trade 14 01-24-2008 09:42 AM
Ball Driver OR Allen Key Driver? implusepro Nitro On-Road 6 01-22-2008 05:19 AM
